Thread Tools
Old 23rd December 2007, 02:25   #1 (permalink)
rider60's Avatar
Red face need help configuring my ICE
AMPLIFIER #1
http://www.sony.co.in/product/xm-zr6...ite=hp_en_IN_i
this is the link to my two channel amp which is 350 watts this page contains both the features and the technical specifications you asked me to post you
AMPLIFIER #2
http://www.sony.co.uk/view/ShowProdu...ICA+Amplifiers
this is the link to my 4/3 channel xm-504z sony xplode amplifier, now i think you can tell me which configuration is the one which can give me best sounding music,
PIONEER SUB-WOOFER:
http://www.pioneer.com.sg/storefront...&CatId=2,27,36
this is the exact woofer i have in my car its mentioned 900watts behind though,
HEAD UNIT:
the head unit is pioneer 6850 i dont remember the exact model number which is close to the link below, the link i could find was to deh-p6950
http://www.pioneer.com.sg/storefront...&CatId=2,24,32
well mine has the output for the front , subwoofer and the rear speakers sperately! it has two allowed AUX ports and an ipod connect right below the panel face of the HU!
REAR CO-AXIALS:
my rear speakers are 420watts ones the model number is TS-A6981S which are actually two years old! i could not find the site for these rear coaxials so just posted them with the correct model numbers!
FRONT COMPONENTS:
here is the link to my jbl gto607c components for the technical specifications sake,
http://www.jbl.com/car/products/prod...at=COS&ser=GTS
now my query is that what is the best way to connect and configure the ICE?
which amp do i use to power the sub woofer? whichamp do i use to power the components and which ones do i use to power the coaxials at rear?
which would be the best sounding configuration for the best sounding music?
gurus please help me configure for the optimum performance with this setup!
thanks a ton in advance!
rider60 is offline   Reply With Quote
Old 26th December 2007, 10:54   #2 (permalink)
Team-BHP Moderator
DerAlte's Avatar
You don't have much choice there, so go for the simplest:
1. Connect the Front and Rear Preamp-OUTs to the 4channel amp and the Sub-OUT to the 2-channel
2. Bridge the 2-channel amp and connect the Pio sub to it
3. Connect the front compos and the rear coaxes to the 4-channel amp
4. Set all tone controls to flat at the HU, Fader to 0. Play your favorite CD
5. Set the LPF at the sub amp to 80Hz, and for the time being keep the volume to the lowest at the 2-ch amp
6. Set the HPFs at the 4ch amp to 80Hz
7. Set the front volume at the 4-ch amp to a comfortable listening level, with the HU volume set to 1/3 of the highest
8. Now bring up the rear volume at the 4-ch amp gradually till it just interferes with the front, and then reduce slightly
9. Then, increase the volume at the 2-ch amp till you can just feel the sub sound in the front. Double check by reducing till the sub feeling goes away and increase back to the "just feeling" level
10. If you are THUMP-happy, increase the volume at the 2-ch by a couple of notches. If you now increase the volume at the HU, the THUMP will be more pronounced, but not out of proportion with the music
Double check the tuning with a couple of different CDs (vocals, instrumentals, drum & bass, ... whatever is your fancy) till you don't have the tinkering urge anymore.
Maybe the gurus can suggest a better LPF/HPF frequency?
Enjoy!
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 26th December 2007, 11:44   #3 (permalink)
jCube's Avatar
Some statments you made are confusing. Can you elaborate what you meant? Did you mean the gains?
jCube is offline   Reply With Quote
Old 26th December 2007, 12:58   #4 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Egjhackly, j^3 Sir!
__________________
Old 26th December 2007, 13:09   #5 (permalink)
RAC
Enjoy!
Hi. Can you please explain point no.2 on what it means and how is it done.
RAC is offline   Reply With Quote
Old 26th December 2007, 13:33   #6 (permalink)
rider60's Avatar
as of now the connections give by the car decors guy are front components powered by the 4-channel amp,
the sub powered by the 4 channel amp
and the rear co-axials are connected to the 2channel amp!
the preamps-outs are connected accordingly
will this be okay, or will this harm the spearkers or sub or the amp or the hu in any way?
i asked the car decor guy to bridge the 2channel amp, the guy says that the loud thump will be lost if bridged, i too need to know to bridge the 2-channel before i do so!
okay will connect the things as told by you deralte asap! if thats the best configuration!
Old 26th December 2007, 14:47   #7 (permalink)
jCube's Avatar
Egjhackly, j^3 Sir!
Well, the gains setting feature provided in amps is a way of matching your HUs pre amp voltage to the input voltage of the amp. Different HUs have different pre amp voltages; commonly seen voltages range betwen 2V to 6V. The gains feature allows you to specify this. In other words, it helps you to get the most out of your amp with least distortion, if used correctly.
Using your gain as a volume control is the surest way to damage your equipment.
The bridged output of your 2 ch amp is 130wrms, 10watts more than the bridged output of ch 3 and 4 of your 4ch amp. It wouldnt make much of a difference though, but driving your sub off the 2ch amp, as suggested earlier, is better.
Old 26th December 2007, 15:14   #8 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Simple generic extension of what the installer would have seen with conventional expansions from (4-ch amp driving front and sub) to (4-ch amp driving front and sub + 2-ch amp to drive rears). He should read up the ICE-section and manuals.
* The link that you posted for the 2-ch amp says "Rated Output Power: 1 Ch x 130W at 4 ohm (0.1% THD)"
* The link for 4-ch amp says "Min. channel configuration at 4 ohm (W) / THD (%) 2x 50 + 1 x 120 / 0.1%"
* Not that there is a BIG difference in the 2, but still the bridged 2-ch is producing a teeny-weeny bit more than 2-ch bridged of the 4-ch. One wouldn't think that the thump will be less (I am sure he didn't read the amp specs)
* On the other hand, the 2-ch has ONLY an LPF, making it more suited for the sub. In other words, the 4-ch with its HPF would be more suited for driving the rear channels
No, the existing setup will not harm the speakers or amp in any way, but maybe you could consider the above.
@RAC: Q.v. Bridgeable Amplifiers for bridging
__________________
Old 26th December 2007, 18:44   #9 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Sorry sir, I am not much of a wordsmith, nor a good engineer, but there is a difference between "adjusting the volume with the gain control (tuning)" and "using a volume control to adjust the relative loudness of music generally". The "matching your HUs pre amp voltage to the input voltage of the amp" is the logical description of the physical process of tuning by one's ears.
The 2V or 6V is the max peak-to-peak voltage (before it distorts) given as a guidance by the HU designer, corresponding to 100% volume setting on HU. What you actually get at the Pre-out is a factor of the HU volume control. So, at 33% of the volume scale at the HU, you are likely to get 33% (on a logarithmic scale) of say, 2V, as peak-to-peak output.
And BTW, there is no "input voltage of the amp" - whatever the HU produces appears at the amp input, and if it is insufficient to produce adequate loudness at your ears, one changes the amp "gain" to "make it louder"!
The only thing that will be damaged by frequently adjusting the gain control - if one really desires to do so - is likely to be only the potentiometer attached to the knob, and not the rest of the equipment. Otherwise, one normally sets it and forgets it - the main control is the HU volume control.
__________________
Old 26th December 2007, 19:30   #10 (permalink)
Team-BHP Moderator
navin's Avatar
For most applications I prefer
HPF Front: 63Hz/12db or 50Hz/18db
HPF Rear: 80Hz/12db or 100Hz/12db
LPF Sub: 80Hz/12db or 63Hz/12db
most gain controls are linear and most volume controls are log. at least they were in the the "old days".
__________________
Scixelsyd Etinu
Old 26th December 2007, 23:35   #11 (permalink)
rider60's Avatar
well deralte, i appreciate all the information, but right now atleast nor do i have the time nor the energy to read through all the pages of the link you provided, sorry for that.
what i do want to know is, do you want me to short the positive and positive and the negative and negative and connect the sub woofer to opposite +ve and -ve ends?
how exactly do i connect the wires, so as to bridge the 2-channel amplifier? and the are two +ves and two -ves in the sub too like i already told you its a DVC sub woofer, please illustrate the wire connections to be made for the sub and the amp bridging thank you in advance!
Old 27th December 2007, 09:51   #12 (permalink)
Team-BHP Moderator
DerAlte's Avatar
@rider60, we are in a bit of a bind here!
* Your sub is a 4 ohms DVC. If you parallel the coils (connect one of the sub + to the other +, and - to -), you will get effectively 2 ohms
* I couldn't find the manual for the XM-ZR602 anywhere on the net, nor of the TS-W307D4 subwoofer. If you have the manuals, please double-check what I have written below
* If one were to go by the manual for XM-554ZR and the XM-504Z, the Sony amps CANNOT take 2 ohms load in the bridged mode, because each channel would see 1 ohm effectively and THAT is a no-no in the Sony tech specs
* Your DVC sub is 400W nominal, which would mean it can take 200W per 4-ohms voice coil
* Since the max you can feed is 120 / 130W, your only recourse with this sub is to use one of the voice coils bridging the 2 channels
* For bridging the 2-channel amp, connect the + terminal of the sub (one of the coils) to the + of the left channel and - to the - of the right channel (please see http://download.css.ap.sony.com/cons...D%2b6Q%3d%3d#a Page 2 Connection Diagram 2)
Now, how it is currently connected is a mystery to me, since I have not seen the installation. In a lighter vein (with all due respect to the original installer), I wouldn't be surprised if the installer had connected one voice coil of the sub each to the left and right rear channels of the 4-ch amp!
Navin-ji, should @rider60 leave the other voice coil open or should he short it? Maybe the Pio sub will behave better with one coil shorted!
Come to think of it, @rider60, we should "let the sleeping dogs lie": let the installation be as it is - unless you really feel something is wrong. At least you will not be provoking Murphy's laws.
__________________
Old 27th December 2007, 10:00   #13 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Of course, and they will continue to be like that in the future too - unless evolution changes the characteristics of the human ear.
I was using the "log" law in the relationship between Pre-OUT signal and the Volume Control. Even if the VC is implemented in software, one uses log law as with pots of yore.
__________________
Old 27th December 2007, 11:00   #14 (permalink)
rider60's Avatar
okay i understood how to bridge now i will post the pics of the new configurations asap, thanks a ton for all the info deralte.
Old 27th December 2007, 15:05   #15 (permalink)
Team-BHP Moderator
navin's Avatar
neither of the amps rider has can drive a 2ohm load when bridged. one options is to use the 4 ch. amp for the sub and the 2 ch amp for the front components and let the Hu drive the rear. that is what I would do.
Der Alte, between leaving the spare coil open or short I'd go short. It should drop Qtc a bit and hence result in slightly less boomy bass.
Also it is not only Murphy's Law rider shouldbe worried about. ICE laws at TBHP are also known to have their influence. These laws have been listed here...
http://www.team-bhp.com/forum/ask-gu...ing-forum.html (STATUTORY WARNING - 10 Risks to know before entering this forum!)
__________________
Scixelsyd Etinu
Thread Tools
iS my ICE OK? sandyrocks Ask the Gurus 11 27th November 2007 11:58
Ice!!! vivekiny2k Ask the Gurus 15 14th August 2007 16:58
Baleno ICE Help invincible7 Ask the Gurus 18 10th May 2007 12:42
Need your help on ICE....Please!!! shiv Ask the Gurus 3 4th May 2007 20:51
HELP - configuring email on Nokia 7610. normally_crazy Gadgets, Computers & Software 6 4th August 2005 18:04
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
