Thread Tools
Old 12th April 2008, 23:07   #1 (permalink)
Default ICE upgrade for Magnum LT
Am plannin 2 get a Magnum LT soon n felt ther is a need 2 change the sound setting in the car. It comes wid a Alphine 2din MP3, the car is for my dad n just wants a decent setup. need help 2 change the speaker setup, on a tite budget 10-12K, not plannin 2 change the HU as I felt its good enough. Calling all the experts here to help me in findin me a good amp,component or coaxial setup.
P.S does this HU support VCD/DVD video?
channelv is offline   Reply With Quote
Old 12th April 2008, 23:40   #2 (permalink)
Team-BHP Moderator
navin's Avatar
1. please do not use SMS terminology on TBHP. I had to read your post twice to understand it.
2. for 12K I'd suggest getting an amp and good front speakers. Use the stock OEM speakers till your budget permits.
There are 4-5 good amps (JBL, Blau, Kenwood, Pioneer) that can be had for about 6-7K and similarly about 3 good component speakers (JBL, Blau, Illusion) for about 5-6K.
__________________
Scixelsyd Etinu
Old 13th April 2008, 07:24   #3 (permalink)
Am really really sorry navin, and to evrybody......I guess my lazyness is eating on to things that I write....figured out the difficulty only when I myself tried reading it. Sorry again!
I was wondering how much it would cost for a decent component to be put in front and a good coaxial at the back with a suiting 4 channel amp for this Alphine HU. And what about damping? How important would it be in Magnum?
Old 13th April 2008, 11:21   #4 (permalink)
BHAGWAN's Avatar
Infractions: 0/1 (4)
Talking Damping @ Budget is 10/- K !!
Sir, I am a bit lost; You mentioned that your bedget is 10 to 12 K
In this you want 'decent components' + 'good coaxial' + 'suiting 4 channel amp' + 'damping'
Ambitious, is the least I can say;
The damping for the car along will set you back 15 K.
100 sq. ft is what you will need for 4 doors @ Rs. 150/- per sq. ft. + Labour - fitting charge Rs. 2/- K minimum.
__________________
'bhagwan'
'B'
Mumbai - India
BHAGWAN is offline   Reply With Quote
Old 13th April 2008, 11:41   #5 (permalink)
Team-BHP Moderator
DerAlte's Avatar
@channelv, please limit smileys to 2 - hope you have read the posting rules.
Hmmm, have you listened to the stock system? What was it that you found was lacking?
As Navin said, getting components in front and an amp are the 2 measures with the most effect. For example, a Blaupunkt GTA4 Mark II Special (6K with b&w) with JBL GTO 607 or Blaupunkt THc172 or Hertz DSK165 or Illusion Electra 6.1 (~6K).
You would need a couple of thou more for decent wiring (watch out for fakes). A bit of damping wouldn't hurt - a good installer should be able to do some strategic 'jugaad' damping with closed cell foam and cotton waste. Of course the proper way to do it would be with regular damping sheets like Dynamat, etc., which would cost at least 5K.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 16th April 2008, 18:08   #6 (permalink)
sonic_boom's Avatar
Try going through this thread. It'll help you a lot.
Systems at Various budgets (basic ICE - systems at various budgets -10K, 15K, 20K, 25K & 30K)
__________________
If 10% of road accidents are due to drunken driving then 90% of accidents are due to driving without drinking...Hmmm...
sonic_boom is offline   Reply With Quote
Old 9th June 2008, 18:36   #7 (permalink)
manojgautham's Avatar
Default ICE for Magnum - Gurus Please Help
I have booked a Chevrolet Optra Magnum and should be getting it sometime next week. I went through a lot of threads and found that the HU & speakers that come with the car aren't good enough and I plan to change them. This is what I was planning.
HU - JVC KW AVX814
Speaker Rear - DLS Performance 960 - 3 way co axials
Speaker Front - DLS Performance C6A - 2 way components
I plan to have a 4 channel Amp & a mono amp to drive the sub.
When I met an ice installer I was advised against using a sub. The reason quoted was that the boot in Magnum is kind of air tight and I will not get enough bass effect in the cabin.
Now I request the Gurus to help me out with the following,
1) What is the approximate price for the HU, Co axials & Comps?
2) I need suggestions on which amps to use along with their approximate prices. I am looking at VFM
3) Has somebody used a sub in Magnum, does it give decent bass?
4) The above mentioned HU is 5.1 channel, I need suggestions for the surround speaker along with mounting ideas.
Thanks in advance,
Manoj
manojgautham is offline   Reply With Quote
Old 9th June 2008, 18:41   #8 (permalink)
Oops, I think I have posted this in the wrong place. Mods please move this thread to "Ask the gurus"
Old 13th June 2008, 16:58   #9 (permalink)
Gurus, please help me with my query
Old 13th June 2008, 17:07   #10 (permalink)
Team-BHP Moderator
navin's Avatar
Originally Posted by manojgautham View Post
HU - JVC KW AVX814
When I met an ice installer I was advised kind of air tight and I will not get enough bass effect in the cabin.
I am not uptodate on prices but LBM is one DLS owner on THP who might be abl to help.
Yes the bass from a sub in the trunk of a sedan might be attentuated but it will still come through into the cabin.
For the amps check out JBL, Pioneer, Kenwood and Ground Zero. Each of them makes a decent VFM 4 channel amp and monoblock.
__________________
Scixelsyd Etinu
Old 20th June 2008, 12:51   #11 (permalink)
Thanks Navin Sir, I am getting the vehicle tomorrow. Will let you know how it sounds after I install the ICE.
Old 26th June 2008, 12:19   #12 (permalink)
Finally took delivery of the car on 21st June.
The ICE upgrade done is as follows:
HU - JVC - KD AVX814
Front Comp - Helix 6.5"
Rear Speakers - Infinity Co-ax - 5.5"
Sub - Infinity 12"
Amp - Kenwood - 4channel
- JBL - Mono - 300.1
The SQ is superb and I am loving the music.
Old 26th June 2008, 12:33   #13 (permalink)
Manoj, what was the damage? Especially how much did the JVC Headunit cost?
SumitB is offline   Reply With Quote
Old 26th June 2008, 12:39   #14 (permalink)
prince85's Avatar
Sub - Infinity 12"
Congrats dude, thats some very good equipment you have got there! Please post the install pics and importantly the pics of the DVD Head-Unit from different angles if possible.
By the way, whats the difference between JVC AVX 810 and 814?
__________________
2008 - SUZUKI SX4 ZXI (Leather Option Pack)
prince85 is offline   Reply With Quote
Old 26th June 2008, 14:13   #15 (permalink)
gunbir's Avatar
Wink
lol
You can try reading the manuals for both.
__________________
Stuck in my head - Goldspot - Rewind
gunbir is online now   Reply With Quote
Thread Tools
ICE Upgrade saintsinner Sound Off and Show Off 119 30th January 2008 07:46
ICE upgrade for Fiesta nemo Ask the Gurus 4 1st October 2007 17:22
ICE upgrade in Santro Vino_David Ask the Gurus 0 12th September 2007 15:18
Speakers upgrade for Magnum Rodeo Ask the Gurus 66 11th September 2007 21:44
Should I upgrade tyres for Optra Magnum dockap Tyre & Alloy wheel Section 5 24th June 2007 14:36
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
