| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Feb 2008 Location: HyderaGr8
| I was unable to find the answer to a few basic question in this forum, so here they are: (1) Which location is better (sound quality-wise) for rear speakers: the parcel tray or the rear door? wouldnt the door installation reduce or eliminate the stereo effect because the speakers face each other? same thing for the front speakers too: dash board or the front door? (2) Should a four way amp be connected to front or rear speakers (apart from the sub)? I hear divergent views on this though the majority favor the rear speakers. (3) I understand from a debate in this forum that Co-Axial speakers are better than component speakers for the rear. An outside source told me the opposite. which is correct. (4) Is it ok (sound quality-wise) to install the sub in the parcel tray (right in the middle, in between the 2 rear speakers)? |
| | #2 (permalink) | |
| BHPian | Quote:
I have the same set of questions but did want to put them till i think about an ICE upgrade. raj
__________________ ....HINDUISM ........JAINISM .......BUDDHISM ......SIKHISM ........ISLAM CHIRSTIANITY | |
| | #3 (permalink) | ||
| BHPian Join Date: Aug 2006 Location: New Delhi
| Quote:
Other ppl would be much better qualified to answer this, but from whatever I have read on this forum, there are two different types of subs. What you are talking about is the "free-air" sub which can be installed in the parcel tray, and is designed for such installation. But if you take a non-freeair sub and install it this way, you won't get good results - you will need an enclosure (box). For those you have two options - ported enclosures (with a hole, larger box, requires less power, but gives more boomy sound) and sealed enclosures (no hole, smaller box, requires more power, but gives much tighter bass).
__________________ In memoriam: My Signature. Censorship 01 Vebmetal 00 | ||
| | #4 (permalink) | |
| BHPian Join Date: Feb 2008 Location: Chennai
| Quote:
![]() 2. If you are driving and you have component speakers at the front, it's only sensible to power the front components with the amplifier. However if you sit at the back you can power the rear speakers. But the problem is it will look like the sound is coming from behind. So in any case i feel it's better to power the front components from the amp. In T-BHP everyone suggests this. Whos is this majority that favour the rear speakers?? 3.If you take them by the sound quality, components are better than the co-axials (and a little expensive too). The thing is that if you are driving and have the sub, then all you need is a speaker to fill the rear with sound. Also if you are using a four channel amplifier driving the front components and the sub, then the rear components will have to be powered by the HU and it is going to give poor performance. So it makes sense to choose the co-axials for the rear as fillers and powered by the HU. Hence the recommended setup is Front - Components Rear - Coaxials Boot - SUB Even if you dont have a sub, you need co-axials at the rear to get some bass into the system. But interms of performance components are better but if you consider the whole setup the co-axials are more effective. 4. If you want sound quality, then the sub needs to be in an enclosure. If you have a hatch, then the setup you mentioned, called Infinite baffle or IB, will give decent performance. But if you have a sedan then an enclosed sub in the boot will give much better sound. Again you need to choose between different types of enclosures according to how you would like your boom boom.
__________________ Anyone driving slower than you is an idiot, and anyone going faster than you is a maniac. ~Author Unknown | |
| | #5 (permalink) |
| Senior - BHPian | I think you've mostly got what you need to know My 2 cents:1) Speakers in Parcel tray vs. speakers in Rear-door I'd vote for the speakers in the door. If there is provision in the door, use the door. - Parcel trays rattle after a while, if the installation is not so good. - Rear-seat passengers will find the sound coming from their front more pleasing. They get a better soundstage, and you can play the speakers louder. - Better space utilisation. - You usually can install upto 6.5" speakers in the rear door (of cars with the provision). This size will be quite OK, as far as bass-support is concerned. (Considering the other advantages over parcel-tray mounting). You can put 6x9s in a parcel tray in the back, but I'd prefer the advantages of the door-location more. - The sound does not get pulled back much from the driver seat (the parcel tray is much farther away than the rear-door from the driver). 2) Amping front speakers vs. amping rear speakers Definitely amping the fronts. Especially if you have a sub in the back. If you amp the rears and the sub, all the power will go to the back of the car. You will have a very weak front-stage. Amping the fronts balances out the sub better. And amping the fronts will make them play much cleaner at medium-to-loud volumes. 3) Coaxials vs. Components in the rear Well, this is a factor of budget. And a factor of the next-best-way in which the saved funds can be utilised. Everybody agrees that comps sound better than coaxials. But they also cost about double the price of coaxials in the same range. For somebody who enjoys music from the driver's seat, the increase in sound quality in the rear (by paying double the cost of a coaxial) is usually not enough to warrant the extra expense. The amount saved by installing coaxials instead of comps would be spent better in damping the front doors. Or in going towards the budget for the next upgrade. 4) Sub in parcel-tray (free-air) vs. sub in box This is mostly a matter of taste and convenience. A sub in a parcel tray will sound quite different from a sub in a box. I personally prefer the response of a boxed sub. You will do good to check actual installs of both kinds to really understand how different the subs sound. Free-air installs: - Sound more boomy and lack tightness and detail (in nearly all cases). But, they also need lesser power (a not-so-powerful 2-ch amp will do nicely). - Your boot will be free of a box at all times. - Integrate almost automatically with the fronts, when tuned right. BAss usually sounds less localised. - These installs are also not really easy to get right. The boot must be sealed completely from the cabin for the sub to sound as i should. A box-install: - Slightly more expensive because of the box, the connectors needed for removing the box when needed, and mostly because of the higher power requirements. A ported box will also generally be happy with a 2-ch amp, but will effectively get less louder than a free-air sub getting the same power. (I'm referring to entry-level to medium priced subs here all the way). - A sub in a sealed box would need a lot more power to sound as loud (and good). - The enhancement in detail and tightness in a box install justifies the higher cost. - You can always set it up so you can remove the box when you need more space in the boot.
__________________ Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison |
| | #6 (permalink) | ||||
| BHPian Join Date: Jul 2007 Location: New Delhi
| Quote:
Also, free-air installs may lose a little upper bass "kick", hence would require suitable midbass drivers in the front stage to compensate for this... That said, IB (free-air) bass sounds warm, tactile and more natural to my ears and also blends in more easily with the front stage. It's what I prefer and also have in my car... Quote:
| | #7 (permalink) |
| BHPian Join Date: Feb 2008 Location: hyderabad
| @ CrtlAltDel, First of all, great queries as I always had these doubts in my mind as well. @Hydrashock - Awesome explanation. Just want to confirm - To feel the beat in your chest, should i go for a enclosed Subwoofer then? |
| | #9 (permalink) |
| BHPian Join Date: Sep 2006 Location: faridabad/rourkela
| i think in cars the best way to have a wide sound stage and imaging you need to place speakers facing each other.if they are placed facing IN the cabin then one will loose the soung stage.speakers sound best when you are listening in 'on axis' position but in car audio only ONE person can experience it hence the only option is to place facing each other right in front. |
| | #10 (permalink) | |
| Senior - BHPian | Quote:
![]() A sealed box will be faster and tighter, but will need a lot more power (= a more powerful amp) than the ported box to get more or less the same loudness (as the ported box). A free-air install won't be exactly lacking as far as "thwack" is concerned. It's just that the bass will be much softer and more ummm... enveloping (than a boxed sub's bass).
__________________ Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison | |
| | #11 (permalink) | ||
| Quote:
![]() The thing is if you mount the sub in the parcel tray in a hatch, since the boot space is restricted it would serve like an enclosure (Not as good as a sealed/ported box, but an enclosure in a wider sense) and the performance will be better than the same sub in a sedan's parcel tray since it's boot is bigger. Of course the front/rear isolaton is a problem in a hatch but a good install should take care of it. Quote:
__________________ Anyone driving slower than you is an idiot, and anyone going faster than you is a maniac. ~Author Unknown | ||
| | #12 (permalink) | |||
Earler in my car I was keeping the speakers facing each other I kept it that way for a long time. But one day I thought of experimenting the placement of drivers and its effects. What I observed was that when I changed the location to On-axis of the listener ear there was tremendous improvement on the imaging part. Earlier one cannot make out from which side the sound is coming. But now one can clearly listen tell from which side the sound is coming. This is called Imaging. About the soundstage. Now It is in the centre, earlier I was now where maybe it was near the lap. But now it is on the dash. The singer is on the dead centre and clear in the front. and the stage is wider than before when the speakers were facing each other. I am not bragging or showing off I have not personally not listened to a single car which has that good Imaging and sound stage. If some one has it I would really wanna audition it. Quote:
| | #13 (permalink) |
| Senior - BHPian | http://www.team-bhp.com/forum/ask-gu...thread-87.html (The Swift Audio Thread) read starting from this page to make the speakers installed in the doors safer and for keeping them running for a longer time. |
| | #14 (permalink) |
| lbm how can you have the 'singer in the dash ' in your car when your tweeter is ON AXIS and the midrange facing upwards at the door?????? in your car its only the persion sitting in the driver seats is able to hear both the speakers.what imaging are you talkin about my bro????? |
| | #15 (permalink) |
| Newbie Join Date: Jan 2008 Location: Bombay
| 2 cents he he. you sure squeeze every penny. good explanation but i want to add that comps sound better in the rear - this depends upon where the speaker are fitted. if the speaker are in rear doors then comps is the way to go..but for parcel tray you will not be able to extract the max potential. |
| Thread Tools | |
Similar Threads | ||||
| Wagon R rear speakers tray system | udit78 | Ask the Gurus | 36 | 11th July 2008 19:09 |
| Tweeter Mounting Position - Rear Door Component ? | BHAGWAN | Ask the Gurus | 2 | 23rd June 2008 12:23 |
| Mounting speakers on Boot tray.. good or bad for tray?? | varunghatge | Modifications & Accessories | 9 | 18th December 2007 15:27 |
| Modifying Tata Dicor rear door | Nattusbs | Modifications & Accessories | 12 | 4th September 2007 23:29 |
| Dent and Scratch on the rear - left side door | bangboy | Street Experiences | 25 | 5th January 2007 12:38 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
