Thread Tools
Old 28th March 2008, 10:04   #16 (permalink)
BHAGWAN's Avatar
Unhappy Knew - but never used !!!
Originally Posted by low_bass_makker View Post
You dont know about HX-D2..that is strange. Anyways here is some info about it...
Clarion India | HX-D2
Clarion HX-D2 Head Unit : Equal to McIntosh/Nakamichi/Pioneer P9 etc? - Talk Audio Forums
Ya with Steg amps the possibility are endless
Sir,
I knew about it, but had never used it.
Actually I was planning an 'active' re-install of my RS.
Things may be a bit 'stressed' financially.
If things get better, I will go active on the fronts of the RS.
The amplifier cost gets prohibitive.
Maybe, I will buy an Audison VX & replace a Steg from the I-10 & put that Steg in the RS & go active. However, I do not have plave for another amp in the RS. There are 3 of them & it is rather packed.
Actually, I have so much of car audio gear lying around, If I could just sell it all off -40 to 50 % off] I may be in a position to generate some funds.
Fingers are X-ed.
Truthfully my new CD Plaer has landed in ND - yesterday & I shall have to pay for it next week & that is robbing me of my sleep !!!
__________________
'bhagwan'
'B'
Mumbai - India
BHAGWAN is offline   Reply With Quote
Old 28th March 2008, 10:16   #17 (permalink)
BHAGWAN's Avatar
Wink I will check this out !!!
Originally Posted by gunbir View Post
Sir actually Clip is right. The Alpine 9887 CAN do 3way active. You have a switch (under the HU IIRC) that you have to select to the active position. Then when you power up, the menus will change to an active setup menu. The Pioneer P80 also does this in a similar fashion.
Thanks Gunbir;
I shall check this out.
This may sound stupid, off the hat, so please do pardon;
If the HU has only 3 rca pre outs, how can one send different signals to different power amps to drive different drive units ?
You see, in the Clarion HU, there are many RCA outs for the 'active config'
How is this done in the Alpine HU ?
Please do try and explain.
Mind you, I still have not checked the 9887 out 'completely' !
So there is room for improvement - for me i.e.
Thanks !
__________________
'bhagwan'
'B'
Mumbai - India
Old 28th March 2008, 10:25   #18 (permalink)
gunbir's Avatar
Infractions: 0/1 (4)
Sir, the main difference here being that the Clarion can do 4way active and the Alpine 9887, 3way. As you rightly pointed out, with the Clarion, you have 8 channels to play with. While in the Alpine, you only have 6 channels.
Clarion HX-D2 - High, Mid, Low, Sub (front 3way + sub)
In "Normal" mode, the Clarion is configured for Front + Rear + Sub + Full Range. When you select "Network" mode from the setup menu, it converts into 4way active as above. There is also a "Direct" mode for purists where the DSP is switched off and the HU goes full range on all preouts.
Alpine 9887 - High, Mid, Low (front 3way / front 2way + sub)
As mentioned earlier, select active at the switch, and your menus convert to active 3way.
__________________
Often imitated, never duplicated!
Old 28th March 2008, 10:35   #19 (permalink)
BHAGWAN's Avatar
Wink Small Clarification - Please............
Sir,
Thanks.
Small clarification - please.
The Alpine HU has 3 RAC's out. i.e. 6 channels.
Now, suppose I have 1 set of components in the front & 1 set of components in the back & 2 subs. This will work.
However, what if I want to remove the passive x-over & make the set up active ?
I will need 2 RCA's for the front left & 2 RCA's for the front right. Correct ?
Same for the back componenets.
That means that my 2 components [front & back] will need 8 RCA outs. My Sub's will still be left.
Besides, I need to work on the X-Over for the components [without passive network] The frequency & the slope etc. Will the Alpine give me all this flexibility ? I am not so sure.
The Alpine HU is for an average to semi serious CAR AUDIO enthusiast. I feel. I like it, price to performance is great, but is not an out and out performer.
__________________
'bhagwan'
'B'
Mumbai - India
Old 28th March 2008, 10:47   #20 (permalink)
gunbir's Avatar
Cool
If you go active with this HU I'm afraid rear fill will have to be abandoned. The HU will only do fronts and sub. And though you can parallel the HUs preouts to multiple amps for a front and rear active setup (even if you you can live with front and rear having same xo, slopes), you will lose out on time alignment. Of course, you can always go active from your amps.
But, if you want to go active with your HU, pretty much forget active rear fill.
Exactly.
__________________
Old 28th March 2008, 11:55   #21 (permalink)
navin's Avatar
maybe if you use 5-6 channel amps you can manage. remember the tweeter amp need not be big power.
1 2 ch. amp 150-200W x 2 x 4 ohms for subs
1. 4 ch. amp 75-100W x 4 x 4 ohms for midbasses (front and rear)
1. 6 ch. amp 40-50W x 6 x 4 ohms for front mid and tweeter and rear tweeter
If your fronts are 2 way 2 x 5ch. amps can do the job. there are many 5 ch. amps that can drive a subs at 150-200W and 4 more channels at 50-75W.
we have a section for this.
If you are using the Alpine you will have to go active at the amp end. however few multi channel amps (4-6 ch.) have TA built in. Gunbir and B&T might be able to list those that do.
__________________
Scixelsyd Etinu
Old 28th March 2008, 14:34   #22 (permalink)
clipto333's Avatar
Gunbir, even the HX-D2 i think cannot do front, rear and sub active. Can you list any other Hu that can do 4-way active?
Navinji,
The Audison Vrx and the steg k series have optional Ta modules. Don't know about others.
cheers
clip
clipto333 is offline   Reply With Quote
Old 28th March 2008, 15:02   #23 (permalink)
BHAGWAN's Avatar
Thumbs down T.A. Module ??? I am lost !!!
Dear Navin & Clipto,
I am lost;
What does a TA module have to do with set up a ICE in active mode ?
Can you please throw some light ? Please.
We are talking about HU's that can run speakers [components] in an active manner [without a passive x-over]. We do not need to run the components bi-amplified. We need to talk about HU's that can run the speakers through amplifiers and have active x-over in them.
TA is a funstion of tuning the bass in a car. The Arrival of different frequencies at a specified destination [location] !!
You guys have confused me; Please do shed some light.....
Thanks.
__________________
'bhagwan'
'B'
Mumbai - India
Old 28th March 2008, 16:57   #24 (permalink)
navin's Avatar
I think what you seem to be looking for is a HU that has LPF out and HPF out for front and rear as well as a sub out. so in effect you need 10 RCA outs (or atleast 9 if we consider a mono sub). To behonest I dont thik such a HU exists. I believe that if one really is looking for this level of funtionality one needs a 2 box solution with a HU having 5-6 RCA out and a processor that does the time alignment, x-crossover, and eq functions. Alpine, Pio and I am sure others have such solutions.
My contention is/was that if we can have 9-10 RCA outs why not have TA not only between the sub and the front speakers but also between the midbass and tweeter (sort of like a ladder network used to align tweeters with midwoofers in home audio 2 way speakers). The advantage of this would be that one could delay the tweeter (which is usually mounted closer to the ear) to be aligned with the woofer.
If however you are only looking for Xover funtionality (in the HU) I would do what Gunbir suggested: let the amp do this.
There are many amps (4-5-6 ch. amps) that can accept a fullrange (or almost full range) signal and XO it into a HPF and LPF before amplifiying the same and driving individual woofers and tweeters. I think Steg and Audison both do this. If Clip is right then you can do the TA at the amps too!
__________________
Scixelsyd Etinu
Old 28th March 2008, 18:00   #25 (permalink)
low_bass_makker's Avatar
Steg K series does not have TA modules..
Old 28th March 2008, 18:08   #26 (permalink)
BHAGWAN's Avatar
Exclamation Correct !!
Spot on Sir !
I am still lost;
Why are we discussing TA on an Active Install thread ?
Most guys here are talking about Bi Amplification of Speakers, not Active Amplification of Components with Active X-Overs !!!!
__________________
'bhagwan'
'B'
Mumbai - India
Old 28th March 2008, 18:15   #27 (permalink)
Spot on Sir !
I am still lost;
I think they are presumming that if one is going active he or she will do TA.
I think this is what Godji is asking for.
Old 28th March 2008, 18:29   #28 (permalink)
BHAGWAN's Avatar
Wink Correct Again !!
Hi !
You are right;
This is OK, if one has Stegs to use.
Then any HU can work, since all the 'tinkering' happens with 'chips' in the Amplifier.
However, if you do not have Stegs, then which HU can be used ?
That is how this topic has been progressing.
The illustration is good, but it is only applicable for Steg's
If Steg's are not being used, then Which HU can be used to do this ?
That is the Million Dollar Question.
Thanks LBM for the illustration.
__________________
'bhagwan'
'B'
Mumbai - India
Old 28th March 2008, 18:42   #29 (permalink)
clipto333's Avatar
Spot on Sir !
I am still lost;
Most guys here are talking about Bi Amplification of he stegSpeakers, not Active Amplification of Components with Active X-Overs !!!!
I dont think we were discussing TA in particular. Please read the post No. 127. navinji said "Gunbir and B&T might be able to list those that do"
i replied listing the amps i thought could do TA with modules.
i don't really understand whats confusing you.
cheers
P..S. - I didn't read your last reply.
No HU can do front + rear + sub active.
Old 28th March 2008, 18:44   #30 (permalink)
For a 3 way+sub setup in which there is
1. Front tweeter
2. Front Midrange
3. Front Midbass
4. Sub (front or back)
Then one can use
1. Pioneer P9 combo
2. Alpine PXA-H701
3. Alpine PXI-H990
4. Clarion HX-D2
There will be more but these are more popular ones.
For a 3way front + 3 way rear + sub there is no HU in this world. One will need to put external crossovers for the same.
For a 2 way + sub normal HU like Alpine 9887, P80 can do the job.
Thread Tools
Windows Vista Discussion Thread normally_crazy Gadgets, Computers & Software 391 4th November 2008 19:11
The Moto GP 08' discussion thread Shan2nu Motor-Sports!! 191 27th October 2008 18:52
The ABS discussion thread!! VMG Technical Stuff 205 20th September 2008 10:21
The Top ICE Amplifiers Discussion Thread BHAGWAN Product Discussions 53 18th April 2008 13:41
Chennai General Discussion Thread slipstream The Team-BHP Meet Section 11 9th August 2006 16:43
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
