Thread Tools
Old 16th April 2008, 02:37   #1 (permalink)
arpandiv's Avatar
Default Cutting open a bass tube?
I have a JBL 12" base tube with me,it wont fit in the alto boot,since there is a tray on top with the 6x9s ..an option is to put the 6x9s in boxes by the sides of the boot. and put the tube as it is,or cut open the base tube and install the woofer in a box.the tube seems to be sealed and it think the only option is to CUT it open? can i get away without destroying the tube ?
arpandiv is offline   Reply With Quote
Old 16th April 2008, 10:28   #2 (permalink)
navin's Avatar
Cant you just unscrew the woofer from teh tube and put it in a box.
__________________
Scixelsyd Etinu
Old 16th April 2008, 10:52   #3 (permalink)
DerAlte's Avatar
Maybe you could think of mounting the 6x9's in the quarter-glass area - search, there is a thread in the Show Off and Sound Off section. Then you can keep the sub tube as it is and not have to do a risky dissection.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 16th April 2008, 10:56   #4 (permalink)
Sam Kapasi's Avatar
The tube is not sealed. The 12" woofer is covered with a grill that is tightly fixed into the lip of the tube.
Pull the grill out using some force and some screwdrivers and you will expose 8 screws holding the woofer to the tube. Unscrew those and unclip the wires from the terminals and Navin is your uncle.
__________________
Live the YetiLife®
Old 16th April 2008, 11:02   #5 (permalink)
navin's Avatar
Originally Posted by Sam Kapasi View Post
The tube is not sealed..
Of course not it is ported!
__________________
Scixelsyd Etinu
Old 16th April 2008, 13:16   #6 (permalink)
iraghava's Avatar
You can remove the grille by inserting a screwdriver where the grille sits on the enclosure & prying it out by using a little force. I recently had to do this & the grill came out without any problem.
And Navin is your uncle.
What happened to Bob?
__________________
Power corrupts. Absolute power is kind of neat.
iraghava is online now   Reply With Quote
Old 16th April 2008, 14:25   #7 (permalink)
navin's Avatar
He's still here (staying in Lokhandwala, Andheri) . He refuses to go back to his home land as long as Pres. Bush is in charge. Right now he is havnig a whole lot of fun doing bit roles in Indian movies and adverts. here is what he looks like.
Essential UG-- God Men Con Men
__________________
Scixelsyd Etinu
Old 16th April 2008, 17:05   #8 (permalink)
arpandiv's Avatar
thanks for the inputs,
decided to presently let the tube be in the boot,will dump the tray holding the 6x9 and instead mount them on the boot door. will try via different placements/putting sub in a box later as the days progress.
Old 16th April 2008, 17:18   #9 (permalink)
Technocrat's Avatar
Be careful Arpan the VXi has rear wiper & placing the 6X9 might damage the wiper set
__________________
The Holy Trinity: Traction, Torque and Tarmac
Thread Tools
installing a bass tube bmdesai1987 Ask the Gurus 21 11th October 2007 01:33
Bass Tube or Woofer Enclosure....... funkydevil Product Discussions 8 9th October 2007 11:22
For Sale - JBL Bass Tube Revvhead Shifting gears 8 18th July 2007 09:32
DDIY - Bass Tube gunbir DIY - Do it yourself 11 1st April 2007 14:30
Which is better - Bass tube or s/w? panky12345 Product Discussions 16 7th August 2006 23:21
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
