Thread Tools
Old 9th May 2008, 14:30   #46 (permalink)
Team-BHP Moderator
navin's Avatar
Originally Posted by greenhorn View Post
tired with a DIY isolation ring made out of double sided foam tape for one of the speakers....
try butyl rubbber. shore hardness 60.
__________________
Scixelsyd Etinu
Old 9th May 2008, 18:35   #47 (permalink)
greenhorn's Avatar
Where can i get them from I mean, in what kind of shop should i ask for them.
Either way, here are the pics as promised
The mid bass as initially installed. There was no seal, and sound was leaking through the slots cut for the grille that came with the car. Also, the seal around the base of the driver wasnt exact either
used foam tape to cover the base of the grille that came with the speakers
After installation - yes i know it is very dusty inside !
the white foam does look a bit unsightly, but managed to hide it with black permanent marker
The end.
Well It aint over yet. The rear plank will hopefully be completed by tomorrow, and then the rears will join the party!
__________________
2007 Indica DLG
My next Truck will be a Safari!
greenhorn is online now   Reply With Quote
Old 9th May 2008, 21:36   #48 (permalink)
greenhorn's Avatar
some googling for the door panel vibration issue dug up a novel idea. squeezing bottles of water ( the type of bottle distilled water comes in) into the door pockets. now that's a novel idea for mass loading the door panels
And of course the water can come in handy on a sunny day
Got something to do for tomorrow then !
__________________
2007 Indica DLG
Old 9th May 2008, 23:13   #49 (permalink)
Team-BHP Moderator
navin's Avatar
I get rubber sheet and cut it. In Mumbai we have a place called Lohar Chawl where such stuff can be found. You just need to know what you are looking for.
__________________
Scixelsyd Etinu
Old 10th May 2008, 09:49   #50 (permalink)
greenhorn's Avatar
A small doubt. really want to put up the Hertz stickers on my car, but I've heard that one of the best theft deterrents is not to advertise what you have on the inside.
I really want to put the hertz stickers, but then again, i want my ICE( and car) to stay in my hands.
A friend of mine suggested that some partially informed thieves might , on seeing the hertz label on a white Indica, mistake it for a Hertz rental car
what do you guys think - should i put the stickers on or not
Request to mods: can the thread title be changed to "ICEing the Indica for SQ in a 20K budget" and moved to the DIY/Showoff forums if required
__________________
2007 Indica DLG
Old 10th May 2008, 10:08   #51 (permalink)
Team-BHP Moderator
DerAlte's Avatar
From any "panchar" shop - inner tubes of bus or truck tyres! Your double-sided tape formula is only a psychological solution both for preventing vibrations and sealing air leakage.
Why is the Hertz logo showing up reversed on the grill?
Wonderful DIY job. Well done, keep up the good work!
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
DerAlte is online now   Reply With Quote
Old 10th May 2008, 10:11   #52 (permalink)
greenhorn's Avatar
those are of the right door actually
Reversed them to maintain a consistency in the pictures
Thanks DerAlte. I A/B'd my left and right speakers, to check it made a difference- and there was !
I'm not sure how long the foam will last though
I suppose the rubber is a better and more long lasting solution
__________________
2007 Indica DLG
Old 10th May 2008, 18:27   #53 (permalink)
greenhorn's Avatar
Ok, tried the water bottle experiment. Didn't expect a lot of difference, but it didnt make any difference :(
oh, and the mdf plank seems to be taking longer than expected , and the guy from the shop seems to have stopped picking up my calls. The last was when i called him to tell that mine was not a bone stock indica , and that he might have to cut a bit off the plank in the rear to accommodate ( what i think is ) the rear de mister.
I have the feeling this guy thinks I'm too much trouble . I'll call him again on monday. let me see...
__________________
2007 Indica DLG
Old 13th May 2008, 21:32   #54 (permalink)
greenhorn's Avatar
One week after i ordered , still no plank
First he said no vinyl finish, then today morning he says they cant ( or rather are *Extremely reluctant* to) buy rexin just for this one off case.
Bah, I don't have a choice. carpeting it is
He said it will be ready by tomorrow afternoon.
Btw, turns out the folks at sharleo were the ones who were fabricating the rear plank after all !
__________________
2007 Indica DLG
Old 13th May 2008, 22:25   #55 (permalink)
redfire's Avatar
Infractions: 0/1 (7)
Default DIY is the way
Hi Green, good going. DIY is the way. I have decided it and will be starting soon. First step is to gather accessories. Now I have all the ICE equipments in my car playing with ordinary cables and installation, the next items to be sourced are quality cables, wires and damping material. I have already spoke to B&T and decided on GZ/Ichibahn/Illusion cables and wires plus noisekill. Power cables are not finalised (Finolex/L&T are also considered). Once I gather all things, will be starting DIY.
Santhosh (sharleo) is a good friend of mine too. I have talked to him once regarding installation and he said he can arrange it. But as you told, I strongly feel DIY. So let us try. Buzz me for any help / helping hand while DIY. Wish you all the best.
__________________
jay
Most automobiles problems are caused by the loose nut that connects the steering to the saddle
redfire is online now   Reply With Quote
Old 13th May 2008, 22:38   #56 (permalink)
greenhorn's Avatar
do post the pix of your damping . If the gurus feel that he (santhosh) does a good job, I might also feel tempted to follow. My front door really needs some.
If its being done on any weekend, maybe i could join
__________________
2007 Indica DLG
Old 14th May 2008, 00:04   #57 (permalink)
leodelg's Avatar
if it is some time in june, then i might tag along too. I'll be moving back to tvm on june 1st and i want to get my system tuned. Maybe we can have a mini TBhp meet at Santhosh's place!!
__________________
2005 Baleno Vxi
1998 Splendor (Still going strong)
leodelg is online now   Reply With Quote
Old 14th May 2008, 07:50   #58 (permalink)
arif_t01's Avatar
Put a Hertz Non-Rental Car sticker
__________________
Trying To Discover A New Identity!
arif_t01 is offline   Reply With Quote
Old 14th May 2008, 09:08   #59 (permalink)
Sankar's Avatar
Jay when do we get to listen to your setup?
__________________
"Auto racing, bull fighting, and mountain climbing are the only real sports... all others are games."
Ernest Hemingway
Sankar is online now   Reply With Quote
Old 14th May 2008, 10:53   #60 (permalink)
redfire's Avatar
Hey Sankar bro - any time. Are you guys back home from official trip? I think I can drive to your office today evening. BTW hoping that you will be there first hand to help me in DIY.
__________________
jay
Thread Tools
Pls suggest me a good ICE installer in Chennai kpkeerthi Ask the Gurus 88 4th July 2008 19:49
Looking for a good second hand ride - suggestions please redsfx Hatchbacks 39 21st December 2007 21:47
fiesta ice -- 15k and pune installer.. suggest please ronk Ask the Gurus 21 27th September 2007 01:20
Reliable ICE Dealer/Installer in Pune carboy Ask the Gurus 8 16th July 2007 15:38
Good dealer and installer for K&N in Bangalore ? Nikhilb2008 Motorbikes 11 18th December 2006 16:12
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
