| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Jan 2006 Location: Bangalore/London
| The amp is GM X374 which is 4 channel amp and has 35 X 4 at 4 Ohms, 50 X 4 at 2 Ohms and 100 X 2 at 4 Ohms. Recently I took the infinity Reference 6020cs comopnents and JBL 527 coaxials. Infinity Components are at 90 WRMS @ 2.65 Ohms and JBL is 45 WRMS @ 4 Ohms. Now i need suggestions to get better sound and power. First thing can i bridge the components to make 100 X 2 @ 4 Ohms in Mono mode and run the rear coaxials from HU ? If I run 2.65 Ohms component speakers on 4 Ohms amp will it damage the amp. Next can i use connect the rear coaxials also to the same bridged setup. Its like connected two wires - one from Comp and one from coax ? Also If I bridge it will I get to notice notes which are meant to left and right channels (in short Fader control). And what Gain should i set on amp? Should i keep it to normal? Hope its not confusing. Experts advice pleasee. |
| | #2 (permalink) | ||||
| Team-BHP Moderator ![]() Join Date: Mar 2007 Location: Bangalore
| On the contrary, extremely confusing is what it is: ! Difficult to figure out what you are trying to do, and what you want to achieve.Do you mean "play louder, yet clean"? Quote:
That will be known when you tune it
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | ||||
| | #3 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
the amp you have will drive 4 speakers (2 components and 2 coax speakers) without trouble but not in bridged mode. If your HU has 2 sets of pre outs (front and rear) the above is what I'd suggest you do. The 2.65ohms rating is a nominal rating and should not trouble your amp too much. However if you do find your amp getting too hot to touch then you might been a better amp.
__________________ Scixelsyd Etinu | |
| | #4 (permalink) |
| Ok, Some of the things sorted, like my ideas on Balance and Gain controls. The user manual of the Pioneer amp says this :- To prevent damage • Speakers to be connected to the amplifier should conform with the standards listed below. If they do not conform, they may catch fire, emit smoke or become damaged. The speaker impedance must be 2 to 8 ohms. But in case of two-channel and other bridge connections, the speaker impedance must be 4 to 8 ohms. Hence, I am now bit reluctant to connect the Infinity Components which is 2.65 impedence to the amp which is will supply 4 Ohms in bridged mode. However from another source of information about Infinity Reference product description, this is what is said :- Infinity Reference speakers have two-ohm voice coils. This unique approach extracts more power from your amp or head unit. Many factory OE systems include two-ohm speakers. Infinity Reference speakers are perfect for those applications.If your head unit or amplifier is rated to drive a four-ohm load, Infinity Reference speakers are still the best option. Again its bit of confusing. |
| | #5 (permalink) |
| Senior - BHPian Join Date: Nov 2006 Location: Mumbai
| Go ahead and connect it dude,nothing will happen as Deralte said amp can feed anything between 2 and 4 ohms.only thing to take care is don't connect the Compos in Bridge mode.
__________________ "Whenever I find the key to success,..... someone changes the lock. |
| | #6 (permalink) | ||
| Quote:
If each section of the amp (FL, FR, RL, RR) is able to feed a 2 ohms speaker, in the bridged mode (2 sections together - FL+FR, RL+RR) also it will be able to feed it - as long as it is not asked to feed a load of less than 2 ohms per section * The fronts (infinity) will present a 2.65 ohm load: perfectly acceptable for the amp * If you connect BOTH the fronts and the coaxes, you get a 1.59 ohm load: not acceptable (it WILL play, albeit for a short while before going into protection) Quote:
* round it up by the conventional rule, you will get 3 ohms * ignore the decimal part and you get 2 ohms!!! Since most amps are 2-ohms stable, it works perfectly OK. People who don't use an amp will normally play at a moderate volume (ignore the "I want the loudest at the lowest price" cases for a moment), not enough for the HU amp from over-heating and tripping. For the other cases, one has to be totally "tripped out" not to notice the distortion that the amp will produce before tripping.
| | #7 (permalink) |
| Thats a neat explanation by DerAlte. I am now convinced that I can bridge in Mono Mode from 4 channels. Its like bridging 4 channels to 2 channels. Like Derlite said "left to the amp 'front' set, right to the amp 'rear' set" Ramie : You said "be sure not to Connect Comps in Bridge mode." Is it true that Components cannot be connected in bridged mode? Phew now I am getting confused. |
| | #8 (permalink) |
| Relax, @Kiran, no reason why comps cannot be connected, other than the impedance being too low for the amp. @Ramie must have meant comps and coaxes in parallel. Right, @ramie? You would need some wiring jugglery to achieve the bridge. You have to use RCA Y cables to feed the L signal from HU to both L & R of amp Front, and R signal to L & R of amp Rear.
| | #9 (permalink) | |
| Quote:
advised him to connect the speakers in parallel with proper Phase.Dunno why he is getting soo confused,in connecting the speakers???
__________________ "Whenever I find the key to success,..... someone changes the lock. | |
« Hyundai I10 Audio Setup - Help needed
ipod integration with Safari 2.2 stock ICE - Blaupunkt bahamas?? HU »
| Thread Tools | |
Similar Threads | ||||
| Running a kinetic for speedrun | binz | Motorbikes | 23 | 22nd November 2007 07:15 |
| Amplifier rating Vs Speaker rating | CaAT | Ask the Gurus | 22 | 13th November 2007 10:56 |
| The running-in trip to Agumbe | Samurai | Travelogues | 21 | 11th November 2007 10:14 |
| HU ( CD player), speaker and amplifier is available for 10k | nicejits | Ask the Gurus | 5 | 1st October 2007 23:44 |
| amplifier for alpine speaker...help me . | jerish666 | Product Discussions | 5 | 28th December 2006 09:46 |
