| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Dec 2005 Location: Mumbai
| Hi all, I had a very technical query about Amplifiers. Power rating of amplifiers are done of specific Volts eg. 400 RMS @ 11 V , 800 RMS @ 12 V, 1500 RMS @ 14.4 V etc... If i am not wrong the car batteries are something like 12 V? So, my DD M3 amp, says that it outputs 2400 watts RMS @ 1 ohms at 12.8 V 2700 watts RMS @ 1 ohms at 14.4 V 3000+ watts RMS @ 1 ohms at 16 v Now my question is that, if i want to run my system at 14.4 V, how can that be done? Car batteries are 12 V, do you get batteries above 12 V also? May be stupid question, but i am throughly confused.
__________________ BASS ADDICT Digital Designs 3512 x 2 Digital Designs M3 mono block amp Next is What?.....surely not a mobile phone :P |
| | #2 (permalink) |
| Distinguished - BHPian ![]() | I think with all the electrical components of your car running fine (Alternator, Battery etc.) your car's system voltage is around 14.4V by default. Don't know what'll be the effect of the amp's load on it though. I think LBM/Tanveer/B&T/Navin/Sam/Gunbir can explain more.
__________________ Power corrupts. Absolute power is kind of neat. |
| | #3 (permalink) | |
| Quote:
Anyways, let wait for some expert comments.
__________________ BASS ADDICT Digital Designs 3512 x 2 Digital Designs M3 mono block amp Next is What?.....surely not a mobile phone :P | |
| | #4 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: New Delhi
Infractions: 0/1 (4) | 12.6-12.8 : Engine turned off, only battery. 13.1-13.6 : Car running, without heavy electrical accessories. 14.4 : HOW? Its good that you started this topic, even I was thinking of opening a similar thread.
__________________ SINGH IS KINNNNNNNG.. |
| | #6 (permalink) | |
| BHPian Join Date: Dec 2007 Location: Kanpur
| Quote:
Now with electronic regulators we have 13.6-13.8V. Strictly speaking the ideal voltage for a battery drops with increasing ambient temperature.
__________________ Life is short, do not make it shorter! | |
| | #7 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
12.6-12.8 : Engine turned off, only battery 13.1-13.6 : Engine running, electrical accessories running, battery charging 14.4 : Engine running, over-rated alternator + regulator, no other electrical accessories running (except ICE) and battery fully charged Battery is 12V NOMINAL; does not mean voltage at the terminals cannot be more.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | |
| | #9 (permalink) |
| Fine... but what if i want to go upto 16.6 V....just a question, not my intension Guys have bench tested the amp, and as said above it draw 2700 RMS @ 14.4 V, and 3200 RMS @ 16.6 V. So how can car electrical be pulled up to 16.6 V then?
| | #11 (permalink) |
| Haan, thats what i am asking....that with AC on + Engine Running + ICE Installed, how can the entire system be made to operate at 14 V or 16V?
| | #12 (permalink) |
| Senior - BHPian | 1.U need a deep-cycle battery like the Optima yellow top. 2.U'll need an uprated alternator to churn the current to charge the battery. If U dont do the above,U'll be using up car batteries like eveready batteries used on digicams. LBM has lived with a similar setup.So, he'll have a lot to say here. |
| | #13 (permalink) |
| Team-BHP Support ![]() | The Load voltage is always less than non-load voltage at the output terminals of a power source. So unless you have a 500A alternator, and your usage is 10A, you cannot escape voltage drop. Ideally your voltage should not drop below 13V with ICE on. If you are facing that, you should upgrade to a bigger alternator. A high Ah battery is a stop gap solution.
__________________ Reclaiming.....! |
| | #14 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| You cannot maintain battery voltage of 14V or higher continuous unless you are using a bank of batteries and/ or high amperage alternators and/ or serial batteries of 2-4 volts. Your setup without any power supply enhancements will run for the most part in the 11.5 to 12.5 volts range, for short periods.
__________________ Operator! Give me the number for 911! |
| | #15 (permalink) | |
| Quote:
One way is to mount another alternator with a full-wave bridge rectifier, with the regulator set for a different voltage. BUT, are you sure the amp is rated to work at 16.6V without going up in smoke? Maybe you should read the fine print - it should say somewhere for how many seconds is that allowed! Amp electronics IS over-rated for safety - but SAFETY is the buzz-word.
| Thread Tools | |
Similar Threads | ||||
| HELP! - Amplifier switching off | esteem_lover | Ask the Gurus | 21 | 25th June 2008 17:11 |
| Amplifier questions | nishantgandhi | Ask the Gurus | 16 | 1st February 2008 11:03 |
| Amplifier tuning | jinu_joseph | Ask the Gurus | 21 | 3rd August 2007 13:14 |
| need help in getting right amplifier | virender_gaur | Ask the Gurus | 49 | 2nd October 2006 20:04 |
| Help me with my amplifier | WILDTHING | Ask the Gurus | 1 | 2nd January 2005 11:32 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
