| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #16 (permalink) | |
| Senior - BHPian | Quote:
Now, who was that SOB? Would wack the hell out of him for saying that. ![]() Frankly, I wasn't recommending him those. But just mentioning some of those brands for which a demo isn't easy. But thinking again, some of those few are within his budget, like the Illusion (electra), Hertz (Dieci & energy) etc..
__________________ The squeaking wheel doesn't always get the grease. Sometimes it gets replaced!! Last edited by speedzak : 24th April 2008 at 18:47. | |
| | #17 (permalink) | |
| BHPian Join Date: Sep 2007 Location: Bangalore
| Thanks for the detailed suggestions zak. Quote:
Looks like its pretty lengthy, sorry for that.
__________________ Ford Ikon Flair 1.3 2004 Bullet Electra 2003 Safari 2.2 VTT EX Pearl White | |
| | #18 (permalink) |
| Senior - BHPian | You're most welcome. The doubts about the Jvc amp, it would be better if we could see the model number of it. Yes, 55w per channel @ 4 ohms sounds a bit on the unhappier side. But more details on the amp may prove it better. We understand your tight schedule baba! So, the suggestion to do your homework as much as and whenever possible. It will help a lot in gaining good satisfaction levels later. Rest, as we said! Just log on to team-bhp and shout. Somebody will come up with assistance.
__________________ The squeaking wheel doesn't always get the grease. Sometimes it gets replaced!! |
| | #19 (permalink) |
| The JVC Amp is, KS-AX3500. Welcome to JVC India Specs: Max. Power Output of 580W Continuous power (RMS) of 55W/channel, into 4 ohms, 20Hz - 20kHz, at less than 1.0% total harmonic distortion 4-, 3-, or 2-Channel Operation Class-AB Circuit MOS-FET Power Supply Converter Variable Input Level Control (0.3 - 6V) LPF ON/OFF Switch Gold-Plated Input Terminals (Power) Gold-Plated RCA Jacks Speaker Input Connector Balanced Input 2-ohm Stable Operation Over-Temperature Protection Overload Protection Short Circuit Protection DC Offset Protection Soft Start Anti-Pop Circuit
| | #20 (permalink) | ||
| Team-BHP Moderator ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
Any of these will fit in the Safari stock location. The 5xx is a 5.25" speaker, and 6xx is a 6.5" speaker. While you are at it, check the prices of Vc172 and Vc132 (Velocity range) components also from the Blaupunkt dealer. If you are buying everything Blau, you may get a decent discount on these and then these will be within your budget. The Blau coax THx should cost you LESS than the THc components - anomaly in the prices you have mentioned. Quote:
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | ||
| | #21 (permalink) | ||
| Quote:
![]() Quote:
![]() I shall definitely check all the options available in component series of Blaupunkt before choosing one. Atleast auditioning all the speakers there can give me a better picture on relative performance. Any songs that you can suggest which covers the entire freq spectrum, a 70% accurate test cd types that I can take with me for audition. What is your opinion on Illusion speakers when compared to Blaupunkt. ? I can see that they are very popular among bhpians.
__________________ Ford Ikon Flair 1.3 2004 Bullet Electra 2003 Safari 2.2 VTT EX Pearl White | ||
| Thread Tools | |
Similar Threads | ||||
| Safari 3.0 dicor or 2.2 VTT dicor ? | tabrez02 | SUVs, MUVs & 4x4s | 18 | 4th September 2008 11:39 |
| Safari TCIC LX or Safari DICOR LX | arindam | SUVs, MUVs & 4x4s | 19 | 10th January 2007 16:42 |
| Safari DICOR Lx | vnagarajs | SUVs, MUVs & 4x4s | 2 | 11th December 2006 16:36 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
