| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | I have a JBL GT5-12 (275W RMS) in a sealed enclosure, driven by a JBL GTO3501 monoblock (225W RMS @ 4 ohms and 360W RMS @2 ohms). I am contemplating an upgrade. The options I have are 1) Change to JBL GTO1264 DVC sub (300W RMS). I will wire it in parallel for a 2ohm load so that the amp is able to put out its full 360W. 2) Add one more GT5-12 in another box in parallel for a 2 ohm load. I tried the second option with an old GT4 sub and I was pleased with the results. The questions I have are a) Which is a better option? (No issues with losing space in the boot) b) In option 1, will the 360W output be bad for the sub which is rated at 300W, also will it sound much better tah my current setup c) In option 2, will the 360W output be equally divided between the two subs. ie will 180W per sub be enough to drive it well? d) the option 2 drives more air, so I'm inclined towards that. What do you say? |
| | #2 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Since you already have one GT5 sub, I would suggest you keep it and add another one rather than trying to sell one off and get another. (Not that selling a JBL sub is going to be difficult, but still )There is no harm in using the DVC sub with the amp either. The little extra power wont kill the sub, and having met you I think you would be very unlike LBM in the loudness department . But I'd still put my money on two subs.
__________________ Operator! Give me the number for 911! Last edited by Bass&Trouble : 12th March 2008 at 21:27. |
| | #5 (permalink) | |
| BHPian | Quote:
You got me right. In the loudness dept, I am as you guessed. I'm looking for a good punch at low volumes. I guess the only option is to move more air which means adding another sub is a better option. Also, is my assumption right that each sub will get only 180W RMS when it is rated at 300W RMS? In that case, will it be optimal? Or will a single DVC sub getting its full 300W RMS be a better option? | |
| | #6 (permalink) | |
| Quote:
Which config would be better is difficult to answer. If you like the quality of bass that you are currently getting and would like to increase the output by a few notches, then adding another sub is the way to go. If you think the current sub lacks something in sound quality that the 1264 can provide (something you can judge by listening only), go for the 1264.
__________________ Operator! Give me the number for 911! | |
| | #8 (permalink) | |
| BHPian | Quote:
If I go for the DVC, it will be a 2 ohm load and the amp will deliver 360W, whereas in the current setup it is a 4 ohm load, so it delivers only 225W. Will that be a substantial difference in output? I would assume not much, because volume of air moved will still be that if one 12" sub. So, I guess adding one more sub, inspite of each being fed with only 180W, should be a better option. | |
| | #15 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
__________________ Scixelsyd Etinu | |
« Original or Not? Purchased a Pioneer 2050 today.
Suggestions to Install a DVD system in Safari »
| Thread Tools | |
Similar Threads | ||||
| Adding a Front Armrest | luvjascha | Modifications & Accessories | 1 | 26th March 2008 08:52 |
| Adding AUX-IN port for HU | gopz | DIY - Do it yourself | 35 | 18th October 2007 16:42 |
| Adding Aircon to Non-AC Matiz. | Su-47 | Modifications & Accessories | 4 | 16th October 2007 20:48 |
| Adding a Tachometer to Alto! | ramki067 | Modifications & Accessories | 14 | 25th April 2007 23:45 |
| Adding Ethanol in Fuel | narasimha raju | The Indian Car Scene!! | 11 | 18th October 2006 09:19 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
