Thread Tools
Old 22nd April 2008, 11:47   #1 (permalink)
Smile Advice about audio setup for Maruti 800
hello!
i am planning to install an audio system on to my Maruti 800 (2001 model)
i have zeroed upon a few specs, here they are
Pioneer any model between – 7000k to 8000k
JBL GT 936 or 937 – 4000k to 5000k
Speaker box – 850
Wiring and labor – 2000
I HAVE A BUDGET OF 15000 TO 16000
i am thinking of even installing a Sony 2 channel amp. all the above will com with a bill and warranty.
i got these specs from a dealer named Sprocket in Koramangala, Bangalore (Bangalore guys would know, i guess). so i would like to ask a couple of questions?
1. Should i go in for the stock wiring or go for a better wiring system?
2. Should i mount the rear speakers on a plank or install them with speaker boxes vertically in the rear? which one would give me good accoustics?
3. Will the 2 channel amp be sufficient for me to install a subwoofer later on?
i would be greatful if you guys give me valuable opinions on this issue.
Thanks, regards
Gautam.
gautamsnn is offline   Reply With Quote
Old 22nd April 2008, 18:37   #2 (permalink)
Team-BHP Moderator
DerAlte's Avatar
Sprocket is a good dealer, but - his prices are normally higher and not sure if he has good installers.
1. Search for the thread on installers and ICE shops in Bangalore - maybe one of them will be more suitable for you
2. Search in the Sound Off and Show Off thread for any installations in M800 - this can give you a good idea of the possibilities (don't get scared of one of the installations which has huge square woofers in the back and only 2 seats)
Your choice of equipment is OK, though instead of Sony you could think of JBL, Blaupunkt, Panasonic, Pioneer or Alpine amplifier. You will need a 4-ch if you want both the speakers and the sub on the amp.
JBL GTO 937 should cost you less than 4500 if you bargain well (if you can, look in at Sound Factor, the JBL brand shop on Lavelle Road - you can audition the speakers there).
If you can search for the thread (in the SO-SO section) which shows a neat installation in an Alto, maybe you could think of mounting the speakers in boxes on the quarter glass - saves you the hassle of the parcel tray.
Since the 6x9 can only go in the rear, your sound stage will be totally in the rear - not really recommended. May be other TBHPians can advise whether you can mount 6.5" components in the front door (door pad) instead. Costs slightly more, but the difference in listening experience when you are driving is quite a lot. Unless you listen to music REALLY loud, you will be able to avoid the amp but still have a good system.
If you go step by step, you will be able to add a 4-ch amp and the 6x9 later. Next step after that - add the sub, driving the front and sub via amp, with the 6x9 driven from the HU.
I doubt if the 2001 M800 comes prewired, but even if it does it is better to use a good wiring kit (avoid Boss and such).
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 22nd April 2008, 19:03   #3 (permalink)
sonic_boom's Avatar
After amping my 6x9s with the gto75.4 , the quality of sound has improved tremendously. I recommend it highly.
__________________
If 10% of road accidents are due to drunken driving then 90% of accidents are due to driving without drinking...Hmmm...
sonic_boom is offline   Reply With Quote
Old 22nd April 2008, 22:59   #4 (permalink)
Default @ DerAlte
thanks for the information! i am much better informed now..
as you mentioned, I think SoundFactor will be a good option for me.. I will also try to do some R&D at Audio Fusion( i heard through a lot of posts that Anwar at AF is really good).
i already have front speakers under the dashboard as i have a Blaupunkt tape player right now..so do you think that will an ok substitute for the front speakers?
Can you also tell me which Pioneer HU will be good? i dont necessarily need a USB port but if i can plug in my Creative MP3 player it would be great!
what sort of wiring would be the best for my audio setup?
thanks again for the info!
peace!
Thread Tools
Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! Sam Kapasi Ask the Gurus 8564 21st August 2008 00:59
Advice needed for high end audio setup for my car Aryaan Ask the Gurus 9 12th September 2007 10:40
Maruti likely to renew Maruti 800 with a brand new car askicode The Indian Car Scene!! 32 13th February 2007 11:57
New ICE Setup advice!!! furioussphinx Ask the Gurus 20 29th June 2006 00:06
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
