Thread Tools
Old 10th December 2007, 12:47   #1 (permalink)
Default where to install the sub?
I am planning to install a JBL GT5-12 sub in my Honda City ZX. I don't want to install it in the boot within an enclosure as it will eat up the boot space. Is it advisible to install it in the rear parcel shelf? Would that compromise the bass effect? Or there is any other place to install the sub other than boot?
Please advise. Thanks in advance.
__________________
Shen
Only those who risk going too far can possibly find out how far one can go
shenbag63 is offline   Reply With Quote
Old 10th December 2007, 13:05   #2 (permalink)
jkdas's Avatar
search for IB install (infinite baffle)
jkdas is online now   Reply With Quote
Old 10th December 2007, 13:17   #3 (permalink)
hydrashok's Avatar
The GT5-12 is intended to be used in an enclosure (about 1 cu.ft). It is not a free-air sub, so installing it on the parcel shelf will not give good enough results. (This is just what I think, Sam will be able to confirm).
For an NHC, I can't think of any place other than the boot, for a sub install. Especially the GT-5 12. I don't think there is enough space under the seats for even a 10" sub.
If you have absolutely no option to but leave the boot free, you might have to consider a compact active sub that you may be able to install under the seat. Blaupunkt sells one such sub in India. There are other options available outside India.
You will be able to install the sub in a removable box. When you want boot-space, you'll just need to unplug the sub and take it out.
Edit: This will give you an idea about the powered subwoofers available. The Infinity Basslink II and the Kenwood KSC-SW1 are pretty good (but pricey) option. If you look around, you might just get an old Kenwood w00x which was like a standard in compact active subs.
This and this are Blaupunkt's options in India.
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
hydrashok is online now   Reply With Quote
Old 10th December 2007, 15:24   #4 (permalink)
DerAlte's Avatar
Alternate 1: Perhaps a sealed box fabricated out of fiber-glass can be considered below the parcel shelf (spanning the whole width of the parcel shelf)? The sub, mounted on the parcel shelf, will be firing from a sealed box arrangement without compromising boot space.
Alternate 2: Depending on the profile on the side of the boots, one could do what Navin has done in his Octy or what Gunbir+JB had done in a CRV (?) install: make a fiber glass enclosure that uses the side area near the wheel well.
Alternate 3: Mount the sub on a 1" MDF plank behind the rear sets, and play the sub IB-mounted firing through the rear seat. Sub depth will intrude into the boot, though.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 10th December 2007, 18:04   #5 (permalink)
Jaggu's Avatar
how will a sub (speaker) mounted on the MDF tray of swift sound, is it really worth experimenting?
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 11th December 2007, 09:45   #6 (permalink)
Thanks @hydrashok and @DerAlte for the recommendations. I'll check all the options with the installer and will go for the best one without compromising the sound quality.
Also, one more clarification - whether the stock wiring in NHC is good enough or the wiring need to be changed for better acoustic handling? Any thoughts?
__________________
Shen
Old 11th December 2007, 16:20   #7 (permalink)
montyguru's Avatar
no. you've been 'gifted' with a hatch. use it to your advantage. there's nothing like a sub in a sealed box.
__________________
life is a song!
montyguru is offline   Reply With Quote
Old 12th December 2007, 00:14   #8 (permalink)
determinus's Avatar
Default Change the sub?
If you havent finalized on the sub, why dont you try a Pioneer 306 or similar ones? They are pretty good for free air/ infinite baffle/ on backseat/ parcel tray installs (all are the same thing = no box). Suits your need perfectly.
__________________
"Reality continues to ruin my life"
determinus is offline   Reply With Quote
Old 12th December 2007, 05:13   #9 (permalink)
montyguru's Avatar
Cool
sorry, i realise this is for a city zx.
__________________
life is a song!
Old 12th December 2007, 08:30   #10 (permalink)
JayD's Avatar
Hydra, do u know how much they cost in cochin? and how is their performance compared to normal subs? Planning to do something like this in my matiz, Dont think the normal box would fit in the boot. Also is there any way to stop the rear wiper from rattling??
P.S: Where can i find the kenwood KSC-SW1, and how is its performance?? And price?
__________________
ATTENDANCE- The last 3 minutes of a class which makes the 2 hours of torture worthwhile!!
Thread Tools
My first Fiberglass Install blueraven316 Sound Off and Show Off 66 15th August 2008 14:09
cant install alloys! raj_5004 Tyre & Alloy wheel Section 6 23rd April 2008 08:45
ABS-is it possible to install one? nitindangoria Technical Stuff 1 27th March 2008 23:41
Innova Install gunbir Sound Off and Show Off 77 1st June 2007 14:59
Install botched up raul Sound Off and Show Off 59 17th May 2006 13:28
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
