Thread Tools
Old 31st January 2008, 18:53   #1 (permalink)
Default Suggestion for my Music system for Santro Xing
I am Sunil.I have a santro xing model car for which i have connected the following.
Head unit-Sony 460us
Front Speakers-Sony round(ordinary)
Rear Speakers-JBL GTO 937
Amplifer-Sony 554ZR
Subwoofer-JBL CS1004T
I have connected the amp to the rear speakers and the Subwoofer.
I am also planning to replace the amp with JBL CS60.4.Please suggest me whether i should replace the amp i have(Grey market one) or continue with the same.Is the amplifer 554ZR capable of driving the Subwoofer and the rear speakers.People tell that the head lights get dimmed due to the subwoofer.Is it true.Please give me your valuable suggestion.
linusk is offline   Reply With Quote
Old 31st January 2008, 21:07   #2 (permalink)
jkdas's Avatar
Welcome to TBHP
60.4 is a good choice.
You can start from here
http://www.team-bhp.com/forum/ask-gu...k-25k-30k.html (basic ICE - systems at various budgets -10K, 15K, 20K, 25K & 30K)
jkdas is online now   Reply With Quote
Old 31st January 2008, 22:24   #3 (permalink)
Thanx for your reply,
will this 60.4 be capable of driving the rear speakers and the CS1004T subwoofer.
Sunil
Old 1st February 2008, 03:27   #4 (permalink)
saintsinner's Avatar
60.4 would be perfect, bridged.
go for regular co axials JBL speakers in the front.
937 at the rear are fine. powered from the amp.
would also advice a pioneer HU
__________________
2006 Accent GLE
2007 Scorpio 4X4
saintsinner is offline   Reply With Quote
Old 23rd March 2008, 21:17   #5 (permalink)
Thanx for the reply. I have installed the cs60.4 amp for my car. You have suggested for the Pioneer head unit. Please tell me the model of the Pioneer Head unit which will be able to drive my tweeters, 4 speakers and the subwoofer.
Sunil.k
Note from Mod - Please leave spaces after using a punctuation mark to ease readability. If you wish to discuss this, look here > http://www.team-bhp.com/forum/shifti...tml#post715293 (A YetiGuide® : How To Post In Proper English) . Thanks.
Last edited by Rehaan : 23rd March 2008 at 23:46. Reason: Please see note in post.
Old 24th March 2008, 12:50   #6 (permalink)
i would suggest the pio 5050 or the 6050 if it falls in your budget. chuck the tweeters, power front co axs from the HU, rear speakers and sub from the amp.
__________________
2006 Accent GLE
2007 Scorpio 4X4
Old 24th March 2008, 23:02   #7 (permalink)
Thank You sir for your reply.
Old 25th March 2008, 00:45   #8 (permalink)
amit_mechengg's Avatar
Amplifer-Sony 554ZR
120% u have to change ur amp if u want the potential of ur jbl sub. i was running with the same sony 2 channel amp. sony amp is very weak 130 watts rms is not enough. get rid of the amp.try out if u get a jbl 75.4. u can use them for rear gto937 and the sub. its an amazing amp.
__________________
" I dont Drive Fast , I Fly Slowly "
amit_mechengg is online now   Reply With Quote
Old 25th March 2008, 06:38   #9 (permalink)
Amit, he has got a 60.4
the sony is not so bad. it used to power my 306DVC.now it just powers the comps and rear speakers now.
__________________
2006 Accent GLE
2007 Scorpio 4X4
Old 25th March 2008, 09:49   #10 (permalink)
karanraheja's Avatar
Is Pioneer 5050 really good? I like the Pio 6050 but its doesnt fit into my budget
__________________
Remember that nobody will ever get ahead of you as long as he is kicking you in the seat of the pants.
karanraheja is offline   Reply With Quote
Old 26th March 2008, 22:59   #11 (permalink)
I checked with the car accessories shop here.They have Pioneer 3090 and the pioneer 5090.How are these and what is your opinion on Sony 460us.The vendors also told me to add a adapter to the sony 460us because it does not have the sub output.What actually is this adapter.One vendor also suggested me to exchange the Sony 460us with pioneer 5090 for Rs 4500.Should i go for the exchange.Pls advice.
Old 12th April 2008, 21:38   #12 (permalink)
This is in continuation of my previous mails.I have added a Scosche SLC4 converter as per the advice of my installer. for my audio system as the system i have did not have Pre amp outputs.After adding this the quality of the rear speaker has improved but the front speakers and the tweeters are not getting any signal.Without sound from the front listening to music is very boring.What should i do to come out of this problem.Please advice me.
Old 12th April 2008, 23:37   #13 (permalink)
Old 13th April 2008, 12:10   #14 (permalink)
DerAlte's Avatar
...I have added a Scosche SLC4 converter as per the advice of my installer. ... quality of the rear speaker has improved but the front speakers and the tweeters are not getting any signal...
Difficult to imagine how you have connected the different parts of the system, other than assuming that both the front and rear speaker outputs of the HU has been wired to the Scosche converter box. Let me hazard a guess:
* You have connected one pair of amp channels to the 937 (rear) and the other pair bridged to the sub
* Your fronts speaker are connected to the HU
* Or have the front speakers been disconnected after the Scosche box was connected??? Is that what you are trying to say???
If so, do the following:
1. Connect the 'front' RCA (corresponding to the front speaker connection of the Scosche box) to the 'front' channel input pair of the amp. Connect the front components to the 'front' channels of the amp
2. Connect the rear 937s to the HU. Yes, right in parallel with the Scosche box
3. Connect the 'rear' RCA to the 'rear' channel input pair, and the sub to the bridged 'rear' outputs
4. Reduce amp gains to 0. Keep HU volume to normal listening volume, and gradually shift Fader to Rear, till the 937s are giving decent output. If needed, Increase HU volume till you are satisfied for the rear seat
5. Increase the 'front' channel gain till, sitting in the front seat the front volume is slightly higher than the rear
6. Now increase the 'rear' channel gain till you get your desired level of bass thump
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 13th April 2008, 12:15   #15 (permalink)
sonic_boom's Avatar
I thought the 460us had 2 preamp outputs... Refer to the following link.
460 specs
__________________
If 10% of road accidents are due to drunken driving then 90% of accidents are due to driving without drinking...Hmmm...
sonic_boom is offline   Reply With Quote
Thread Tools
One question about tyres of Old Santro and New Santro Xing DDGuy Tyre & Alloy wheel Section 5 12th November 2008 13:35
Suggestion with my Old Audio System into new car mezereo Ask the Gurus 4 29th March 2008 02:49
Security system for Santro Xing GoneIn60Seconds Technical Stuff 3 2nd April 2007 11:35
Suggestion for new car Audio System jinu_joseph Ask the Gurus 358 25th September 2006 22:53
Suggestion + Upgrade my system smreddy Ask the Gurus 16 10th July 2006 15:30
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
