| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Jan 2008 Location: Trivandrum
| Hi Gurus, Last week I got a GT5 12". I am planning to fit this into my new car (yet to arrive) Stile D. Last weekend I measured the T/S specs (as nothing is mentioned on the JBL site). The results was not as I expected (I was under the assumption that the specs would be similar to the GT4 12" series except for the technology). Following are the T/S specs (measured). * f(s)= 30.95 Hz * R(e)= 3.75 Ohms * Q(ms)= 7.413 * Q(es)= 0.864 * Q(ts)= 0.773 * V(as)= 56.000 liters (1.978 cubic feet) * M(ms)= 223.20 grams * C(ms)= 0.12 mm/N The user manual mentions that the sub can either be placed in a sealed or ported box. But from the above specs the only enclosure I can think of is a sealed (EBP ~ 40) and that too with a Q around 1. Now I don't know how to proceed. Gurus, can anyone help me with the following questions. * Is it normal to have this high Qts/Qes for GT5 12" or is it something else (may be I am doing something wrong or the driver is damaged).* If the specs are not normal, can somebody share the specs for the sub. Thanks, Venki. |
| | #2 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
__________________ Scixelsyd Etinu | |
| | #3 (permalink) |
| Do you think the specs are correct? I will try re-measuring in someone elses PC over the week end and see how things go. Also pardon me for my ignorance, what is OB (sounds like IB ) and what has Mms to do with that?Venki. |
| | #4 (permalink) |
| Senior - BHPian Join Date: Sep 2005 Location: In the Hood Near You
| Well even i need GT5-12 Specs for Sealed BOX. Maybe Sam can throw some light on this issue.
__________________ For every idiot there is an equal and opposite gender idiot. Singles are people with incomparable intelligence! |
| | #6 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
Navin is referring to the HT term - OB = Open Baffle; not exactly IB. Low Mms means that the OB physics will get knocked out of kilter by this sub's moving mass being a bit too heavy. ![]() Sam, this is really strange: none of the products have the "Boxes and Parameters" link enabled under the Product Support pages on the JBL website.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! Last edited by DerAlte : 25th March 2008 at 10:30. | |
| | #7 (permalink) | |
| Quote:
OB = Open baffle. When a driver is in open baffle the front wanve is not protected from the back wave (no box) and hence there is cancellation once the wavelength of the baffle is exceeded. To compensate for this drivers with a high Qts (rising respnse) are used; the rising response compesates for the cancellation. However given that the driver has no support from the box (as there is no box) drivers with low Mms (cone mass with air) are preferred.
| | #8 (permalink) | |
| Using the WT3 (woofer tester 3). The manual mentions its dependancy on the sound card volume. So my guess the accuracy might vary depending on the hardware. Also forgot to mention one think, the first mesaurement I made recorded a Qts of .699. Later on I re-measured the driver till the specs became consistant over multiple measurements. Quote:
. I think my memory is also becoming "Lossy" ![]() The JBL india site has specs for the GT4 sub though | |
| Thread Tools | |
Similar Threads | ||||
| Subwoofer Enclosure - Readymade vs Custom | Raja | Ask the Gurus | 7 | 28th September 2007 16:43 |
| For sale: MDF Subwoofer Enclosure | nitrous | Shifting gears | 4 | 11th September 2007 13:05 |
| Velocity 1200 Watts SUBWOOFER With Enclosure For sale. | speedzak | Shifting gears | 5 | 18th April 2006 16:46 |
| The best Subwoofer Enclosure design | HotChillyPepper | Ask the Gurus | 16 | 20th March 2006 19:54 |
| Subwoofer Enclosure | karthik247 | Ask the Gurus | 11 | 12th October 2005 13:21 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425
