Thread Tools
Old 4th June 2008, 13:25   #16 (permalink)
My Sony HU has developed a strage problem. It reads the CDs alright when the HU is cold i.e. when I start the car. But after about an hour or so when the HU gets hot it start skipping and after some time just ceases to read CDs.
What might be the reason for this and how to correct this?
Nitin
ntomer is offline   Reply With Quote
Old 4th June 2008, 15:05   #17 (permalink)
Shakensoul's Avatar
I also have a similar problem but the symptoms are the opposite. The HU is Sony, it reads original CDs and CD-RW, but does not read CD-R , thought of getting the lens replaced at an authorized service center, but too lazy to take out the HU. As long as its reading CD-RW, I'm fine with it.
Shakensoul is offline   Reply With Quote
Old 4th June 2008, 15:25   #18 (permalink)
esteem_lover's Avatar
Infractions: 0/1 (5)
Originally Posted by ntomer View Post
Nitin
Use a lens cleaner cd, should sort this out.
__________________
Goodbye Dada, you made us proud.
Old 4th June 2008, 23:48   #19 (permalink)
What might be the reason for this and how to correct this?.[/quote]
I don't think its lens - i think its temperature playing its roll.
ntomer
You can do a simple diagnose, power on the hu listen to aux or tuner for one hour then switch to disc.If problem appears in a minute or so its temperature/power source (if you have amp+sub then your car battery/alternator may not producing enough power,and problem becomes worst in the night as head lights are on).
If problem repeats after some time 45min to 1hour then you can suspect lens.
mohang_j is offline   Reply With Quote
Thread Tools
Whats the solution to Windscreen scratches that cause glare? rahuldeodhar Technical Stuff 18 14th September 2008 12:23
Which amp is better Sony XM-554ZR or Sony XM-ZR604? prakasse Ask the Gurus 3 5th November 2007 16:29
Sony 5505 HU not reading MP3 sudhir_nyc Ask the Gurus 32 5th November 2006 19:18
Sony CDX-GT250S + Sony XS-GF6932 aalaap Product Discussions 13 20th September 2006 14:31
Whats the fastest i.e whats the highest average speeds that you have maintained MKRAFT Street Experiences 1 3rd April 2006 18:25
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
