Thread Tools
Old 18th December 2007, 22:31   #16 (permalink)
sanchits's Avatar
dude, a good VFM option is kenwood 9103d, as "akg7091" mentioned, i had bought thhe same amp from driven for rs 12000. i am running an image dynamics 12" dvc sub and it is also 1 ohm stable and has a power of 900w rms.
sanchits is offline   Reply With Quote
Old 19th December 2007, 19:40   #17 (permalink)
Bass&Trouble's Avatar
Originally Posted by nitrous View Post
Can U educate me on why a SVC doesn't need a mono while a DVC shouldn't run from a bridged 2 channel?
Against mono:
http://www.team-bhp.com/forum/ask-gu...tml#post633478 (Upgrading my Octy ICE)
For mono (and for rich people ):
http://www.team-bhp.com/forum/ask-gu...tml#post633731 (Upgrading my Octy ICE)
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Old 19th December 2007, 21:24   #18 (permalink)
determinus's Avatar
Default DVC shouldnt or DVC neednt?
I understand the statement that SVC doesnt need a mono to run. But I cannot understand why a DVC shouldn't run from a bridged 2 channel. The latter sounds like an absolute no-no. Why? I read the posts in B&T's reply, but that doesnt really give a clear answer.
Did that statement really meant -- a mono will do better justice to a DVC or that the bridged channel of a normal amp isnt powerful enough, or something else? I am very confused coz, I am planning to run an IDQ D2V2 from the 190w bridged channel of an SRx4. I tried the same channel on an SVC and it worked like a charm. So the above statement is worrysome. Any expert help?
__________________
"Reality continues to ruin my life"
determinus is offline   Reply With Quote
Old 19th December 2007, 22:48   #19 (permalink)
blueraven316's Avatar
The simple reason a SVC (4Ohm) is not suitable with a Monoblock amp, as most mono amps give peak power at 2 Ohms, and a single 4 Ohm subwoofer cannot churn the max potential of that mono amp hence not giving it's full performance.
The answer to your DVC question is, that most DVC subs are Dual 4 Ohms, and there is no way to make a perfect match with a 2/4 Channel amp which on bridged mono mode runs at 4 Ohms and the DVC sub wired in series results in 8 Ohms and wired in parallel results in 2 Ohms.
A DVC sub wired in parallel will heat the amp bridged at 4 Ohms, and in most cases amp will go into heat protect mode.
Am not very sure but the IDQ D2V2 looks like a Dual 2 Ohms sub to me, so that is no problem to run off a 4 channel, as the sub coils can be wired in series and that will result to 4 Ohms which is the exact match with the bridged 4 Ohms channel.
Hope this helps.
blueraven316 is offline   Reply With Quote
Old 19th December 2007, 23:20   #20 (permalink)
rider60's Avatar
well i am too in need of a mono block for my pioneer (dvc i guess), its a 900watt champion series woofer, which mono block is recommended at the least possible price, its currently running on my sony 500watt 555model 4-channel amp,completely red in color with the X-shaping, along with the front blaupunkt components connected to the same amp,
for the rear pioneer 420watt coaxials i have conneted the 350watt sony 2-channel amp seperately! i recently purchased the 350watts 2-channel its the latest model! the black and the silver color!
which mono is suggest that costs the least?
rider60 is offline   Reply With Quote
Old 20th December 2007, 15:45   #21 (permalink)
determinus's Avatar
Hope this helps.
So, if the impedances match there is no issue. Is that right? When I read B&T's and others statements it felt like something else. If only B&T can clear the air on why he said so, it would be perfect.
Yes, the D2V2 is a dual 2 ohm which in series is 4 ohms and works for the bridged channels. If I get a mono, I understand that may not be able the extract the complete juice out of it using the D2V2 sub. May I can get one more of those subs and wire them in parallel (voice coil still in series) to make 2 ohms!
@rider60: Try the Pioneer D510 mono. About 8-9k and 500w RMS, great VFM.
__________________
Old 20th December 2007, 16:33   #22 (permalink)
I'm sorry to cause the confusion.
By DVC, I meant commonly available entry level dual 4 ohms subs. These are the most common.
By SVC, I mean single 4 ohm subs. Again, the most common SVCs.
As you have mentioned correctly, it all boils down to the final impedance presented to the amp.
So lets just say that 2-ch amps in bridged mode (ones that cannot run 2 ohms in bridged mode) are good for subs that pose a 4 ohm load, and monos (designed for max output at 2 ohms) are good for subs at 2 ohms.
__________________
Old 21st December 2007, 10:22   #23 (permalink)
navin's Avatar
Originally Posted by Bass&Trouble View Post
As you have mentioned correctly, it all boils down to the final impedance presented to the amp..
and the amp's ability to manage low impedances with aplomb.
__________________
Scixelsyd Etinu
Old 21st December 2007, 15:20   #24 (permalink)
beanstalk_230's Avatar
So what would actually be a good VFM mono and sub combo ??
[VFM - entry level mono and 4-5k sub]
__________________
Gaurav
beanstalk_230 is offline   Reply With Quote
Old 21st December 2007, 15:24   #25 (permalink)
nitrous's Avatar
Entry level mono would be a JBL CS300.1 as everyone here is recommending.
It puts out around 300W RMS at 2 ohm impedance.
So, a DVC sub that can take 300W rms and the coils are wired in parallel would be best.
I think in JBL, U have the GTO 1204D.
Even Id be interested in a similar combo.
__________________
2004 2005 2006 2007 2008 - 5 consecutive titles.
Arguably,the best the sport has ever seen!
Old 21st December 2007, 15:42   #26 (permalink)
apart from jbl do we have any other VFM options available like the one mentioned by akg from kenwood , or any other
__________________
Gaurav
Old 21st December 2007, 15:49   #27 (permalink)
@Nitrous, your subwoofer is GT4-12 right?
Is it a SVC woofer or a DVC?
Ford_madhan is offline   Reply With Quote
Old 21st December 2007, 15:54   #28 (permalink)
nitrous's Avatar
GT4-12 is a 4 ohm SVC.
I think I will replace it when upgrading.
__________________
Old 21st December 2007, 18:56   #29 (permalink)
rider60's Avatar
will the pioneer7300 mono block costing around 7500 at my place be good for my DVC 900W champion series subwoofer? or should i buy the jbl's cs301.1 as the cs300.1 is unavaliable as of now?
need urgent help on deceding please people reply asap, as i wont be having time for another 3months to get any one of the monos fixed, after the christmas!
Old 21st December 2007, 19:04   #30 (permalink)
nitrous's Avatar
I just googled,rider.
Your Pioneer 12" champion series is a 300W RMS. A pioneer 7300M or the JBL 300.1 is enough.
__________________
Thread Tools
Is the Hyundai I10 VFM ? khuz1979 Hatchbacks 15 29th August 2008 00:15
Best VFM Performance Subs gemithomas Ask the Gurus 52 15th March 2008 15:43
Best VFM tweeters? kvish Ask the Gurus 18 10th March 2007 10:27
How VFM is the Tata Indica? ported_head The Indian Car Scene!! 67 15th July 2005 00:34
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
