Thread Tools
Old 1st January 2008, 19:03   #166 (permalink)
BUSA's Avatar
How good will be th 100.4, i can wait for it, if it is going to be better. I plan to run the Illusions through any of the amps mentioned before in this thread.
Later on, i will be going for a sub and 2 channel amp to drive it. How much does a slim sub cost, something that can fit below the seats.
__________________
Got Bhp? Team-Bhp.com
Old 1st January 2008, 20:36   #167 (permalink)
low_bass_makker's Avatar
Why 2 channel for the sub rather than a monoblock ? And why slim woofer ? I think a normal 12 or 10 inch can be accommodated easily.
Old 2nd January 2008, 10:59   #168 (permalink)
BUSA's Avatar
Mono's will cost alot, hence plan to go for a 2 channel. Boot space is very dear to me, hence want to put the sub below the seat.
@ DerAlte - Thanks for the fantastic explantaion :clap
__________________
Old 2nd January 2008, 12:37   #169 (permalink)
akshay1234's Avatar
busa - i dont think you should get a slim sub. if anything get 2 slim subs under the front seats and a 4 channel to drive them. 1 slim sub wont produce much bass.
akshay1234 is offline   Reply With Quote
Old 7th January 2008, 01:30   #170 (permalink)
montyguru's Avatar
Smile
how does this work exactly? i too would like to get a pair of slim subs below the seats with an external amp...
__________________
life is a song!
montyguru is offline   Reply With Quote
Old 7th January 2008, 10:25   #171 (permalink)
hydrashok's Avatar
http://www.team-bhp.com/forum/sound-...a-install.html (Innova Install)
Not slim subs, but 2 x 8" IDQs. IDQs will be happy in very small enclosures, and they are shallower than most other subs.
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
hydrashok is online now   Reply With Quote
Old 7th January 2008, 12:11   #172 (permalink)
I think Hydra IDQ does not comes in 8 inches.
The ID 8 inch has a mounting depth of 4.75 inch. I would suggest you GZTW 8 inches which has a mounting depth of 3.7 inch and require a enclosure of 6 liters / .21 cuft.
Old 7th January 2008, 12:37   #173 (permalink)
navin's Avatar
Most slim subs do not produce quality bass. I am not even talking quantity here. but the quality of bas from these pre-fab subs can be bettered. The technology is there, bettr drivers are available but I guess market forces do not justify this.
If I had to do this I'd take a pair of 6.5" or 8" woofers - some new woofers use NdFeB magnets mounted in front of the cone - these woofers are less deep and can be accomodated in say a box that is say 5" x 12" x 12" and using EQ (a la Linkwitz) and a big amp (more EQ mean more power) tune the system to say 40-42Hz. This will give you well defined bass that will span most modern music.
every woofer has box dimensions/volume that are most suitable for it. I would check with the manufacturer's specs and confirm. remember that one must account for the volume of the woofer (along with any ports and braces) and must hence consider the NET INTERNAL volume of the box. Some techniques that will allow you to shoehorn a woofer into a smaller box are Linkwitz EQ, making the box more lossy (a controlled form is called Aperiodic loading) etc..
__________________
Scixelsyd Etinu
Old 7th January 2008, 12:41   #174 (permalink)
navin's Avatar
Actually I'd look at Illusion's IM8 which has a mouting depth of little over 2".
__________________
Scixelsyd Etinu
Old 7th January 2008, 14:47   #175 (permalink)
That will be a good option. but its power handling is 100 watts. Thats why sub will do a better job.
Old 7th January 2008, 15:51   #176 (permalink)
navin's Avatar
Try pushing 100W into most 6-8" wofoers at 50Hz. 100W is more than adequate a thermal rating. at 50-100Hz it is Xmax, Bl, Mms etc. that are more important.
__________________
Scixelsyd Etinu
Old 7th January 2008, 17:52   #177 (permalink)
BUSA's Avatar
Thank you LBM, Hydra and Navin. I have no option other then getting a slim sub, since boot space is very dear to me, infact i plan to install the amp below the seats and not behind the third row.
I am confused about the amps.
A few options : -
JBL GTO 60.4 - Rs. 5500 - It can play 90db
GZ 4.1 MK 2 - Rs. 9300 - It can play 140db
And wiring comes to 3k or what? Ichibaan wiring kit is 3k so that means by budget has gone for a mighty toss
__________________
Old 7th January 2008, 17:56   #178 (permalink)
akshay1234's Avatar
busa - ive sat in an innova with 'a' slim sub and it didnt have much bass. if you want good bass then get atleast 2.
Old 7th January 2008, 19:00   #179 (permalink)
Bass&Trouble's Avatar
Umm, it must be the Ground Zero wiring kit. Its the cheapest, good quality 8-ga wire kit. The Ichibahn kit was for Rs. 2500 or something, sold out now.
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Old 7th January 2008, 21:23   #180 (permalink)
DerAlte's Avatar
A few options : -
@busa-bhai, where and how did you get the db figures for the amps? One has to associate amp power with sub impedance and sensitivity before one gets to the db.
PS: The sub does not have to be "slim sub" (like the Pio TS-SW2541D) for the box to fit under the seat. Any sub with mounting depth less than 5" will fit into that space. The critical parameter is the box volume corresponding to the sub that you select. IMHO a 10" ID sub would be able to do a decent job (more like the roar of a full-blown 12incher than the miao of a slim sub) with a 0.5-0.6 cft box which can be shoe-horned under the Innova front seat. But, ID10 is not exactly cheap.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Thread Tools
Innova basic ice razrman Ask the Gurus 1 12th November 2008 20:14
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever Ask the Gurus 18 25th October 2008 01:39
ICE for my Innova GentleGiant Ask the Gurus 4 15th July 2008 21:24
Uber-Luxurious ICE in an Innova Sam Kapasi Sound Off and Show Off 37 19th May 2008 10:25
Budget ICE for INNOVA sudheerys Ask the Gurus 17 20th October 2006 11:14
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
