Thread Tools
Old 7th January 2008, 23:11   #181 (permalink)
BUSA's Avatar
Thanks DerAlte - I was qouted the db figures by a dealer.
I dont intend to hit even 90db to be frank, we can leave all the db game to LBM
Any sub will do as long as it fits below the seats. Can i get a normal sub which i can place in the boot and change its location from boot to between the third and fourth seats when ever i want. How much would that cost?
What about adding a MDF Tray behind the last row and adding a free air sub? I know it wont play as good as closed encosure, but should do the job.
& Yes, please give the costs for the sub.
__________________
Got Bhp? Team-Bhp.com
Old 8th January 2008, 00:10   #182 (permalink)
Bass&Trouble's Avatar
You could have 2 subwoofer cables with the same easily detachable terminal at the end routed to both places where you plan to keep the sub. This will not cost much extra.
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Old 8th January 2008, 11:19   #183 (permalink)
low_bass_makker's Avatar
Not recommended. Go for a enclosure any day in a vehicle like yours.
Old 8th January 2008, 12:32   #184 (permalink)
DerAlte's Avatar
Perhaps you should go to another dealer! Dealers (most) cook up figures for their benefit, but this one seems to be more brazen than the rest.
No, an MDF plank with free air mounting is not a solution:
a. Innova 3rd row folds to the sides, you will get NO bass then
b. There is no provision for mounting a plank, it will mess up the interior
c. Free air subs sound bhhhoom-bhhhoom - not desirable
You have the following choices:
1. Under seat (http://www.team-bhp.com/forum/sound-...tml#post124435 (Innova Install))
This would be the best solution IMHO, since it utilizes unused space and is near the main audience, obviating the need for TA. You just need to select a suitable 10" sub, which needs a small sealed box of that size.
2. 12" sub under either of the 3rd row seats - you can make a box that just fits under the seat when the seat is used. Will not take up much space when you are keeping luggage with the 3rd row folded up. You need not remove it at all
LBM-maharaj, you are sub ka boss, could you please select a good sub for @busa-bhai and design the box for him? The IDs need a small volume even for ported, I think, but I am not sure of his budget.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 8th January 2008, 12:36   #185 (permalink)
navin's Avatar
JBL GTO 60.4 - Rs. 5500 - It can play 90db
GZ 4.1 MK 2 - Rs. 9300 - It can play 140db
60.4 = 60W x 4 channels I dont see how that translates into db unless you are talking about gain.
The sub wont cost much more but you will have to run 2 sets of wires.
I dont think you can add a MDF tray to an Innova.
__________________
Scixelsyd Etinu
Old 8th January 2008, 13:17   #186 (permalink)
akshay1234's Avatar
under the 3rd row seats? theres no space.
akshay1234 is offline   Reply With Quote
Old 8th January 2008, 15:33   #187 (permalink)
DerAlte's Avatar
Sir, the bottom of the seat does not touch the floor, does it? Otherwise one will be sitting in the lotus position and going "Ooooooouuuuuuummmmm"! It was better than a Hyderabad riksha the last time I sat in the 3rd row.
__________________
Old 8th January 2008, 15:38   #188 (permalink)
akshay1234's Avatar
. but theres like an inch of space below it. the footwell is at a lower height than the seat base.
Old 8th January 2008, 16:47   #189 (permalink)
BUSA's Avatar
Thanks BT, DerAlte dbLBM & Navin.
I plan for only one sub and budget is 5k for it. No budget at all for the mono, so will have to run 2 channel on the sub and the fronts of the car by the HU. I want good sound in the middle row.
DerAlte - Which sub will fit below the third row seat, a 10inch? Can a sub be placed inside the doors?
__________________
Old 8th January 2008, 16:49   #190 (permalink)
DerAlte's Avatar
Thanks Akshay, I stand corrected. I was quoting from old flawed memory from my last 3rd row experience.
In that case below the 3rd row is ruled out.
__________________
Old 8th January 2008, 16:57   #191 (permalink)
DerAlte's Avatar
3rd row seat is ruled out, as pointed out by Akshay. Only hope is below the passenger seat. This is the most optimum - since it is near every one, power from the bridged amp channels should be enough.
Unfortunately LBM must be busy as usual - he hasn't replied to our query on sub and box yet. Wait for him / PM him.
Doors are not suitable, only the tailgate is a possibility, but not very desirable (unless you put a 12" and drive it with a mono).
__________________
Old 8th January 2008, 17:06   #192 (permalink)
Very bad car for ICE.
Old 8th January 2008, 19:04   #193 (permalink)
akshay1234's Avatar
today i saw that mtx showcar with 4 subs at the back (3rd row removed) and 1 sub instead of the glove compartment. it also had many tvs. it was an innova.
Old 8th January 2008, 23:08   #194 (permalink)
Then again a demo car. with the thrid row passanger seat it will be hard to install a sub. So it will be between the third and second row or a slim enclousre behind the last row of seats.
Old 9th January 2008, 11:26   #195 (permalink)
akshay1234's Avatar
yup. thats what i have.
Thread Tools
Innova basic ice razrman Ask the Gurus 1 12th November 2008 20:14
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever Ask the Gurus 18 25th October 2008 01:39
ICE for my Innova GentleGiant Ask the Gurus 4 15th July 2008 21:24
Uber-Luxurious ICE in an Innova Sam Kapasi Sound Off and Show Off 37 19th May 2008 10:25
Budget ICE for INNOVA sudheerys Ask the Gurus 17 20th October 2006 11:14
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
