| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #31 (permalink) | |
| BHPian Join Date: Feb 2006 Location: Mumbai - Bombay
| Quote:
TA was never asked for my Million Swords - I think !!!
__________________ 'bhagwan' 'B' Mumbai - India | |
| | #32 (permalink) | |
| Senior - BHPian Join Date: Sep 2005 Location: New Delhi
Infractions: 0/1 (4) | Quote:
So the answer to your question is: there is no one box HU solution that will let you do Active Front 2way + Active Rear 2way + Sub.
__________________ Often imitated, never duplicated! | |
| | #33 (permalink) | |
| BHPian | Quote:
I didn't start anything. i just replied to navinji. That's it. It were your questions which were being answered. I think navinji thought you would need TA with active XO's so he asked Gunbir and b&t if they could list amps that can do TA. Whats so confusing in that? The active vs passive thing was over in a few posts and shifted to you wanting to reinstall you setup in RS actively plus the discussion on HU that can do active. cheers Last edited by clipto333 : 28th March 2008 at 19:31. | |
| | #35 (permalink) | |
| BHPian Join Date: Jun 2006 Location: Delhi/Noida
| Quote:
Auditions are always available for music lovers. ![]()
__________________ Car : Kenwood - Tru - Rainbow - ID Home : Dynaudio - Krell In the audio world, adding to the music is the biggest sin. Last edited by sk456 : 31st March 2008 at 15:08. | |
| | #36 (permalink) | |
| BHPian | Quote:
![]() Will send you a PM when im in Del. cheers clip | |
| | #37 (permalink) | |
| Quote:
I rest my case. ![]()
| | #38 (permalink) |
| BHPian Join Date: Oct 2007 Location: Mumbai
| I have a Santro and am currently running the following setup, Amplification: 2*4 ch amps = 8 channels of amplification. Speakers: 2 pairs of 6.5'' 2-way components. Sub: One 12'' sub in a sealed enclosure. Head Unit: Clarion DXZ 775 USB Currently, the components are running off one 4 ch amp and the sub is running off 2 bridged channels of the other amp. My brains been wandering recently between studies and the following came to my head. The Mid-bass driver is mounted on Mdf ring on the door and the tweeter some 10'' above it. I have a 4'' co-ax lying around, which would fit the stock, in-dash location in the Santro. As my HU has on-board 3-Way Active crossovers, i'm thinking if the 4'' co-ax can be linked to the two-way components and wired to the HU crossover to go 3-way active Jugaad style. Thus, in total, 6 ch of amplification would be required and the remaining 2 channels, bridged to drive the sub as usual.
__________________ Don't let the past dictate who you are but let it be a part of who you become |
| | #39 (permalink) |
| Guess the ICEPerts are busy. Anyways, i'm going DIY on this hack job today. Will keep the updates coming. Hoping to be assisted by the ICEPerts on this one.
| | #40 (permalink) | |
| Senior - BHPian | Quote:
| | #41 (permalink) |
| LBM Bhai, thanks for the encouraging news. As of now, i couldn't work on my car. Spent the entire day installing ICE in a Marina and my friends Santro instead. With the three way setup, this noob will need guidance, somewhere on the lines of ''3-way active for dummies''. You have said that i should try getting a 3 way active crossover, but my HU features 'Digital 3 way cross over', from this i gathered that i will not need an external cross over, all i'll need is 6 channels of amplification. Am i on the right track or have i gone off track ? Also, please elaborate on the values of the cap and the inductor required, along with the wiring requirements.
| | #42 (permalink) | |
you can do it with your HU but it will do 3-way not 4-way active which you want. You would need external 3-way for the tweeter, midrange, midbass. You can control the sub from the HU directly. Give a 80 hz HPF singal to the crossover and control all the freq from there. The value of caps and inductor will depend on the cross over points you choose. But I would recommend a active setup here. | |
| | #43 (permalink) |
| | #44 (permalink) |
| Is there any place where i can get cross-overs OTC or do i need to make one for myself. If so, then i'm afraid i have an uphill task on my hands. SOS !
| | #45 (permalink) | |
| BHPian Join Date: Jul 2007 Location: New Delhi
| Quote:
1. Disconnect the tweeters from your component set. 2. Mount the 4" coax in the stock location in the dash 3. The 4" coax is already a passive 2-way speaker. High-pass it using your HU active crossover and connect to 2 channels of your 4-channel amp 1 4. Bandpass the 6.5' midbass drivers using your HU active crossover, connect to other 2 channels of your 4-channel amp 1 5. Lowpass your sub using your HU active crossover, connect to bridged 2channels of your 4-channel amp (as you are currently doing.) In this manner, your are using the tweeters of your coaxes and the passive XO connecting them to the 4" driver. Pros - you have a true 3-way front stage without need for any external crossovers, also because your tweeter & midrange (in this case the 4" coax driver itself) are coaxially mounted, you should get a more coherent sound. Cons - the tweeter on the coax may not be as good as those on your compnents, you cannot select crossover point/ slope b/w tweeter & midrange, no separate level adjustment for tweeter & midrange either. It may sound a lot better than you expect. Try it out and see if you like it, and let us know ![]() Last edited by Flying Bong : 19th June 2008 at 09:35. | |
| Thread Tools | |
Similar Threads | ||||
| Windows Vista Discussion Thread | normally_crazy | Gadgets, Computers & Software | 391 | 4th November 2008 19:11 |
| The Moto GP 08' discussion thread | Shan2nu | Motor-Sports!! | 191 | 27th October 2008 18:52 |
| The ABS discussion thread!! | VMG | Technical Stuff | 205 | 20th September 2008 10:21 |
| The Top ICE Amplifiers Discussion Thread | BHAGWAN | Product Discussions | 53 | 18th April 2008 13:41 |
| Chennai General Discussion Thread | slipstream | The Team-BHP Meet Section | 11 | 9th August 2006 16:43 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
