| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #61 (permalink) | |||
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
I'm not just saying this with reference to your case, but this is generally true: Sometimes, dealers are offended when a customer suggests impractical/ unusual/ non-standard things. They will just go ahead and do as you said since you cant come back and really catch their necks for it. Plus, the eagerness to do astounding work and give great advice naturally diminishes based on how much money the installer stands to earn from the sale. This does not just depend on the budget of the system, lot of other factors. Some may think my views are very lofty, but this is 100% true. And more so with "big", "reputed" installers. Quote:
__________________ Operator! Give me the number for 911! | |||
| | #62 (permalink) |
| BHPian Join Date: Jan 2008 Location: Mumbai
| Nahi - not true, its only partially installed. Subwoofer is pending. Also, I am not completely happy with the install so would like to get it re-done
__________________ If the speed of light is 3x108 m/s, what's the speed of darkness? |
| | #63 (permalink) |
| BHPian Join Date: Nov 2007 Location: mumbai
| dude if the installer wasnt Boom. please do go to him for the reinstall.hes done my amp rock solid with the mdf board. be sure to use mohan and if Ajay can spare shafique to build you a side mounting board -his way is rock solid do. check out how hes done B's smaller Steg on his swift btw whats the equipment?
__________________ An expert is someone who takes a subject you understand and makes it sound confusing. |
| | #64 (permalink) | |
| Quote:
Do you have any trouble with the amp on the rear seat? Imean does it interfere with any suitcase/luggage? Or do youface any problems in case you have to fold down the rear seat?
__________________ If the speed of light is 3x108 m/s, what's the speed of darkness? | |
| | #65 (permalink) | |
| Quote:
yes if youre planning on folding the seats and using the space then there may be a bit of a problem. i can understand your concern since the getz seats double fold. i can understand why you choose the boot sides.however if it were done the way B has done his swift you would not have any problems. Shafique was his installer and he used MDF bolted with L brackets ( i would assume) so theres no screwing onto the thin fibre sides which would offer a crappy mount as it has happpened in your case Alternatively you may also try the under the seat amp. use and mdf board between the carpet and the metal base of the car . then screw on the amp through the carpet and the MDF sheet. overheating and dust is not a huge problem as people make it out to be.
__________________ An expert is someone who takes a subject you understand and makes it sound confusing. | |
| | #66 (permalink) |
| Hi LBM/Gunbir, Here are the install pics of the amplifier. Let me know your thoughts on how to solve the rattling issue or to relocate the amp. ![]() ![]()
| | #67 (permalink) |
| man if those are self taping screws directly screwed onto the fibre on the side of the boot the whole god damn thing is gonna come off some day let alone the rattles. what you need is an MDF board that can be bolted down with the metallic base of the car boot. then the amp needs to be mounted on that. why dont you get in touch with shafique who did bhagwans install. he may be a little expensive but then you will hav rock solid work However the easiest way is loading the board and amp on the back seat. though i understand that you will loose the option of double folding your seat
| | #68 (permalink) |
| BHPian Join Date: Jul 2007 Location: Gurgaon
| Didn't Wanted to start a new thread. I have a couple of questions before finally finally geting things installed in my Adventure. The car has stock wiring for four speakers. I have Blaupunkt MP47 HU and Blaupunkt THC662 components in front already installed, and I plan to get a four channel amp (Blaupunkt GTA 4 special MKII or Kenwood 8401), 12" Sub (Bull Audio) and 4" or 5" coaxials as rear fillers. I will connect the front components with two channels of amp and bridge the remaining two for Sub. Now the queries are 1) Same query as of Nishant, where to Install the Amp? My only worry is, I don't want to pierce the metallic frame of car. Also as a option there are four Hooks installed into the cars boot, at all the four corners of four, aproxiamtely making a rectanagle of 1 meter by 1.5 meter. So although it sound like a jugaad, but what if I put the Amp in middle of this rectangle and tie the amp screwing holes to all four hooks with strings. ![]() 2) Is Sub-Woofer Enclosure also bolted down with car floor, or is it just put freely there? The Boot of my car is huge, so I doubt that it can roll over during occasional harsh braking or turning. 3) Now Initially i wanted a sealed enclosure, but seeing the boot of my car, i guess it won't suffice and a ported enclosure would be a better choice. My taste regarding Bass is, it should be as original as it is in the track, the Sub shouldn't overshadow the other frequencies. My perception of Ported and Sealed Enclosure is based on a article Car Audio - by Sparky3489@yahoo.com . Kindly correct if me I am wrong here. 4) Approx How much will wiring cost? 5) The specs of Kenwood 8401 and Blaupunkt GTA4 special MKII are almost identical. Both are avaibale in 5-6K bracket. Only kenwood is available in grey at this price and Blaupunkt with B&W. So I am unable to understand why Kenwood 8401 is overhyped. is there any feature worth enough to drop Blaupunkt. I have abudget of 15K, so If some money is saved, then I would prefer to do some noise dampening done of front doors. So gyani gurujano, please clarify these queries and suggest few solutions. |
| | #69 (permalink) |
| 1. mount the amp on an MDF board that is screwed on well onto the back of the rear seat. ICER's on tbhp here dont like juggad 2. Sub woofers in small hatches are generally not bolted down, however you can do that or use l brackets to screw them to the back of the rear seats 3. the article on subs is good.However please read threads here to get the concept clear. Subs in sealed boxs generally produce controlled bass that is not too loud(compared to ported).if you say you want accurate bass reproduction that doesnt overshadow other frequencies please go for a sealed box rather than ported. it would be advsable if you can audition a sealed box and a ported box before you decide 4.Decent power wire 150-175rs/metre-you would need about 8-9m,Decent rca wire 350-800rs/pc,decent speaker wire 35-100rs / metre 5.kenwood and Blaupunkt have slightly differnt sound signatures.Both are good choices.Audition and decide
| | #70 (permalink) |
| BHPian Join Date: Aug 2008 Location: Bangalore
| The best place to put the amp is under the front seats. It saves space and most people don't generally change the settings once its in place. The back seat would make sense if you were going to make changes to the sound. IMO take all you can with B&W it always makes sense. SUB's in ported boxes have an extension in the lower frequencies. that is basis box and port tuning. these have to be matched right with the sub to get the best effect. Typically its easiest to get a sealed box matching the sub's volumetric requirement. Sealed boxes have excellent reproduction as is. Selection however is best left to you and your preference. most of my friends with hatches haven't bolted down subs. The box itself is typically enough to hold it in place or you can use the L brackets like magma recommended. |
| Thread Tools | |
Similar Threads | ||||
| Help With Speakers & Amplifier/ AV Receiver | nura | Gadgets, Computers & Software | 41 | 12th December 2007 23:24 |
| Audiobahn 6X9 (3 way) speakers for sale.... | panky12345 | Shifting gears | 6 | 23rd October 2007 19:43 |
| How to get Tighter bass from 6x9 Speakers? | anuragn | Ask the Gurus | 68 | 3rd October 2007 15:54 |
| For Sale Infinity Reference 6913l 6x9 speakers | clipto333 | Shifting gears | 0 | 2nd May 2007 21:16 |
| Pioneer Speakers - Which one with 944 amplifier? | GTO | Ask the Gurus | 7 | 12th May 2004 23:40 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
