Thread Tools
Old 15th September 2008, 22:15   #136 (permalink)
HotChillyPepper's Avatar
Just for your info: Maxtor Basics 120GB will work with 6050UI. This is the cheapest HDD with enclosure (Factory assembled) I could find which will work with 6050. Otherwise I have tried 2 local cases with Hitachi HDD was not working with the HU
__________________
Optra Magnum 2.0 TCDi
Chevy Spark LS
Hero Honda Karizma 225
I will never be provoked on road, no matter how hard they try.
HotChillyPepper is offline   Reply With Quote
Old 15th September 2008, 23:20   #137 (permalink)
vebmetal's Avatar
^awesome, thanks for letting us know. By any chance could you give a product link?
__________________
In memoriam: My Signature.
Censorship 01 Vebmetal 00
vebmetal is offline   Reply With Quote
Old 16th September 2008, 00:06   #138 (permalink)
FeelTheBass's Avatar
Hi!! HotChilly!! Thanks!! for the info. i've always been thinking if i could attach a HDD with my 6050.
What about the specifications of this HDD? do they differ from other HDD Brands?
__________________
~~ Feel The Bass ~~
FeelTheBass is offline   Reply With Quote
Old 16th September 2008, 08:20   #139 (permalink)
Here you go: eBay India: Seagate Maxtor 120 GB Mini USB External Hard Disk 120GB (item 310077409719 end time 21-Sep-2008 21:38:49 IST)
But note that here in Bangalore eZone you will get it for 2990 bugs. It comes with 3 years company Warranty. So better try in your local stores for a better price. In Nehru place Computer Empire will have this stuff in stock
Originally Posted by FeelTheBass View Post
Hi!! HotChilly!! Thanks!! for the info. I've always been thinking if i could attach a HDD with my 6050.
Yes you can. I am using it for the last one month. I could carry 20GB of music in more than 300 folders.
As far as specifications concerned, you should look out for the rated current of HDD. it should be around 400mA, so including the case electronics it will come below 500mA(USB2.0 Spec ). But practically many drives with the above spec will not work with 6050, I suspect the IDE to USB converter consuming huge power and hence the total power required for the setup exceeds 500mA. I personally tried Hitachi , Toshiba and Samsung drives with different local 2.5" HDD casings(Advik and Supercomp). Both were giving a Error 22 , Error 11 or USB N/A on 6050.
So I believe its not only just the HDD, but the Electronics too will make a difference. I haven't tried any factory built HDD portable drives other than Maxtor Basics 120GB, as my first try itself with this setup as successful.
You will have to format the Maxtor Basics 120 with any HDD partition tools available on net to FAT32 before copying files. By default it is NTFS formatted from factory and will not work with your HU. Let me know in case anyone required some help in preparing the drive. Also its better (not mandatory)to run a defragment utility on the HDD after copying all files, especially if you copied more than one folder at the same time, this will make a difference. This will help the HU to find out files faster and lesser seek time.
__________________
Chevy Spark LS
Old 17th September 2008, 17:04   #140 (permalink)
Hi! HotChilly!! bro. Thanks!! a lot for such a valuable information from your side. I've always been thinking if we could hookup a HDD with my 6050. You are of great help. thanks!! again.
__________________
~~ Feel The Bass ~~
Old 18th September 2008, 00:06   #141 (permalink)
vebmetal's Avatar
This would be beautiful with a Parrot Rk8200. Keed the HDD in the cave/pocket and forget about it.
btw anyone know if the new SSD (solid state (?)) hard drives work with HUs? I would guess they need less power.
__________________
Old 18th September 2008, 00:39   #142 (permalink)
But they are bloody expensive right now..
Old 6th December 2008, 08:54   #143 (permalink)
tez
tez's Avatar
hi everybody,
if we plan to get Pioneer 5000UB from US, will it be playable in india? I dont know if there are any US specific encoding being done and also the voltage and current specifications. It is available for 119 USD from amazon which comes out to around 5600 INR? Kindly advise
tez is offline   Reply With Quote
Old 6th December 2008, 08:58   #144 (permalink)
greenhorn's Avatar
5050 costs the same if not lesser in grey here
__________________
'07 Indica DLG - Almost a DLX
Old 6th December 2008, 09:38   #145 (permalink)
karankapoor's Avatar
don't buy it in US,you can buy it here for around 6.2/6.4k in india in grey and with bill it will cost you around 8k with 2 years warranty.
__________________
P80RSII l ID Chameleon's l Genesis Dual Mono l ID Max l Genesis Dual Mono EXtreme l Kicker l Connection Audison l Dynamat
karankapoor is offline   Reply With Quote
Old 6th December 2008, 09:47   #146 (permalink)
tez
tez's Avatar
thanks greenhorn and karan for the response. Is there a specific reason i should not get it from US as in would i face problems in installation or wiring etc? I am getting 6000 series in 8k hence i am getting tempted. Also please advice on Clarion DXZ385USB HU?
Old 6th December 2008, 10:00   #147 (permalink)
greenhorn's Avatar
since the same thing is available for about the same price locally, it would be easier, and you don't have to bother, especially with the customs etc, and buying it locally would be easier.
If you want to buy another HU, lets not go off topic here. there may be existing threads, or start a new thread for your requirements
__________________
Old 6th December 2008, 11:14   #148 (permalink)
tez
tez's Avatar
thanks greenhorn. I have dropped the idea of getting this HU from US. i rather buy it here.
Old 18th January 2009, 13:44   #149 (permalink)
Default Deh-4250sd
Anybody has tried DEH-4250SD DEH-4150SD
I checked in grey market(Bangalore), they are offering it for around 6K.
Any reviews on this?
Hemanth HG
hemanth.hg is offline   Reply With Quote
Old 18th January 2009, 20:33   #150 (permalink)
ascertain's Avatar
Lightbulb Nothing special
There's nothing special about clarion drives as far as playback is concerned (the name Clarion gives a rosy picture doesn't it?). Me and my brother (who is a pretty good auditioner) have listened to quite a few HU's, and feel that quality wise Eclipse>Alpine>Kenwood=pioneer=clarion>Sony. Of course clarion has some innovative products like the DMR's (Digital media receivers), which are only solid state memory based (Less maintenance- no moving parts), and also look neat , but SQ is not as great as the eclipse. If you are looking at those 3 pioneer HUs mentioned on the thread then 6050 is it.
ascertain is offline   Reply With Quote
Thread Tools
Pioneer DVH-4050 Divx File Play ganesh_bbr Product Discussions 0 12th July 2009 19:14
List Button Wouldn't Show Album In Alphabetical Order In Pioneer 5050,6050. FeelTheBass Ask the Gurus 20 24th March 2009 11:55
Peculiar problem With HU (Pioneer 6050 ) sandeep3in Ask the Gurus 18 11th October 2008 17:20
Pioneer 4050 HU subdrive gauravsinha Ask the Gurus 5 30th September 2008 21:28
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599
