| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Mar 2008 Location: Bangalore
| To the Gurus: I got my ICE setup for my Swift diesel recently and discovered that there is a lot of cellphone interference through my speakers. After trying(unsuccessfully I must add) to identify the cause, I took the car to my installer (Sound Factor) and surprise, surprise, there was no problem at all and everything seemed normal. I took couple of spins with the installer and after looking quite stupid, I dropped him back and made my way back home grumpily. And again, it happened...the irritating sound (like the one you get when your cellphone is close to your landline) was back. After spending more time trying to troubleshoot, here's what I've discovered:
My cellphone is a Nokia 6151 and am on an Airtel connection. Any inputs on solving this problem will be greatly appreciated!! ![]()
__________________ Honk only if u're horny |
| | #2 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| This is likely to happen with any HU * when a call is active * when a call is being connected or disconnected * if GPRS is on and there is data activity Did you check by actually trying to make a call when you were testing? Solution? The simplest is to keep the handset away from the HU. Also, check the grounding of the outer shell of the HU.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #3 (permalink) | |
| Thanks DerAlte Yes, I did try making a call while I was testing. The interference occurs when a call is about to come in or when a number is being dialled. After connectivity, the interference goes away. The closer the handset is to the HU, the louder the interference. Quote:
__________________ Honk only if u're horny | |
| | #5 (permalink) |
| Found quite an interesting article after some Googling: macosxhints.com - How to prevent iPhone audio interference in speakers The suggestion is to use some aluminium foil behind the cellphone to prevent the interference. I tried that and voila, it worked!! Also, juggled with removing and replacing the aluminium foil. The interference was not audible as long as the aluminium foil was behind the handset, and came back as soon as I removed the foil. The HU in my previous car was a Sony 5500 (I think...) and it had an aluminium trim around the border. Maybe that was what prevented the interference. My current HU is a Pio 5090 and has no aluminium trims. It would be interesting to know from fellow T-BHPians their experience of HUs with/without aluminium trims with regards to cellphone interference.
| | #6 (permalink) |
| Senior - BHPian | I never had any cellphone interference in my Pio 2950 when using any of the cellphones. Did you try using any other cellphones other than Nokia 6151 ?
__________________ Hold fast to dreams, for if dreams dry, life is a broken-winged bird that cannot fly. |
| | #7 (permalink) |
| Yes, I've tried a MotoSlvr and couple of other cellphones. Same problem. Interestingly, a co-worker at office has the same HU in an Alto and faces the same interference problem. Quite weird ![]() Will try visiting my installer over the weekend for any possible solution.
| | #8 (permalink) |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| If you have the habit of leaving the cell phone on the dash, under the HU (on the double DIN space) this will happen, look at the bright side, i use this to intimate myself, of incoming calls ![]()
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
« Rockford Fosgate P312D4 magnet in basket moving.
Connect N73 Music Edition to Pioneer 6950 using Aux IN »
| Thread Tools | |
Similar Threads | ||||
| Interference in FM Radio while Blowing the HORN | 1self | Ask the Gurus | 20 | 28th August 2007 23:40 |
| Cellphone may erase your car key! | tsk1979 | Technical Stuff | 9 | 31st May 2007 00:09 |
| Colour-Shifting Interference Paint finish | Ram | Technical Stuff | 10 | 28th January 2006 00:47 |
| Lost my cellphone - what do i do ? | manson | Gadgets, Computers & Software | 16 | 13th March 2005 03:30 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
