Thread Tools
Old 25th January 2008, 12:05   #16 (permalink)
Mr. boombastic's Avatar
Originally Posted by maverickzCar View Post
A slightly technical question:
How does RMS Power output and Peak power output affects the Sound Quality with same set of speakers?? I have 6" front components and rear 6x9 on tray and going to change my HU. There are no amps or subwoofer and no plans to add one sometime soon.
The current one, Pioneer 7950 has RMS PO as 22 W and Peak PO as 50 W.
The new one that am aiming for, Alpine 9887 OR Blau MP57, has following specs:
Alpine 9887--
RMS - 18 W
Peak - 50 W
Blau Hamburg MP57--
RMS- 25 W
Peak- 45 W
Does this mean that due to lower Peak power output, Blau MP57 will not be able to drive the current set of speakers that well?
Or, in another case, due to lower RMS PO, Alpine 9887 will face same problem?
Can anyone show some light on importance of these factors (RMS and Peak PO) on the sound quality and how does it affects the overall audio feel (for 2 compos and 2 tray oval speakers and nothing else to drive)...
Program power is the maximum power that a speaker can handle over a reasonably long period of time when driven with program material i.e. regular music, while rms is the measurement done in the lab or factory where the speaker is tested over a long term using a test signal comprising of the whole band of frequencies the speaker is supposed to produce and not music (which contains only part of the band at any given point of time).
Note from Moderator: Kindly avoid using [FONT] [COLOUR] tags
Mr. boombastic is offline   Reply With Quote
Old 25th January 2008, 17:27   #17 (permalink)
DRAGONLORD's Avatar
Compenents need and amp for best output and INMHO and the pio 7950 has 3 RCA preouts !!! So, i suggest you get a good 4 channel or two 2 channels, if budget constraints, get a 2 channel now for the components and upgrade later with another 2 channel for the rear speakers.
Then next if you wish u can add an amp and sub next.
3 RCA preouts perfect for upgrades !
__________________
Don't drink and drive, for you may spill your drink !!!
DRAGONLORD is offline   Reply With Quote
Thread Tools
Pikes Peak but no challenge 1100D Travelogues 17 7th September 2007 12:49
Need of new car Vs Peak Oil. subscrive Hatchbacks 3 25th July 2007 15:52
TheLoudest.com speakers - 350W RMS!!! gopz Product Discussions 16 13th July 2007 19:09
If my front compos were 100 rms each, what rms amp do I need? wannabelean Ask the Gurus 18 17th August 2006 12:01
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
