| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Sep 2007 Location: Kolkata
| hey guys i m getting radio signal problem as the signal sometimes get very weak and the sound gets distorted in my Alto..as it was working fine but suddenly this problem started.i have changed antenna & car headunit 3 times but the problem is same,is there any problem with my car or some fuse blown up please help... :my car rig: SONY 222 AMP PIONEER HEADUNIT PIONEER REAR AND FRONT SPEAKERS.. |
| | #2 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Did you ask the antenna mounting person to check for electrical continuity from antenna end to HU antenna socket? Most likely the wire from the antenna to the HU has broken somewhere in between. In that case, no matter how many times you change the HU and antenna, you will have the same problem.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #3 (permalink) | |
| Senior - BHPian | Quote:
- Took out the HU. Antenna plug was properly in. - Checked the antenna end. Connection was ok. - Traced the cord/wire from behind the HU to under the panel below the steering. Voila! Found another male-female connection there. This plug was disconnected.
__________________ PIGZILNKILJBSCOMB | |
| | #4 (permalink) |
| whenever i touch the antenna steel side the signal gets stronger i live in kolkata central and there is no radio signal problem, other cars get good radio signal like my Mahindra Scorpio the signal is smooth...no distortion.. |
| | #5 (permalink) | |
| BHPian Join Date: Jun 2007 Location: Kochi
| Quote:
I am also having the same problem. Poor FM reception throughout Kerala. Nil recepiton when the vehicle is moving. Reasonably good if vehicle moving and I touch the antenna. Reasonably good if vehicle is stationary and I do not touch the antenna. Good when the vehicle is stationary and I touch the antenna. The auto tuning does not work. I have to manually tune the HU. The HU is Pio 4050 and the car - WagonR.
__________________ ɹǝʌıɹpʇɐǝsʞɔɐq | |
| | #6 (permalink) |
| Senior - BHPian | BaCkSeAtDrIVeR : Check the connections and also make sure that the antenna is also of a good quality. I'm having very clear receptions(even at Piravom) whether the vehicle is stationary/not.
__________________ Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly. |
| | #7 (permalink) |
| Thanks. I did guess that it is a problem with my set up. But had no clue where to start trouble shooting. What HU are you using?
__________________ ɹǝʌıɹpʇɐǝsʞɔɐq Last edited by BaCkSeAtDrIVeR : 13th September 2008 at 14:41. |
| Thread Tools | |
Similar Threads | ||||
| Problem with Radio Tuning | manaa45 | Ask the Gurus | 7 | 15th October 2008 21:21 |
| Wierd problem: Toxicity in my new Alto | nitin.dangayach | Technical Stuff | 33 | 29th August 2008 13:48 |
| Problem with Alto Lxi (between 65-75 kmph) | kishoryk | Technical Stuff | 20 | 11th August 2008 18:31 |
| FM radio signal amplifier- is it available? | arunkumar_rec | Ask the Gurus | 21 | 19th December 2007 11:58 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
