| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: May 2007 Location: Baroda
| What kind of cables/wires do i need to get for a simple setup consisting of a 60x4 or 75x4 RMS Amp and 4 speakers ? Someone's going to get them from USA for me and i need to specify exactly what i need. Is it okay to get them from crutchfield or are there other better sites ? Do i need to get both power cables and speaker wires ? Or is it better to use a power cable from finolex etc. ?
__________________ And Michael Schumacher is actually in a very good position to win the race. He is in last place. - Murray Walker |
| | #2 (permalink) |
| BHPian | If you have only one amp and 4 speakers then you will need a 8 gauge wiring kit and two pairs of RCA cables. You can look at brands such as audison, monster, scosche etc etc. If you have two amps then you will need a 4 gauge wiring kit.
__________________ She's back. |
| | #3 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: New Delhi
Infractions: 0/1 (4) | If you are bent on getting from US, get a decent 4 channel 4 gauge wiring kit, go for monster/scosche. You wont find good deals on crutchfield, try etronics. In case its same money - wise, next best option would be connection audison. (PM gunbir for details) power cable: finolex is good. no need to get from US.
__________________ SINGH IS KINNNNNNNG.. |
| | #5 (permalink) |
| Senior - BHPian Join Date: Sep 2005 Location: New Delhi
Infractions: 0/1 (4) | Let me try and clear this up... While finolex et al is great for budget installs, there IS a reason why specialized power cable exists for car audio. There ARE proven performance gains in using multi-stranded cables as they can flow larger amounts of current than the economical equivalent of the same gauge. Electricity travels on the outside of the conductor and NOT through it. Thats why the multi strand power cables for car audio contain more (sometimes twice or more) strands than a regular cable of the same gauge. Moreover the quality of copper in these cable is higher in quality cables over economy cables. Quality cables will be made from oxygen free copper which will ensure corrosion free connectivity and better transfer. And lastly, the flexibility of quality car audio cables is way ahead of household cable and in our small cars where space is aways at a premium, flexibility is an asset.
__________________ Often imitated, never duplicated! |
| | #6 (permalink) |
| I cant find any monster/audison wiring kits on either crutchfield or etronics. Any suggestions ?
| | #7 (permalink) |
| BHPian | try Car Audio Video - Car Subwoofers - Car Amplifiers and Speakers Also like Satya has mentioned look for Kicker. e2 E400 by Scosche - e2 400W Single Amplifier Wiring Kit • 6.5mm power/ground (equivalent in strands to most other "8 gauge" kits) • 17' Twisted Hex RCA Interconnec Cables • 17' power and ground - , Car Installation & Accessories, Amplifier Installat
__________________ She's back. Last edited by vikram_d : 21st January 2008 at 00:16. |
| | #8 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
Due to eddy currents produced by the main current, current density decreases exponentially from surface to core: J = Js * e^(-delta/d), where: J = current density at any depth 'delta' below surface Js = current density on the surface d = skin depth constant The skin depth constant is calculated as: d = √((2 * ρ)/(ω * μ)), where ρ = resistivity of conductor ω = angular frequency of current = 2π * frequency μ = absolute magnetic permeability of the conductor If one plugs in values, one finds that the skin depth is 8.57mm at 60Hz, 0.66mm at 10Khz, 0.21mm at 100Khz, 0.066mm at 1MHz, 0.021mm at 10MHz, etc. Most significantly, for direct current (frequency = 0) the depth is infinity, i.e. the whole material conducts current. So, for the power cables, whether one puts Kicker or Scosche or Finolex or even a solid copper bus bar, it is one and the same. For speaker cables and shielded signal cables the scene would be different, but only to a very limited extent depending on the range of frequencies to be transported. Let us gun for the 100KHz range to take care of all possible harmonics in the signal. Definitely (n strands of 0.21mm) will be better than (n/3 strands of 0.66mm). Not sure if the wire specs are written precisely on the package of the cable set. So, perhaps someone can take a micrometer and compare the strand composition of the different brands? IMHO, the cable sets are for convenience and the brand carries a mystique; but quite definitely the same cables would be available with Indian brands.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! Last edited by DerAlte : 21st January 2008 at 10:49. | |
| | #9 (permalink) |
| Senior - BHPian | Thank you Deralte for the same. I would have written the same but without any equations and other minor details. The current is passed through the conductor and not through the surface. Rest about detailed comparison of Branded Car audio cable and finolex coming up in few mins. |
| | #10 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
The real advantage multi-strand POWER cables offer over solid core is flexibility. Multi strand cables can be laid more easily than a bus-bar.
__________________ Scixelsyd Etinu | |
| | #13 (permalink) |
| Senior - BHPian | Have used upto 25sq mm finolex in most of my friends setups with great success. Its not as flexible but hey when your saving $$$$ why not. Extra money was spent on RCA's and speaker cable ![]()
__________________ "Its not the size, its the heart, so dont hate... Accelerate !!!" |
| | #14 (permalink) |
| BHPian Join Date: Jan 2008 Location: Mumbai
| I have a similar query. I need to know which all cables/wires would I need to tell the installer for this setup: A simple setup consisting of a HU and 4 speakers ? Which brands (Indian/Phoren?) and at what price? |
| | #15 (permalink) |
| Senior - BHPian | Ok took out few of my instruments and did some measuring. Test was a comparison of two different wires. 1) normal household 25 mmsq wire. 2) good car audio cable 4 awg. Cross section area. I took both the wires cut is about 3 inches to make the inside copper visible . I used a 1 micron Mitutoyo micrometer for the same to get accurate result. Few pics before the calculation part. The normal house hold wire ![]() The Good car audio cable. ![]() Ok in the house hold wire had 158 strands. The diameter of each wire strand is 0.44 mm so the section area comes to. 0.44 / 2 = 0.22 (radius) 0.22 x 0.22 x 3.14 = 0.152 (section area of one strand in mmsq) 0.152 x 158 = 24.016 mmsq So the normal house hold wire company fall short by approx 1 mmsq from what they claim it to be so it is less than 1 % short. Now comes the The Good car audio cable, it has total of 1078 strands and the diameter of each strand of 0.15 mm so the section area comes to. 0.15 / 2 = 0.075 (radius) 0.075 x 0.075 x 3.14 = 0.0176 (section area of one strand in mmsq) 0.0176 x 1078 = 19.04 mmsq Energy solutions - Metric Cable size to AWG Conversion Normally if we take 4 awg wire it is compared to 25 mmsq indian wire so we are 6 mmsq short that is nearly 25 % less. But according to the American standard it is 21.3 mmsq so we are approx 9 % short still. Now comes the flexibility part. The pic first. ![]() Both the cables are flexible but the Car audio is a bit more. But I dont think the normal house hold wire is quite flexible for the job of car audio install IMHO. The outer sheath of the car audio cable is soft to keep it flexible but the normal home hold wire was a little hard not easy to cut also, which I will take as a good thing. The outside diameter of the household wire is 11.1 mm and that of the caraudio wala was of 10.5 mm. It show that the insulation is thicker in the case of caraudio wala cable. The cost of the House hold wire is approx 125 per meter. And that of the Good car audio cable is 650 per meter. Do the maths which is better. So finally I would recommend the normal household cable for the power wiring of the amp any day. For speaker and RCA get good brands as they directly affect the SQ. About the copper purity test can be done of both the wires If the users of the forum encourage me to do that. |
| Thread Tools | |
Similar Threads | ||||
| cables & stuff in Kolkata | DjNik | Product Discussions | 1 | 12th October 2008 15:12 |
| Jump start cables in Bangalore? | kumar2007 | Modifications & Accessories | 3 | 9th October 2007 11:02 |
| Efx Cables | shadyrulez | Product Discussions | 18 | 7th October 2007 12:27 |
| DIY Interconnect cables. need help. | clipto333 | DIY - Do it yourself | 15 | 30th July 2007 17:45 |
| Malfunctioning cables, help | honda_dude | Modifications & Accessories | 1 | 12th March 2007 18:09 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
