Thread Tools
Old 30th December 2007, 17:30   #1 (permalink)
Default Need help for speaker setup in Ikon
Hi experts,
I am a noobie to the world of ICE and seek your help for my Ikon's speaker setup. Currently, the car has the factory fitted HU with a cassette player and a 6-cd changer in the trunk (not sure of the brand) with 2 front and 2 rear speakers (again, I do not know the brand).
Off late, the rear speakers seem to be having some issues with handling slightly higher sound level, which has made me look at replacing the speakers. After going through similar threads in this section, I am thinking of the changing over to the following:
JBL GTO 507C : Front
JBL GTO 937 : Rear
Can you please suggest
a) if these speakers would work well with the existing HU or do I need to go in for a HU change as well?
b) if an amplifier is a must for this setup?
c) where in Bangalore can I get this change done?
Girish.
girishab is offline   Reply With Quote
Old 30th December 2007, 22:30   #2 (permalink)
amangujral06's Avatar
upgrading to speakers u mentioned will make your system sound much more better ,may be louder too because factory fitted speakers are just simple and cheap speakers and those speakers(new) have higher efficiency thus sounding louder and more clearly..i.e. they will work out well
the thing you should look for is after upgrading to new speakers,is that loud enough for you?
if not you MAY go for a 2/4 channel amp according to your need.
if you dont need a sub -don't buy it..you should be the person to take the decision!
now for head unit.. if you are not satisfied with the sound quality of ur factory deck then u may go for a better aftermarket one..if ur satisfied ur way to go..
if you are not satisfied with the sound output/loudness with new speakers then you may go for a 2/4 channel amp..just make sure your headunit have RCA out..best of luck
amangujral06 is offline   Reply With Quote
Old 31st December 2007, 00:53   #3 (permalink)
nitrous's Avatar
http://www.team-bhp.com/forum/ask-gu...t-20k-max.html (ICE for IKON..Budget 20k MAX..)
Old 31st December 2007, 09:57   #4 (permalink)
navin's Avatar
JBL GTO 937 : Rear
b) if an amplifier is a must for this setup?.
The Factory HU will need line level adpaters however some amps have line level inputs.
if you find your self pushing the volume past it's halfway mark get an amp it will help.
in bangy, anwar, deepak asrani, blueraven (a member here) can help.
__________________
Scixelsyd Etinu
Thread Tools
Help in choosing a new speaker. shreyasma Ask the Gurus 8 4th June 2008 12:15
Need help for HU and speaker ~~VinZ~~ Ask the Gurus 56 17th October 2007 19:15
Ford Ikon mod - fiesta head on ikon block? madhunm Modifications & Accessories 2 2nd July 2007 10:24
Upgradation to Component speaker setup! dsinz Ask the Gurus 8 19th December 2006 14:16
Speaker question mohit Ask the Gurus 13 24th May 2005 20:43
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
