Thread Tools
Old 7th February 2005, 18:04   #1 (permalink)
Default Fitting a sub-woofer
Am toying with fitting a a sub to my Vtec for "effective" listening
Need info on
1: Can it be fitted to an existing 4 channel amp (there is no separate channel from the head unit) ?
2: Should I mounted a woofer in the parcel shelf or go for anenclosed system in th boot ?
Any brand recommendations would be appreciated ?
Old 7th February 2005, 18:23   #2 (permalink)
Superb, so now we have two thumping Vtecs on board!
Absolutely!
On the parcel shelf. For convenience among other things. But have the hole professionally cut with electric cutters. Dont let the local guy use a hammer..
Just shoot ahead and pick up a Pioneer TS-W305C 800W subwoofer. What is the power ratings of your amplifier?
My Vtecs sound system (My Vtec's Sound system!)
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 7th February 2005, 18:24   #3 (permalink)
iceman91's Avatar
well if you want to put a subwoofer for maximum efficency a enclosure is recommended...else you can go in and mount it on the shelf but you will need to change the shelf, put in a thicker mdf plank.
about the amplifier..:
if its a four channel its not a problem as long as you can bridge it. that way bridge two channels and run your sub with it on the lpf mode. if it does not have an lpf then you might have to buy a crossover or equaliser. also you dint mention what head unit do you have?
personally, if i wanted ot put in a sub and was a little tight on the budget i would buy these tubes which have a built in amp and are perfectly built to the enclosures. no headache in installation and minimum cutting to the car.
good brands are:
jbl
alpine
sony
they all have tubes with built in amplifiers
else for a good subwoofer:
the usual: pioneer,sony,kenwood,alpine,jbl
expensive: kicker,jl audio,rockford fosgate,momo by polk audio
amplifiers same categories.
__________________
WANTED: A Pair of Carbonfibre Cajones!!!!
iceman91 is online now   Reply With Quote
Old 7th February 2005, 19:50   #4 (permalink)
Rudra Sen's Avatar
Hello SIR!!
Why don't you spend some time inside my Optra and decide??
Do let me know if I have to bring the car on the golf course...
Old 7th February 2005, 21:49   #5 (permalink)
Originally Posted by Rudra Sen
Hello SIR!!
I did that night when I drove it - hence the inspiration
Old 7th February 2005, 22:25   #6 (permalink)
Rudra Sen's Avatar
So what next? A better system? Top of the line?
Interested to know.
Old 7th February 2005, 22:47   #7 (permalink)
aadix's Avatar
u have a sub in ur optra rudra?
__________________
"live to ride,ride to eliminate"
aadix is offline   Reply With Quote
Old 7th February 2005, 22:51   #8 (permalink)
Rudra Sen's Avatar
Yeah. an ordinary type from Blaupunkt. Does it's work though
Old 8th February 2005, 08:09   #9 (permalink)
Am not looking for something fancy - my system is biased towards mid to high range, need some kick to it
Old 8th February 2005, 09:32   #10 (permalink)
iceman91's Avatar
if you wanna go rudra's way..you cant go wrong. he has one sweeeeeeet setup in his car.
__________________
Old 8th February 2005, 09:52   #11 (permalink)
tabrez02's Avatar
Dear Ajmat
You never told us which AMP you have and how much watts it is. Cause this spec is important to know which sub you have to go for.
I prefer you go for an enclosure kind of a setup inside your car boot and have an AIR out hole made on the rack behind in the middle. I would suggest only pioneer as GTO, as i tried lot of subs but i was not able to get an optimum bass out of the others but the pioneer has a very good bass dept comparing to others. Last but not least, Your wiring has to be good. I mean the wires used for the power and wires used for the subs should be of a good quality and thick(these are special wires for audio). However you get a wiring kits (ex: Boss kits) for these kinds of setup.
__________________
Tabrez
tabrez02 is offline   Reply With Quote
Old 8th February 2005, 19:25   #12 (permalink)
Originally Posted by tabrez02
Dear Ajmat
Sorry, it's a 2 channel - 120 watts X 2 (Pyramid PB440X) - not sure whether this is adequate
Old 11th February 2005, 20:53   #13 (permalink)
Rudra Sen's Avatar
Default Thumping VTEC takes over BLR roads
You can see a jet black VTEC passing by with Mark Knopfler’s latest ‘Shangri-la’ playing. Deep bass to heightened that mean black look.
Sodium vapor lamps dancing past the bodyline. Flat solid alloys rolling black on opposite direction with stroboscopic effect…
There goes our Ajmat. Powered by James B Lansing four channel amp and mama of sub woofer to paint the town red.. oops, black.
I’m glad to pass on my ‘king of bling’ title to Ajmat.
Like a true sportsman I must allow the others to take the pole position.
Old 11th February 2005, 21:51   #14 (permalink)
Naaa, yours is still bigger than mine - the wheels , I mean
Old 11th February 2005, 22:45   #15 (permalink)
would love to see pictures of ur audio setup ajmat.
cheers
heavy_foot is online now   Reply With Quote
Thread Tools
Fitting ABS in Aveo 1.4 LS Raj'sGlory Technical Stuff 4 13th May 2008 12:20
Reliable place for fitting....... funkydevil Ask the Gurus 0 7th October 2007 02:12
Fitting max MP3s on a new CD kkdelhi Gadgets, Computers & Software 14 26th June 2007 09:43
Muffler Fitting in Hyderabad torque4u Modifications & Accessories 2 3rd November 2006 12:08
Accord Woofer and Amp fitting Sahil Ask the Gurus 5 26th May 2004 14:06
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
