Thread Tools
Old 16th January 2008, 11:38   #1 (permalink)
Exclamation Help for ICE in Getz
Hi Gurus,
I just bought a 2nd hand Hyundai Getz in which the previous owner has installed the following ICE:
1. HU: Blaupunkt Bahamas MP34
2. Rear speakers: Pioneer TSA-6980 6x9
3. Front speakers: Wasnt able to open the speaker enclosure but there are 2 speakers fitted in front as well.
Now the problem is that when I increase the volume, I hear a bad noise from both the rear as well as the front speakers (it is similar to when someone is clearing his throat - hope you got that!). This noise gets worse when I turn on the X-Bass feature of the HU.
Someone told me that this is the noise created by dust settled in on the speakers. (?)
Going by your advice on TBHP, I have finalized on the following config for the ICE:
1. HU: Pioneer 4900/6900UB
2. Rear speakers: JBL GTO 937
3. Front speakers: JBL GTO 507
What is your advice on this? I love music and listen to all genres. I love deep bass as well and want to connect my Ipod to my ICE through Griffin iTrip FM transmitter (already own that).
However, my budget is not more than 10-12K so I dont think I can afford amp/SW etc. (Or can I?)
What I want to know is the following:
1. What will be the total cost (including wiring, installation, MDF board etc) for my proposed ICE config?
2. Will I get anything money in returning my already installed ICE?
3. Can you suggest some places in Mumbai to get this done?
nishantgandhi is offline   Reply With Quote
Old 16th January 2008, 11:55   #2 (permalink)
navin's Avatar
Originally Posted by nishantgandhi View Post
I hear a bad noise from both the rear as well as the front speakers..This noise gets worse when I turn on the X-Bass feature of the HU.
the speakers might be damaged. in any case you are getting a new system.
the system you have speced will cost more than 12K. On your budget you can go for a cheaper Pio HU (39xx) and JBL's GT5 series of speakers instead.
The sound quality via the FM transmittter is severly compromised. I would suggest you use an ipod cable. Many current HUs are ipod compatible and can even control the ipod. You'd have to check if the 39xx or 49xx are.
__________________
Scixelsyd Etinu
Old 16th January 2008, 14:28   #3 (permalink)
Thanks Navin. But I MIGHT go for a new system if and only if the speakers are damaged. Is there any way to check whether they are damaged or is this just a build up of dust?
If I exclude the HU (assuming Blau Bahamas fits my taste already), can you tell me the price for my specified set of speakers?
Old 16th January 2008, 16:35   #4 (permalink)
DerAlte's Avatar
Navin-ji, I have a feeling Gandhiji is severely dissatisfied with the apparent loudness and bhass-response of the existing system. Perhaps there is nothing wrong or dusty with his existing HU or speakers. In his quest for dumdaar awaaz he might have taken the HU well into the clipping region! This is evident as he mentions
* All 4 speakers are clearing their throats simultaneously and collectively (OUCH)
* "This noise gets worse when I turn on the X-Bass feature of the HU"
* He has not mentioned at what Volume setting his system starts clearing its throat
Perhaps he should put in an amp (tuned well) to see if THAT gives him his SPL fix. If it does, he still gets to keep his cake and eat it too. Throw in a sub, and maybe he will be doing garba around the car with his loved one! Heeng lage na fitkari... the Pio 6x9 will anyway work decently on the HU, so a 4-channel amp and a sub tube will do in his budget. Ab bolo, kaun sa lagana hai?
If the speakers ARE bad (all of them? too much of a coincidence) even on the amp, it will be easy for him to replace the speakers later, without guilt or penury.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 16th January 2008, 23:03   #5 (permalink)
navin's Avatar
Originally Posted by DerAlte View Post
Navin-ji, I have a feeling Gandhiji is severely dissatisfied with the apparent loudness and bhass-response of the existing system. .
You are right I did not notice that he said all 4 speakers were "complaining".
__________________
Scixelsyd Etinu
Old 17th January 2008, 00:30   #6 (permalink)
low_bass_makker's Avatar
Ya like Deralte said please tell that the speaker clear there throat at low volumes also as the HU internal amps have got no juice to drive speakers. If you like high volume get a amp and keep all the existing stuff you might get some good result on the present setup also.
Old 17th January 2008, 09:19   #7 (permalink)
Update: I checked last night. All four speakers dont make noise collectively. The front ones go bad earlier than the rear ones.
My system has really no output at lower volumes (upto 18-20 volume, I can hardly hear anything!). The music becomes audible only after 20.
Are there some connections which are weak? Or wiring gone bad?
Old 17th January 2008, 12:00   #8 (permalink)
DerAlte's Avatar
Minor difference, they all go bad after a certain point.
Another question: does this happen no matter which source you use? FM, AM, CD? Could you please check again?
I use the same HU and it is unbearably loud both for FM and CD at volume 20. Please don't be offended by my question, but is MUTE on by any chance?
If you consider that the problem is with ALL 4 speakers, the possibility of wiring fault is also unlikely. The likely possibility is that the connection for the Power or Ground connection is not proper, which can be checked by the service guys.
Go to a Blau dealer - they will oblige without any fuss normally - and ask them to check the HU connections for loose contact etc. They will also be able to demo the Blau amp (for example GTA4 Spl. MK II, 4channel, around 6K) and sub-woofer tube (for example GTt 300 HP, less than 5K) for you in the car. Take a decision to buy only after they check and tell you what is wrong. Just ignore statements like "purana ho gaya hai, isi liye dum nahin hai" (electronics is not like humans) and "the original speakers are anyway not powerful" (even fakes will play loud, albeit not good quality sound)
__________________
Old 17th January 2008, 12:01   #9 (permalink)
navin's Avatar
that is becuase they cant handle as much bass. i'd tell you experiment using bass blockers etc.. but I think you might as well get new speakers.
__________________
Scixelsyd Etinu
Old 17th January 2008, 12:12   #10 (permalink)
I think you are expecting to much for the HU amp. Try reducing the low freq, bass boost if any for the HU. And check out the result.
Old 17th January 2008, 12:40   #11 (permalink)
Yes, the problem is with both sources, FM and CD. However will check and revert on this.
No, the Mute button is not on! However, I couldn't locate the ATT button or its settings (the one that suppresses the sound for sometime during a phone call). I suspect it might be the culprit.
Even I was surprised by this behavior of the HU. I had Pioneer DEH-7850MP on my Indica, and it gave out amazing sound at volume 9-10 also! I couldn't go beyond 17-18 in normal drives because sound was already loud enough - even though the max vol setting was 40 on that HU. And I didn't have any SW or Amp on my car. Just 2 rear and 2 front speakers!
Thanks for your advice. Will fish out Blau service center details.
Old 17th January 2008, 12:48   #12 (permalink)
Hi LBM,
Actually, my previous ICE setup on Indica was as follows:
- HU: Pioneer DEH-7850MP
- Rear: Pioneer TSA 6981 6x9 oval speakers
- Front: Kenwood (Dont remember the model no.) fitted in the dashboard.
- No amplifier or subwoofer.
With this setup, I could get amazing bass and sound, even at 9-10 volume level of the HU. Infact, I could not go beyond vol 17-18 in normal driving, even though the max rated vol of the HU was 40! And all tones, sound etc was crystal clear even at lowest vol levels.
Hence, it was but natural for me to expect similar output from a similar ICE setup! However, I came out disappointed :-(
Old 19th January 2008, 19:15   #13 (permalink)
Unhappy
I got my "coughing" speakers checked by a car accessories guy in the Milan Subway market today. Without even listening to the sound, and just by looking at the speakers, he said that these are fake Pioneers
Apparently, the rear speaker grills were rusted. He says that original Pio speaker grills never rust. Also, the front speakers have been fitted into the door without their front grill. Only the OEM speaker grill has been fitted onto them. This is another sign that speakers are fake, according to the guy.
Anyways,I am now thinking of going for the following combo of speakers:
Rear: JBL GTO 937 6x9 3 way coax
Front: JBL GTO 637 (recommended by the installer as he says Getz can take 6 inch speakers in front. {I had suggested him GTO 537}). These would be 2 way coax.
The total price quoted by him is Rs 5800 (Rs 3400 for rear and Rs 2400 for front). Is it fine?
If I choose 3 way coax for front, the price would go up by Rs 1000.
As I am not too fond of loud music/deep bass, I dont want to go for an amp and/or SW right now.
Can someone suggest how the above speaker combo is?
Old 19th January 2008, 23:34   #14 (permalink)
It is nice combo. you can also try the JBL GT5 Series, Illusion Audio, Infinity also
Old 21st January 2008, 11:10   #15 (permalink)
Can some BHP guys recommend me a good installer in Mumbai? I am not very old to this city hence I don't know many shops around. I would prefer an installer who does a neat job, with good quality stuff and genuine equipment (cables etc)
Thanks a lot in advance!
Thread Tools
Imported ICE for GETZ CRDI Suresh_vin Ask the Gurus 3 7th October 2008 22:45
ICE upgrade for my Getz undead Ask the Gurus 18 15th September 2008 15:01
Suggestions for ICE upgrade - Getz PatienceWins Ask the Gurus 43 15th July 2008 17:56
ICE suggestions for the GETZ luvjascha Ask the Gurus 3 6th July 2008 12:43
ICE - Set Up Getz GVS cancerm Ask the Gurus 0 23rd October 2007 16:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
