| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Aug 2007 Location: Chandigarh
| I have a problem!I am running fronts+sub-woofer setup. Rear speakers are powered from HU but the internal amp of HU is turned off.With fader set to rear, one can hear the vocals and music played by sub-woofer.LPF is set at 80 hz.What could be the root of problem and what is the way out!
__________________ Experience is the worst teacher; it gives the test before presenting the lesson. |
| | #3 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Which head unit? If you have LPF on the head unit set to 80Hz and are using the correct channel (subwoofer out) to hook to the subwoofer amp, there's no way the sub can play mid band. Try switching in the LPF on the amplifier and see if the mids go away. If it does, then you are using some incorrect pre-out for the sub. If you have switched off the head unit's internal amp, how are rears running?
__________________ Operator! Give me the number for 911! |
| | #4 (permalink) | ||
| Quote:
Ajay bhai rears are not working, i am using fronts+sub only.Crossovers of HU are functional and AMP is running on flat settings.
__________________ Experience is the worst teacher; it gives the test before presenting the lesson. | ||
| | #5 (permalink) | ||
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
I think Gill has an ingenious idea. Using this set up, when the car engine is running one can fade the subwoofer and front levels up there by using the amp. when the car is stationary fade the front and rears down hence the amp is now just idling. With Class D and Class AB amps this really saves the battery and one can still listen to some music while waiting in the car. Gill, just check if the XO freq. and the slope have both been set. if te XO freq has been set to 80hz but the slope is 0db/octave then you will still have fullrange coming from the subwoofer. Set your slope to atleast 12db/octave (2nd order).
__________________ Scixelsyd Etinu Last edited by navin : 14th April 2008 at 15:24. | ||
| | #6 (permalink) | |
| BANNED Join Date: Sep 2005 Location: New Delhi
| Quote:
1. Check the RCA Cable Connection, should be connected to Low RCA outputs on the HU. 2. Turn off the crossovers from the amplifiers. 3. Set the crossovers from the 9887 - Crossover Menu. 4. Check the slope setting of the subwoofer crossover. If it is 0 then the crossover is bypass. Set it to where ever it sounds better. Start with 12dB (Second Order) and choose between 12, 18 & 24 which ever sounds better. After the selection of the slope flip the phase of the sub woofer and use the one where it sounds blended with your front speakers. | |
| | #9 (permalink) |
| Just Re-checked the RCA,all is fine at this end. In 9887 there the four options in cross over menu which are like this:- And these are the current settings too. BAND Output level cut-off freq slope High 0 80 12 Mid 0 80 12 Low 0 80 12 Even when i brought down the lows to 63hz n 50hz the voacals were audible with fader set to rear but when set at 50hz the level of vocals and music went down considerable yet they are audible.
__________________ Experience is the worst teacher; it gives the test before presenting the lesson. Last edited by Gill : 14th April 2008 at 16:55. |
| | #10 (permalink) |
| BHPian Join Date: Mar 2004 Location: Ludhiana
| I believe the Cables used are good quality and connections were made perfectly well. Now what would I suggest except asking you to please clarify the reply as it can mean either of the two things, the way it's written. Isn't it?
__________________ Punjabi for Life. |
| | #11 (permalink) | |
| Senior - BHPian | Quote:
So I think there is no point discussing it further.
__________________ If you are good at something do not do it for free !!!! | |
| | #12 (permalink) | |
So according to this everything should be fine.
| | #13 (permalink) |
| any other pointers!RCAs are working fine checked them both from HU end and Amp end! I would love to learn what difference does high n mid crossovers make in my set up,when both are set at 80Hz.
| | #15 (permalink) | |
| Quote:
Anyways, I guess you were pointing towards checking the connections. Didnt automatically assume that, because checking for the most likely errors would have been the first thing that would have come to your mind, when you met Gill and Auditioned his setup. Looks like you guys hardly met for 5 minutes or so. Out station travelling means a pretty hectic schedule, I'm sure. Anyways, glad to know Gill did the needful now. So, Gill sahab, the RCA cable, that connects to the rear channels of the amplifier at one end, is correctly connected to Sub Pre-out at the other end then?
__________________ Punjabi for Life. | |
« 'Sasta Solution' -Need CD changer repair / replace advice
Advice about audio setup for Maruti 800 »
| Thread Tools | |
Similar Threads | ||||
| Anyone playing BMW m3-challenge? | akshay1234 | Shifting gears | 17 | 30th January 2008 15:07 |
| HPF & LPF settings ? | prashantk007 | Ask the Gurus | 22 | 8th June 2007 22:52 |
| Horn playing through speakers | revvedup | Ask the Gurus | 7 | 13th November 2006 00:10 |
| Problems with playing videos | karthik247 | Shifting gears | 5 | 6th February 2006 11:07 |
| Playing the pilot to the Forester | Samurai | Street Experiences | 15 | 4th January 2006 20:46 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
