Thread Tools
Old 2nd March 2008, 18:59   #1 (permalink)
gigatech2006's Avatar
Default JBL Component speakers - Queries!
Hi gurus,
I have a few queries pertaining to JBL component speakers. Let me first describe the audio setup in my Hyundai Accent. Got a pioneer head unit, Pioneer ovals at the rear and 5 1/4 pioneer co-axials in the front. I was satisfied with the ovals, but the front speakers were just too bad for my audio tastes. I can see that they vibrate with sound, but feels like most of the sound comes only from the rear ovals which have a rich bass and treble.
I visited the car audio shop close to my house, and he suggested that I go for JBL GT050 components for the front ones as they would provide rich bass and treble from the front side too and later I can choose the amount of sound that comes from the front or rear speakers via the HU. He's quoting Rs. 1800 (with warranty) for the components. However, he didn't have proper answers for the following few questions:
  1. Will there be a power mismatch by replacing coaxials with components?
  2. As the components are heavier, will this lead to constant door rattle problems?
  3. Will it drain the battery faster if I listen to music with engine OFF?
Also, is the price right for JBL components? When I inquired at a different place, they quoted some Rs. 4000 for an American brand (not sure what the name was :( ) Just wanted to make sure that I don't end up buying 'fake' JBLs!
Thanks in advance!
giga
__________________
Hyundai Accent GLE 2007
gigatech2006 is offline   Reply With Quote
Old 2nd March 2008, 20:41   #2 (permalink)
rohitabc's Avatar
Originally Posted by gigatech2006 View Post
Hi gurus,
Thanks in advance!
giga
Rs.1800 Dont tell me dude..
rohitabc is offline   Reply With Quote
Old 2nd March 2008, 20:48   #3 (permalink)
Tool's Avatar
hey gigatech
Nope should not be a problem at all. Do you have a amplifier? Regardless should not be a problem but a Amp is recommended for good bass and rich sound.
2.As the components are heavier, will this lead to constant door rattle problems?
It might. All depends of the Installer and his work. Generally it should not add to any more rattle. It might if you have bits loose behind the door panels .Investing in some sound dampening will help you here . Also not to mention the huge increase in sound quality that you get by dampening
Yes it will. The battery depends on the alternator for its charging. If the engine is off the alternator is not running. Hence you battery is not charging at that time.On small systems without amps this is generally ok but again its something i wont do. Puts a lot of strain on the electricals of the car. Also if you have a dying or old battery then this can kill it for you. Its voltage will fall and beyond a certain point in worst cases it wont have enough charge left to start (crank) your engine.
Each battery has a CCA rating (cold cranking amps). In short this is the max power the battery can give out to start your car at a particular temperature. Usually 20 or 25 Deg centigrade.Also batteries need a base voltage of 12.2 Volts at least. If the level drops below that then you have battery failure.
As for the price of JBL's i have no clue but Sam Sirji will surely help you on that front.
hope this helped.
boom
__________________
Why Drink And Drive When You Can Smoke And Fly ??.
Front Wheel Drive Is The Work Of Satan !!!
Tool is offline   Reply With Quote
Old 2nd March 2008, 21:50   #4 (permalink)
Is it cheap or costly??
__________________
Old 2nd March 2008, 23:21   #5 (permalink)
JPL
Toooo cheap bro.. some misunderstanding I guess, please recheck.
Check this out http://www.team-bhp.com/forum/632878-post141.html (JBL GT5 Series)
Edit: seems like you were quoted for the coaxes 502 (5.25") - Rs.1995/ http://www.team-bhp.com/forum/623380-post134.html (JBL GT5 Series)
JPL is offline   Reply With Quote
Old 2nd March 2008, 23:54   #6 (permalink)
Even I had the same feeling, tht's why asked for the price! I even opened up the speaker packing (it was written 2-way component on the packing), and found similar speakers found in the pics Package mentioned manufacturing date of Nov 07, and was made in Malaysia. So, the question is how do I identify whether the speakers are components or coaxials?? any leads on this?
giga
__________________
Old 3rd March 2008, 00:52   #7 (permalink)
rider60's Avatar
giga
JBL Home Audio - JBL Car Audio - JBL Marine Audio - JBL Home Theater, Theater Systems, Speakers, Stereo, Electronics, Surround Sound Systems - Official Home Page
this site should give you good info on the model numbers of the speakers andthe series and other technical information.
now do you have an amplifier? if so please give the exact model number so that you can be suggested a component speaker or you can search this forum it has been discussed alot of times here.
search in the sound off and show off section there i think you will find a few installs and should give you a good idea about how the installs are done in a proper way.
now coming back to the prices the components start at around 4000 bucks the entry level CS series from JBL with bill and warranty please check out the models.
there are other brands like the infinity, rockford fosgate, illusions, kicker, polk audio, hertz, for the speakers and many more too. and there are a bunch of brands for the amps like wise.
i suggest you do your how work by searching this forum before you spend your money! after all you would want to buy the best the amount you spend can buy right?
rider60 is offline   Reply With Quote
Old 3rd March 2008, 07:59   #8 (permalink)
JPL
giga
component speakers come with a speaker, tweeter and a crossover. like here
http://www.alphacaraudio.co.uk/image...TE/GTO607c.jpg
Coax dont come separate tweeter and a crossover. The tweeter is built on to the speaker !!
Old 3rd March 2008, 15:00   #9 (permalink)
I dont have an amplifier. I just wanted to enhance the sound experience on the front side of the car as the present coaxs produce low bass sound but you really have to make sure that they are working sometimes. Most of the sound is from the rear ovals as I mentioned earlier!
Well, this makes me think, I saw neither separate speakers nor crossovers in the box, though it was mentioned 2-way component on the box! Probably they are jus coaxs inside a component box Thanks for this enlightenment! But are the coaxs so costly that they can be sold for Rs.1800?
__________________
Old 3rd March 2008, 15:44   #10 (permalink)
Bass&Trouble's Avatar
I dont think those JBL speakers are made in Malaysia. Not sure. Please consult Sam before going ahead with this. He should be able to help you "spot the not".
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Thread Tools
GTO 608 Component Speaker - Part of the newly released JBL 8 Series blueraven316 Product Discussions 56 2nd September 2008 19:50
Matching component speakers for JVC AVX800 ramkris Ask the Gurus 9 28th July 2008 17:49
Lightning Audio Component Speakers blueraven316 Shifting gears 4 1st April 2007 15:55
Top 10 6.5" Component Car Stereo Speakers k_ajay Product Discussions 14 10th September 2005 12:08
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
