Thread Tools
Old 27th December 2007, 16:50   #16 (permalink)
determinus's Avatar
Originally Posted by DerAlte
I wouldn't be surprised if the installer had connected one voice coil of the sub each to the left and right rear channels of the 4-ch amp
@Der Alte: Is this a sin? I have seen 75.4 bridged to two channels and driving the two voice coils of a sub. The install was tuned/ passed by gurus. Hence the query. So if each coil offers 4 ohms and the sub is 400 rms, what is wrong with driving 200w into each of the coils using a 2 channel amp?
one options is to use the 4 ch. amp for the sub and that is what I would do.
@Navin: Related question. When you say use the 4 channel to drive the sub, does that imply the above connection (separate to coils) or bridged to 1 channel and wire the coils to match the load?
Thanks in advance.
__________________
"Reality continues to ruin my life"
determinus is offline   Reply With Quote
Old 27th December 2007, 18:48   #17 (permalink)
navin's Avatar
Originally Posted by determinus View Post
@Navin: Related question. When you say use the 4 channel to drive the sub, does that imply the above connection (separate to coils) or bridged to 1 channel and wire the coils to match the load?.
4 channels are bridged to 2 and then each bridged channel drives 1 4ohm coil. this way the amp is not taxed.
__________________
Scixelsyd Etinu
Old 27th December 2007, 20:04   #18 (permalink)
determinus's Avatar
So then why is it mentioned as not-a-nice-to-have situation by DerAlte? [confused]
__________________
Old 28th December 2007, 09:41   #19 (permalink)
DerAlte's Avatar
Thanks in advance.
Sin??? NO, not at all - Navin has correctly described the desirable config - and YOU have seen it.
The 2 channel amp is 65W per channel, so it will drive only 130W combined into ONE coil (since the amp can't take 2 ohms load in the bridged mode). If one wants to drive 200w into each of the coils using a 2 channel amp, one will need a 200W-per-channel amp.
If you read carefully, I had joked about LEFT channel of the front or rear pair driving one coil of the sub and RIGHT channel driving the other - quite different from FRONT BRIDGED driving one and REAR BRIDGED driving the other. @rider60 has the Front components AND the sub on the 4-channel, which precludes using the 4 channels for the sub, unless he shifts the Front components to the 2-channel amp AND drives the Rear coaxes from the HU.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 28th December 2007, 14:21   #20 (permalink)
rider60's Avatar
okay here is what i am going to do,
i am either getting another 4-channel giving away my 2-channel, and power sub completely bridging the 4channels into two, and power each coil seperately, then use the other 4-channel for the front and the rear coaxials!
the other 4channel i intend to get is sony
Sony India : XM-ZR604 (XMZR604) : Details
its xm-zr604,instead of buying a mono for my sub, this will cost me another 1000 bucks extra thats all if i go in for a mono then its minimum 7000 bucks i need to spend so will doing make my ice setup better or should i wait and get the mono itself?
rider60 is offline   Reply With Quote
Old 30th December 2007, 02:24   #21 (permalink)
rider60's Avatar
these are the pics of my amps, now that i have posted the pics, and i have connected the sub to the 2 channel by bridging it and the speakers to the 500 watt 4-channel amp, i want to know what are the best amp and the equilizer settings to be made for the good music.
can you guys tell me the right voltages to be set and the hpf and lpf settings on the amps and equilizer setting on my 6850 pioneer HU.
this should do good for now, i guess , guys i am really looking forward to this please post asap for i am leaving for a long drive tomorrow and the settings will ensure i enjoy the best music! thanks guys in advance!
Old 30th December 2007, 15:42   #22 (permalink)
navin's Avatar
can you guys tell me the right voltages to be set and the hpf and lpf settings on the amps and equilizer setting on my 6850 pioneer HU.!
I usually set my EQ to flat. start from there.
to start set HPF 63Hz/12db and LPF at 80Hz/12db.
__________________
Scixelsyd Etinu
Old 30th December 2007, 18:05   #23 (permalink)
rider60's Avatar
okay i will set the amp to flat, and the following hpf and lpf in the HU, but what do i set the lpf on the 2channel do i turn the power protection on or off on the 2channel which is currently powering the sub woofer?
Old 30th December 2007, 22:12   #24 (permalink)
navin's Avatar
since the amp is driving a 4ohm load in bridged mode it does not hurt to keep the power protection on.
__________________
Scixelsyd Etinu
Old 30th December 2007, 23:45   #25 (permalink)
Bass&Trouble's Avatar
What is 'power protection', and how does one turn it on?
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Old 31st December 2007, 01:38   #26 (permalink)
rider60's Avatar
look close on the amps they have the hpf and the lpf on off switches and the power protection lamps just beside the switches they are the ones we are talking about!
Old 31st December 2007, 09:43   #27 (permalink)
navin's Avatar
currnet overload protection.
__________________
Scixelsyd Etinu
Old 31st December 2007, 10:39   #28 (permalink)
nitrous's Avatar
Dude, B&T asked where the switch for the power protection is, since U mentioned about switcing it on/off.
Old 31st December 2007, 11:13   #29 (permalink)
DerAlte's Avatar
I don't think Sony gives the option to the user of destroying the amp by switching off the o/l protection.
That must be the post-facto indication (LED) that current-overload is occurring / has occurred (either by playing too loud or by shorting).
__________________
Old 31st December 2007, 11:14   #30 (permalink)
navin's Avatar
that is true. i dont see any switch to turn pwer protections on or off. the LED just comes on when the amp has chosen to protect itself.
__________________
Scixelsyd Etinu
Thread Tools
need help in configuring and installing a car pc sandeeprao_86 DIY - Do it yourself 5 16th November 2008 15:40
ICE ICE Baby!!!!!!!!(Swift ICE) scarlet.fever Ask the Gurus 18 25th October 2008 01:39
ICE for my RS redsfx Ask the Gurus 13 19th September 2008 17:39
HELP-Configuring Limewire in a Proxy environment esteem_lover Gadgets, Computers & Software 0 27th May 2008 18:28
HELP - configuring email on Nokia 7610. normally_crazy Gadgets, Computers & Software 6 4th August 2005 19:04
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
