Thread Tools
Old 20th January 2008, 18:44   #16 (permalink)
Gill's Avatar
Originally Posted by nitrous View Post
^^ Can U explain the importance of warranty while purchasing a sub?
What are u asking??????
Warranty matters irrespective of the product and most imp of all irrespective of price you pay.
It gets you piece of mind most imp of all......
@Sidhu Bai ji,check out JBL's latest series sub,very good for the thing your are looking for....
Plz if possible don't go for bass tube,rather buy a sub and get a ported box,amp you have shortlisted is great value for money!!!!!
Cheers!
__________________
Experience is the worst teacher; it gives the test before presenting the lesson.
Gill is offline   Reply With Quote
Old 21st January 2008, 00:06   #17 (permalink)
low_bass_makker's Avatar
Originally Posted by overdose14 View Post
and what are the options with ground zero which can be paired with kenwood amp
You can get a pair of GZ Radioactive subs.
:: Ground Zero :: Subwoofer / Basic Level
One thing I wanna mention here is that the SPL series sub is having the name SPL but it gives out some nice SQL also...
Old 21st January 2008, 01:31   #18 (permalink)
saintsinner's Avatar
get an amp from dubai, DON'T get a SUB, better options here. just get a mono amp.
__________________
2006 Accent GLE
2007 Scorpio 4X4
saintsinner is offline   Reply With Quote
Old 21st January 2008, 03:08   #19 (permalink)
overdose14's Avatar
thanks a lot,
i can't open up Ground Zero web page. i've been trying since last week.
guess BSNL broadband got some problem.
25 K will be enough for this sub and amp.??
__________________
"Holla ain't no stoppin' me
Copywritten so, don't copy me"
overdose14 is offline   Reply With Quote
Old 22nd January 2008, 08:10   #20 (permalink)
headers's Avatar
Nitrous..extremly simple to bust your sub..one wrong connection is all that is required!!
I think its extremely important to have a good install done by a pro and get good speakers with WARRANTY..
If you wanna play around..the option of going to the grey market is always open.
__________________
Walk the Talk..Always!
Old 23rd January 2008, 08:12   #21 (permalink)
overdose14's Avatar
@Gill shaab, JBL subs are nice but i want a sub which can be coupled up with Kenwood monoblock, now Ground Zero seems to be best option.
LBM pajji , how much these subs will cost me
__________________
Old 23rd January 2008, 09:26   #22 (permalink)
ScarySkulls's Avatar
If you are planing for a monoblock, then makes sense to go for a DVC Sub.
Because then only will you be able to down to 2Ohm or even lesser.
With an SVC, you will be stuck at 4ohm. But 9103 puts out 500WRMS @ 4ohms. Not too bad for all the Linkin Park Rock that you listen to.
Just for my info, Why exactly go for a monoblock?
Why not a better, cleaner sounding Amp for the front components first?
__________________
Punjabi for Life.
ScarySkulls is offline   Reply With Quote
Old 23rd January 2008, 09:33   #23 (permalink)
overdose14's Avatar
dude, i know all the ohm stuff, thats why i'm looking for compatible sub and i'll be getting another amp for components.but first i want to upgrade sub and amp, baas at higher volume is just not right. after rockford's pioneer sub is not doing justice to my setup.
__________________
Old 23rd January 2008, 09:45   #24 (permalink)
s0uljah's Avatar
In which case its up to the manufacturer whether they should honour the warranty or not. I doubt warranties provide for an imbecile carrying out the installation.
__________________
"Its not the size, its the heart, so dont hate... Accelerate !!!"
Old 23rd January 2008, 10:54   #25 (permalink)
Hmm.. here are the subs photo with there little specs and there prices choose your poison wisely.
diameter: 30 cm / 12"
power handling: 500 WRMS
impedance: 1x 3.8 ohm
voice coil: 50 mm / 2"
excursion: X max. 18 mm / 0.7"
resonance frequency: FS 30 Hz
SPL: 91,4 dB
Price 12k
impedance: 2x 3.8 ohm
resonance frequency: FS 29 Hz
SPL: 91,4 dB
Price 12k
power handling: 1.000 WRMS SPL Power
impedance: 2 x 2 ohm
voice coil: 63 mm / 2.5"
excursion: X max. 20 mm / 0.9"
resonance frequency: FS 33 Hz
SPL: 92 dB
Price 18k
Old 23rd January 2008, 17:50   #26 (permalink)
overdose14's Avatar
thanks a lot, pajji
and i wanted to ask that if we double the input power to a sub ( in case we are running it at half the rated power). how much overall gain will occur .
i don't expect output to double but still how much gain can i expect.
and how much difference does type of car body makes, like in case same setup is run in a suv and then in any small car.
__________________
Old 23rd January 2008, 19:30   #27 (permalink)
Mr. boombastic's Avatar
I'm no guru but i would agree with LBM, the GZ subs can go pretty low and also are quite reliable in terms of warranty issues
spl wise i would say they have u would have to listen to them to belive the amount of bass these subs produce along with the crisp punch they can deliver
make sure u get them installed from a reliable installer and do give importance to the enclosure as well
also keep an amount of ur budget aside for damping as well
Mr. boombastic is offline   Reply With Quote
Old 23rd January 2008, 23:31   #28 (permalink)
I think you are a GZ sub lover. and also you are new here. What setup are you using ?
Thread Tools
Replacement for Zen king_julian Hatchbacks 12 15th January 2008 15:34
Replacement for Palio psp62in Hatchbacks 50 11th December 2007 12:52
Battery Replacement... karthik247 Technical Stuff 72 26th June 2007 17:11
Replacement Filters: Yes or No? hyper-VTEC Technical Stuff 50 14th March 2007 00:01
2 Din replacement kb100 Ask the Gurus 6 2nd March 2006 11:06
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
