Thread Tools
Old 2nd February 2008, 07:53   #1 (permalink)
nikunj_cal's Avatar
Default Rear Speaker suggestions please !!
Existing Setup for my Swift DDiS:-
Pioneer 7950 UB
Front JBL GTO 6" Coaxials
Rear Pioneer 6"X9" 5 way TS 6991S ( I Think).
JBL CS 60.4 amp
Power Cabling
The 6"X9" have started creating problems. The left speakers has conked out . I am thinking of replacing them with either
1)new pair of 6" x 9"s(Budget4.5k)or
2)coaxials + subwoofer(Budget 7 k).
If I take the first option then should i go for JBL or illusions ? Which of the two has a better bass response.
If I go for the second option then which brands do i go for and can i put the rear coaxials in the rear doors and a sub to the rear mdf tray ? I want to keep the boot free if possible.Or it is possible all the three at the tray cause i have heard that the rear door become heavy with the speakers fitted in and thus starts creating problems after a span of time.
Went through some threads but could not find any to my liking. A redirection to any thread having a similar type of problem will also help.
__________________
RIP, RIP, RIP AND AWAY.................
nikunj_cal is offline   Reply With Quote
Old 2nd February 2008, 08:38   #2 (permalink)
jkdas's Avatar
Get a co-ax that fits in the door and a bass tube . Even a sub in a ported/sealed box would do. A Pio sub in a custom box would be cheaper.
__________________
"She may not look like much, but she's got it where it counts, kid."
Old 3rd February 2008, 08:41   #3 (permalink)
nikunj_cal's Avatar
Bass tube , wont that permanently occupy boot space ? Instead putting a subwoofer on the mdf board rather than a sealed enclosure provide decent enough bass ?
__________________
Old 3rd February 2008, 09:54   #4 (permalink)
vebmetal's Avatar
The gurus here will get you better advice, but I would be a little hesitant in fixing a free-air sub on a MDF board, unless it's done by a very good installer. Otherwise it just leaves too much margin for rattles and other undesirable noises.
If you want boot space, a sealed enclosure would probably be your best bet, as it takes less space to begin with. On top of that if you get this particular connection jack (can't remember the name, others please help), you can disconnect and remove it with ease, say when you have to go pick someone up from the airport.
AFAIK Bass tube is more permanent and not so easy to remove.
__________________
People who talk in metaphors ought to shampoo my crotch.
-Jack Nicholson
As Good as It Gets (1997)
vebmetal is offline   Reply With Quote
Old 3rd February 2008, 12:09   #5 (permalink)
Magma's Avatar
dear nikunj
since you are using front JBL's
it would be a natural progression that you use the JBL GTO937 6*9's in the rear
they are available in your specified budget with bill or rs 2800 (grey)
illusion rear ovals speakers are very crisp and laid back,
if you want more dynamic sounding "ground zero" 6*9 GZ MK2 at about the same value are very good too IMHO)
the ground zero 6*9's offer such good tight bass IMO ( that you may even skip a sub if you like )
however if you want a budget sub you should see if an 8" free air sub can be squeezed in ur MDF tray between ur 6*9 rear coaxials
10inch or 12in would be a real difficult fit on MDF tray in a swift
__________________
An expert is someone who takes a subject you understand and makes it sound confusing.
Magma is offline   Reply With Quote
Old 3rd February 2008, 19:21   #6 (permalink)
Get the JBL GTO937 6*9 to replace your Pioneers and then decide.
__________________
Proxima
2004 Safari LX
2008 Pulsar 180
Proxima is offline   Reply With Quote
Old 4th February 2008, 11:07   #7 (permalink)
nikunj_cal's Avatar
@magama - where can I source ground zero speakers and can you tell me the exact model number ? I am getting a quote of rs 4950 for JBL GTO937 with b/w , isnt that a bit on the high side ?
__________________
Old 4th February 2008, 11:16   #8 (permalink)
shuvd's Avatar
Nikunj, PM Ajay ji (B&T) for GZ. You can also ask Shuvc for Ajay ji's email address.
__________________
I (still) feel the need...the NEED for SPEED
shuvd is offline   Reply With Quote
Old 4th February 2008, 13:21   #9 (permalink)
Magma's Avatar
well 4950rs is also the price for the ground zero speakers GZTF 690 MK2
as suggested above, contact Mr Ajay ( he is known as "Bass&Trouble" on this forum - search for his posts and PM him to know which shop you can get it from)
now the JBL GTO937 are also 4950 mrp . however a disount of 10% shud be possible on bargainin ( you can contact SAM Kapasi on this forum for JBL speakers, mumbai "lamington road gives these disounts)
However you should know you can get the same JBL speakers for about 2800-3000 rs WITHOUT BILL ( you choose ur risk)
Ground Zeros are not sold grey so dont ask!
__________________
Old 7th February 2008, 10:30   #10 (permalink)
Hi...
The gto 937 are too bright. IMO you should AVOID them.. ( P.S. They are available at 2800 Rs in mumbai with bill and warranty ) ..
I have heard the GZ MMK2 and they sound neat.. Hertz deici coaxes also have good reviews though i havent heard them personally..
I would put my money for GZ MMK2 ...
rahulv1 is offline   Reply With Quote
Thread Tools
Suggestions for Coaxial speaker & Basstube nosfreak Ask the Gurus 10 28th September 2007 13:27
Need help! No sound in one of the Rear Speaker! finneyp Ask the Gurus 11 23rd October 2006 14:04
Need help for my Santro rear speaker AdXing Ask the Gurus 126 9th September 2006 12:15
2004 Zen: Rear speaker placement sansjunk Ask the Gurus 4 8th March 2006 16:38
how is kicker rear speaker amit_sound Product Discussions 9 20th February 2006 12:37
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
