Closed Thread
Thread Tools
Old 17th March 2008, 23:33   #1 (permalink)
amit_mechengg's Avatar
Default Urgent Help needed fot the connection of GT5-12"
gurus, i think i have landed up in connecting the GT5-12" sub incorrectly.
the installer had told me that the gt5-12" sub has red and black marking below it. but he said its the reverse way than the other subs. we have to connect the positive to the black and negative to the red.
please help me from this confusion. also where can i get the wiring diagram of the sub?
__________________
" I dont Drive Fast , I Fly Slowly "
amit_mechengg is online now
Old 17th March 2008, 23:39   #2 (permalink)
Sam Kapasi's Avatar
This stands true in the case of the JBL professional drivers where red is negative. Old horses like Navin can confirm.
The GT5-12 is pretty standard. Red is positive. What wiring diagram do you want?
__________________
Live the YetiLife®
Sam Kapasi is offline
Old 17th March 2008, 23:49   #3 (permalink)
sam sir, the installer told me that the red is negative and black is positive. there are two dots on the bottom. i aksed him why is he connecting the positive to the black. he said in case of jbl its "ulta". i drove home the same way.
but i had to carry luggage so i removed the sub box. and now i forgot the positive and negative.
navin sir please confirm what is positive and what is negative.
__________________
Old 18th March 2008, 00:01   #4 (permalink)
JayD's Avatar
I don't think its 'ulta',atleast i think my sub is wired in the normal way! Anyways, u do have a 'reverse' mode for the sub in the H.U right??
__________________
ATTENDANCE- The last 3 minutes of a class which makes the 2 hours of torture worthwhile!!
JayD is offline
Old 18th March 2008, 00:02   #5 (permalink)
got it sir. red is positive. i saw in owners manual. there are two diagrams where they have shown the connections in parallel and series. over that they have written that red is positive. and black is negative.
sam however i found one more thing in the manual. it says that GT5 should be put in small sealed boxes for SQ and ported for SPL. how will it perform in a ported box similar to jbl bass reflex box? can we seal the port for better SQ ??
__________________
Old 18th March 2008, 00:02   #6 (permalink)
ramie2400's Avatar
connect it and check out both the ways.where you feel the loudness is clear and bassy thats the right connection
__________________
Behind every successful student there is a girl...
But!!,what about unsuccessful student's like "US"??
...Lots of girls. :D
ramie2400 is offline
Old 18th March 2008, 00:05   #7 (permalink)
ya but the connections should always be right. the rev on the HU just changes the way the sub fires IMO.
__________________
Old 18th March 2008, 02:36   #8 (permalink)
low_bass_makker's Avatar
Bro what ramie singh said is 100 % correct. If you wire all the red with positive and black with negative then it is correct. But some times the acoustic of the car can play with the sound thats why there is a sub phase change option in the HU with actually changes the red -red and black - black to red-black and black - red.
low_bass_makker is offline
Old 18th March 2008, 11:55   #9 (permalink)
navin's Avatar
not only some Pro (44xx, 4312, etc..) and some compression drivers (24xx, also some commercial JBL L series (100A, 112, 220 etc that used the LE14A, LE15A, LE10H or LE8T) or B series bass bins (B380, B460 that used the 2226, 2235 and 2245 respectively) and many sound reinforcement models (46xx series) were all "reverse wired". I assume this had something to do with the fact the the 1/4" phono plug was used instead of the RCA in those days.
Now will someone tell me why I can remember model numbers from 35 years ago but cant remember what I ate for breakfast a few hours ago).
you are right.
__________________
Scixelsyd Etinu
navin is offline
Old 18th March 2008, 12:06   #10 (permalink)
@ Navin sir,
i was really wondering how one can remember those big lists of models.i never remembered what the teacher taught in previous classes
sir one more question please. there is a mono and stereo toggle switch on the JBL 75.4. i have put both the switches on stereo.
what is the purpose of that switch. does the amp work like mono? what effect will i get if i put the front connection switch to stereo on which the rear jbl ovals are connected and if i put the rear connection switch to mono on which the sub are bridged?
__________________
Old 18th March 2008, 12:32   #11 (permalink)
navin's Avatar
@ Navin sir,
there is a mono and stereo toggle switch on the JBL 75.4. what is the purpose of that switch. does the amp work like mono?
I have played with most of those JBL woofers. Sam knows that hence he used my name in his post.
the mono stereo swithc is used when you want to pridge 2 channels to one. however when you do that ensure that a single speaker is wired as a mono and it's impedance is above 4ohms. if the impedance is too low and the amp is in bridged mode the amp will trip.
__________________
Scixelsyd Etinu
navin is offline
Old 18th March 2008, 12:41   #12 (permalink)
in that case since i have bridged the GT5 sub which is just 4 ohms , i should keep the switch on the stereo mode strictly otherwise the amp will trip right?
__________________
Closed Thread
Thread Tools
Pio 3050UB (2 RCA) + JBL 4Ch GT5-A604 = HOW to GET A SubWoofer "DILEMMA" svsantosh Ask the Gurus 11 4th October 2008 09:41
JBL GT5-500C, is this component speaker a 4" or 5.25" ? vishnuvijay Ask the Gurus 23 14th June 2008 12:15
Need Urgent "HELP" on Hard-Disk ramie2400 Gadgets, Computers & Software 21 31st May 2008 18:34
Help me choosing enclosure for GT5 12" Subwoofer venki7744 Ask the Gurus 7 25th March 2008 11:50
"Help about my Internet Connection" shiva_cool87 Shifting gears 17 23rd August 2006 13:10
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
