Thread Tools
Old 2nd May 2008, 00:32   #1 (permalink)
abhinav.gupta88's Avatar
Default Ice For Soon Coming Rs
Hows this for ICE for my soon coming RS
Front Speakers to be retained
Middle Speakers ( near the rear door latch to be retained )
The Head Unit ( Alpine 9830) to be retained
Changes :
JBL or Kicker Sub / Bass tube ( 10 or 12 " )
JBL components for the rear
Mono Blaupunkt Amp for the sub - Blaupunkt
A two channel Amp Blaupunkt / Kicker for the rear components
Please advice my budget is around 50000( not even a rupee more)
__________________
VTEC NHC AND RED SKODA OCTAVIA vRs (LAAL PARI)
WHY IS EVERYTHING ELSE SO SLOW !!!
-=]|Do The Dew|[=-
Old 2nd May 2008, 00:54   #2 (permalink)
iraghava's Avatar
Why Components in the rear & stock speakers in the front? Will you be driving the car yourself or are you going to be driven around in it?
And any specific reason for choosing Kicker? I don't know much about ICE but from what I gather there are better products than Kicker available at a similar price point.
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 2nd May 2008, 01:32   #3 (permalink)
I will drive myself. Not driven around.
Well someone told me about the fact that the front speakers are components only and are good enough but the rear ones are not good quality.
i was recommended Kicker by a friend. please advice me if anything better in same price
Also someone please tell me prices for the
1. JBL components for the rear.
2. JBL Sub 12 inch
3. Kicker Sub 12 inch
4. Mono Blaupunkt Amp for the sub
5. two channel Amp Blaupunkt / Kicker for the rear components
__________________
-=]|Do The Dew|[=-
Old 2nd May 2008, 10:28   #4 (permalink)
low_bass_makker's Avatar
I would any day recommend a 6.5 inch component kit in the front and a sub in the back (not in tube) and a 4 channel driving them both.
__________________
If you are good at something do not do it for free !!!!
Old 2nd May 2008, 10:58   #5 (permalink)
shuvd's Avatar
Kickers are SPL I think. They play really loud. But, I like.
A 10" Kicker cost me around 10k about an year back.
__________________
I (still) feel the need...the NEED for SPEED
shuvd is offline   Reply With Quote
Old 2nd May 2008, 11:04   #6 (permalink)
Team-BHP Moderator
navin's Avatar
Changes :
The Middle speakers are really just a tweeter, the woofer for this tweeter is in a pod behind your ears.
If I had 50K this is what I would do...
1. Keep the 9830
2. Damp front doors with something like Noise kill 4K
3. Upgrade front components to JBL/Blau/ etc..6K
4. Get 2 4ch amps for 14K (Kenwood, Blau, JBL, Pioneer etc all make one) bridge 4 channels (out of the 8 channels you get) for use with 2 subs.
5. Get 2 10" woofers fro JBL/Blau/Ground Zero 12K - look at Bhagwan's RS install pics he has a box for 2 woofers (ok Bhagwn isusing a woofer with a passive radiator but the box design can be the same).
2 10" woofers are lighter and easily driven by 150W rms that the 4 ch ap will deliver. 10" woofers need a smaller box than 12" woofers hence you can get by with a 2.5 cu. ft. box (say 30" width x 14" height x 12-16" tapered depth). installed snug against your rear seat.
6. Get a pair of coax in the rear pods and dummy the front tweeters they really dont help the sound 4K
7. 3 pairs of RCA wire (Audison, Monster, etc.) - 6K
8. Good Power cable 4 GA from battery to dist block, 8 GA from dist block to each amp. - 4K
__________________
Scixelsyd Etinu
Old 2nd May 2008, 12:47   #7 (permalink)
But i heard that the front are already components and function quite well.
and shouldnt the rear coaxs be connected to the amp.
__________________
-=]|Do The Dew|[=-
Old 2nd May 2008, 13:40   #8 (permalink)
Team-BHP Moderator
navin's Avatar
the front speakers and rear speakers are components. the rear speaker has a woofer behind the rear seat and the tweeter in the rear door.
if you see my earlier post i suggested 2 4 ch amps. this will give you 8 channels of power.
I have linked just one of these below, the specs of the others (JBL, Pioneer, Blaupunkt) are comparable
Kenwood - KAC-8404
as you can see you will get about 4 x 50W rms. When 2 chanels of any of these amps are bridged it will give about 150Wrms. So if you bridge 4 channels (out of the 8 channels) you will get 2 x 150W and 4 x 50W. Use the 2 150W channels fo the 2 10" subs (150W is a bit shy for a 12" sub) and use the 4 50W channels for the front and rear speakers.
BTW just to inform you there is a cheaper Sony amp also available in India. While it has adequate power, many at TBHP find it a bit grainy so beware of this. Also many at TBHP have had problems with BOSS and other such "unbranded" RCA wire. It is safer to stick to better brands like Audison and Monster. In some cities Ground Zero RCA cables are also sold, I am not aware about where but Bass&Trouble (TBHP member) will know more about this.
__________________
Scixelsyd Etinu
Old 2nd May 2008, 16:08   #9 (permalink)
Ground Zero both 10 " subs individually 12 k
or together 12k?
also wanted to know whether the HU has a aux port or not?
__________________
-=]|Do The Dew|[=-
Thread Tools
The Chinese are coming! hollywoodhogan Motorbikes 17 2nd February 2008 21:08
When is the new Accord coming? kumar2007 The Indian Car Scene!! 3 11th September 2007 14:53
Coming up BMW's M1 following the new M3 highwayblaze The International Automotive Scene 11 8th May 2007 00:34
Coming out of the shadows determinus Introduce yourself 18 27th December 2006 11:48
New BMW 3 is coming! amit The International Automotive Scene 11 2nd November 2004 01:11
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
