Thread Tools
Old 24th August 2009, 23:55   #166 (permalink)
DerAlte's Avatar
Ouch! Is it this model? It is Focal econo-model alright. Where did you get it from? I guess you didn't get a chance to check other models and prices before you purchased it.
Looks odd though. If it is meant for mounting at a 4" location, then the cone is just too small as compared to other 4" (JBL, Blau, Illusion, Pio, Sony etc.). No wonder it is tinny, apart from being bright.
If reducing treble at the HU does not help, nothing will. The unit is too small to safely do any modifications (like adding a resistor in series with it's tweeter). Better go back to your installer and get it changed. If that doesn't work, try sticking a layer of thick curtain cloth over the speaker (or behind the grill) to reduce the high frequencies
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 25th August 2009, 16:43   #167 (permalink)
Yes, it the same. I got it installed from Technokrat chennai. You are correct, I didn't get a chance to check other models. I was looking for JBL, but he doesn't deal JBL.
I will try covering with some thick cloth, and will post.
Thanks for your help.
swageo is offline   Reply With Quote
Old 27th August 2009, 01:08   #168 (permalink)
Originally Posted by sirajbose View Post
Guys - any comments from any Verna owners regarding the proper fit into the dashboard?
Thanks!
Couple of questions though - I have a Verna and have just got the 6050 fitted, however it kind of protudes out slightly and leaves a minimal gap from the sides (I shall post pics tomorrow). The installer claims that as the dash of the Verna is tilted towards the driver, there cannot be a perfect fit - What I wanted to know is - is this true and is there a solution.
Thanks!
Uploading the pic. Please note the ugly gap which exists as the HU is slightly protuding from the dash (the gap is on top as well). If I fit the HU completely inside the dash, the outer ring does not fit. The installer claims that this is because of the design of the Verna's dash - Suggestions welcome.
__________________
2008 - Verna CRDI SX w/ ABS
2004 - Santro Xing XS - 50000 Kms - Now Sold
2001 - Maruti 800 MPFI (5 Gears) - 60000 Kms - Now Sold
sirajbose is offline   Reply With Quote
Old 27th August 2009, 11:06   #169 (permalink)
shreyasma's Avatar
Sir, is your HU fitted with help of the DIN sleeve??
In Verna, the console has to be removed and the HU screwed in place like most double din ones.
__________________
Cheers!
Shreyas
"Two Wrongs don't make a Right, but three Rights make a Left!"
shreyasma is online now   Reply With Quote
Old 28th August 2009, 10:13   #170 (permalink)
Yes, the console was removed and the HU was fitted onto a bracket (sleeve I guess) which was then screwed back into the console area (it has preexisting holes for the screws - post which the center console (the one with the AC vents and wooden finish) was put back on.
__________________
Old 23rd September 2009, 15:35   #171 (permalink)
Approximate prices of Pioneer HU in bangalore - Pio 5050 and 6050
praveen4554 is offline   Reply With Quote
Old 16th October 2009, 02:29   #172 (permalink)
tsk13's Avatar
I'm in process of buying Pioneer 6050 from the Grey Market and have been quoted Rs.7500 for the same. I was interested in the 7150 but it's not available in the grey market now and features wise both are same but 7150 when available retailed for 8.5k.
Now the main question, is there any problem with the motorised slide mechanism or any other issues with the 6050?
tsk13 is offline   Reply With Quote
Old 16th October 2009, 08:14   #173 (permalink)
I bought 5050 last month for INR 6400 and 6050 was quoted 8500.
mjkaushal is offline   Reply With Quote
Old 16th October 2009, 09:28   #174 (permalink)
gaurav_chopra04's Avatar
Why go for products from grey market. I know it saves some money (about 2k I guess) but, consider this case. Your lens gets a bit dirty and CD starts skipping. It did in my case (I have a DEH5990, 2007 model). You will go to a person who repairs head units and say, the cd is skipping, He will open your head unit and charge you around 1200 for the new lens and about 2-300 labour.
Since I had warrenty, I called up at the service station, the service engineer came to my place, took the head unit to the service station, called me up and informed that lens got a bit dirty, so serviced it completely and delivered it back to my place in 2 days. Now its been almost 8-9 months since I got the headset serviced and its playing absolutely fine. Even with the case of lens or any other part going fauly, they would have replaced it without any charge. I was not charged even a single penny for the service.
I must say the service I got for paying around 1.4k extra at the time of purchasing was amazing.
If you go for the headunit with motorised pannel, you have another reason to buy it under warrenty. the pioneer headsets are very reliable but afterall its machinery!
__________________
Some People Drive just to get to their Destinations.... Others Drive MITSUBISHI!!!
gaurav_chopra04 is offline   Reply With Quote
Old 16th October 2009, 14:42   #175 (permalink)
tsk13's Avatar
Thanks Gaurav. My experience with Grey market has always been superb, I never came across any problems with my purchases. Moreover, 6050 single din has been discontinued officially so Grey market is the only option now. The the 7150, which is the same as 6050 when it comes to features retails for around 14k with B&W, which is almost the double the rate at which I'm getting 6050 for.
Old 16th October 2009, 18:36   #176 (permalink)
ariendj's Avatar
i got the 6050 for 8k some 10 months back and it works like a charm..
and i got it in grey too..no issues yet..
__________________
im fiesta-ing my life!!
ariendj is online now   Reply With Quote
Old 16th October 2009, 20:03   #177 (permalink)
tsk13's Avatar
Thanks for valuable input. Nice that the set is working fine.
Old 29th October 2009, 16:56   #178 (permalink)
addyhemmige's Avatar
Hi guys, I need some advice out here.
I have a Pioneer DEH-5090UB installed in my Swift for the past year and I am happy with its performance. I have installed JBL component speakers in the front and Boston 6X9 co-axials at the rear.
One of my uncles in the US is coming down to India and is getting a HU for his car here. He has also got one for my dad for his Innova.
He has bought a HU from a brand called DP Audio. The model number is DP312B. The specifications are as below.
3" Wide Screen In-Dash DVD Player
Specifications
* 3” Wide screen In-Dash DVD Player
* Built-In Bluetooth with A2DP Wireless Music Playback
* DVD Player supports DVD-R, VCD, MP3, JPG, WMA, CD, and much more
* Dlink cable included to connect MP3/MP4 player
* USB and AUX Inputs on front of unit
* 3-RCA Pre-Outs including Front, Rear and Subwoofer
* High Power 75W x 4
* Backup Camera Ready
* Fully Detachable Face with carrying case
* Full Function Remote Control Included
* Piano Black finish
DPAudioVideo - Products
My dilemma is that the specifications are better than what my current HU has. So, I thought of replacing my HU with the new one and install the old one in my dad's Innova. But, I had never heard about this brand until now. Has anybody heard about this brand?
Would you guys advise me to stay put or go for the change?
I am tempted to change since it has a DVD player, a 3 inch screen, Bluetooth etc which is not there in my old HU. My only grouse as of now, is the absence of a hidden USB port. It looks odd poking in the Flash drive in front of the HU.
__________________
"There are some things money can't buy, for everything else, my salary isn't sufficient!!!"
Swift DDiS 2008
Suzuki Fiero 2001
addyhemmige is offline   Reply With Quote
Old 2nd November 2009, 16:28   #179 (permalink)
Unhappy Hullooo!!!
Can somebody help me out???
__________________
Swift DDiS 2008
Suzuki Fiero 2001
Old 2nd November 2009, 18:09   #180 (permalink)
Specs look good! I had bought an AudioVox with bluetooth et. al. at a sale in US 6 months back and its been working very well - no issue so far. It suits my requirements. I must also add that AudioVox is somewhat known- nowhere close to Pio though. I havent heard of DP Audio so cant comment.
~maniac
__________________
Gravity is a myth, the Earth sucks.
serious_maniac is offline   Reply With Quote
Thread Tools
Pioneer DVH-4050 Divx File Play ganesh_bbr Product Discussions 0 12th July 2009 19:14
List Button Wouldn't Show Album In Alphabetical Order In Pioneer 5050,6050. FeelTheBass Ask the Gurus 20 24th March 2009 11:55
Peculiar problem With HU (Pioneer 6050 ) sandeep3in Ask the Gurus 18 11th October 2008 17:20
Pioneer 4050 HU subdrive gauravsinha Ask the Gurus 5 30th September 2008 21:28
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
