Thread Tools
Old 10th February 2008, 19:39   #1 (permalink)
manojgautham's Avatar
Default Urgent Help Required - Sub Enclosure
I have a TS-W304F Pioneer Sub. I used it with a large Band pass enclosure. One of the installation guy advised me to go for smaller Ported box and I opened and ruined my box. After putting it on a smaller ported box (2Cu ft) I have lost the punch in the sub. I anyway can't do anything about my older box, but have another box made.
Gurus: Please help me with the most suitable box for this sub. Size and drawing will be very helpful. If any of you are using this sub, please advice........
Thanks in advance,
Manoj
manojgautham is offline   Reply With Quote
Old 10th February 2008, 20:00   #2 (permalink)
Raxx's Avatar
hi manoj, as for as i know the TS-W304F sub is a free air one will perform better in a IB setup, gurus please correct me if i am wrong
Raxx is offline   Reply With Quote
Old 10th February 2008, 20:22   #3 (permalink)
DerAlte's Avatar
2 cft ported is NOT a small box. Also, the sub is a free-air sub so it would do best in an IB install (parcel tray in your WagonR). The bandpass box was a better option maybe - don't know where you got the dimensions, since you say the new ported box is smaller.
The specs page (Pioneer USA - Champion Series) says "Low-Q Design for use in Small Sealed Box (1.2 cubic foot recommended)" if you want a sealed box. The size of the ported box would also be close to it. The bandpass box would be at least 1.7 times that.
Since there are no T-S parameters mentioned in the product link, even LBM would not be able to design a box for you. Or, come to think of it, he just MIGHT have the T-S params or a suitable box recommendation.
The ported and the band-pass go louder watt for watt as compared to the sealed box, but do lack definition (part your "punch").
What amp are you driving it with? The specs say 300W nominal, 600W peak - so it would definitely warrant a good mono-block with a sealed box.
A quick and dirty solution would be to reduce the ported box's internal volume on an experimental basis. Simply add some bricks, check if the "punch" improves. At the point that the sound improves, count the bricks, subtract that from 2cft (if your ported box is indeed 2 cft - better double-check internal dimensions).
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 11th February 2008, 10:38   #4 (permalink)
Thanks, I would love to get a box designed by LBM I am running on GTA 480 amp with 2 chsnnel bridged to my sub. The output is supposed to be 75*4 RMS
Old 11th February 2008, 11:04   #5 (permalink)
navin's Avatar
I suspect that the ported box is not too small but too large for your needs. A smaller box would introduce a peak in the bass response and give you the punch you desire.
Manoj, there are a number of freeware softwares (Boxplot, Box design, etc...) that will calculate the optimum size of the box for you.
I suspect that the kick you expereinced from the band pass box was a "one-note" kick. This sort of kick sounds impressive at first and many even enjoy it but it is not an accurate representation of bass. Still if you do enjoy the added punch why not try reducing the internal volume of the box by adding a few bricks like suggested by Der Alte. If it helps, great. if not we will still be around to help.
__________________
Scixelsyd Etinu
Old 11th February 2008, 11:20   #6 (permalink)
low_bass_makker's Avatar
Here are the specs.
Rest coming up shortly
Old 11th February 2008, 15:08   #7 (permalink)
Thanks to all the Gurus to help me out with this. The problem is solved. I got back the same depth, in fact better depth. The box is 1.2 Cuft ported one and not 2
The problem was the RC output on the HU was loose, therefore the whining sound...... The guy just removed it and put it back and lo the sub started thundering again No whining now.....
Old 11th February 2008, 15:24   #8 (permalink)
Good to hear that your problem is solved.
Thread Tools
Urgent: Blood required at Delhi Joz Shifting gears 6 13th July 2007 18:10
urgent help required with spyware aadix Shifting gears 34 21st March 2007 21:38
Urgent Blood Required @ Chennai Psycho Shifting gears 2 14th March 2006 19:48
Help required on a used Palio 1.2... Urgent! extreme_torque The Indian Car Scene!! 13 6th February 2006 07:45
Laptop Problem...Urgent help required cooljay Gadgets, Computers & Software 15 27th November 2005 23:34
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
