Thread Tools
Old 3rd May 2008, 19:00   #1 (permalink)
abhinav.gupta88's Avatar
Infractions: 0/1 (4)
Default Hows this Configuration
JBL GTO 75.4
JBL GTO 601.1
Kicker: 05C124 - COMP 12" 4-ohm subwoofer
Illusion Components( 1 set )
Can you guys tell how is this config and what is the price of the individual items.
__________________
VTEC NHC AND RED SKODA OCTAVIA vRs (LAAL PARI)
WHY IS EVERYTHING ELSE SO SLOW !!!
-=]|Do The Dew|[=-
Old 3rd May 2008, 19:05   #2 (permalink)
ramie2400's Avatar
I think you already had a thread,about the audio setup for your forthcoming RS?
Could have updated the same.
Illusion Audio Compos 6690/-
Ground Zero 12XD-AL DVC Subwoofer 500WRMS 13000/-
JBL GTO 3001 Monoblock 9000/- (not sure)
Kenwood 8401 4channel amp. 5200/-
this would be great
Mods:Please merge the thread..Thankyou
Old 3rd May 2008, 19:12   #3 (permalink)
Have the prices increased by Rs 200 for both these? or you have added your margin?
__________________
If the speed of light is 3x108 m/s, what's the speed of darkness?
nishantgandhi is offline   Reply With Quote
Old 3rd May 2008, 19:15   #4 (permalink)
Bass&Trouble's Avatar
It must be a typo, for as far as I know, in Delhi only LBM holds exclusive rights to commissions.
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Old 3rd May 2008, 19:16   #5 (permalink)
ramie2400's Avatar
now you came to know the secret AFAIK Kenwood 8401 is short of availability this what rate i hear about 3days back rest i mistakely wrote 6690 for 6490/- hehehehehe..cheers
Old 4th May 2008, 14:39   #6 (permalink)
Hmm. And what are the latest prices for JBL GT5-A604 and Blaupunkt GTA4 Mk II Special?
__________________
Old 4th May 2008, 14:51   #7 (permalink)
low_bass_makker's Avatar
Originally Posted by abhinav.gupta88 View Post
JBL GTO 75.4
JBL GTO 601.1
Amps are good. I would suggest a better woofer here like JBL, GZ . Listen to few more brands of components before finalizing.
Also driving a single sub on a 600.1 would not do justice to the amp. You can drive two subs on it.
Old 4th May 2008, 15:14   #8 (permalink)
One more sub i found was
KICKER-06S12L52-2007-RANGE
  • 12" L5 2007 range subwoofer
  • Size (IN., CM): 12, 30.5
  • Impedance: Dual 2-ohms (can be wired as 1-ohm or 4-ohms)
  • Cone Material: Mica-filled poly/Alum dep
  • Surround Material: Santoprene rubber
  • Sealed Box Volume (cu ft) 0.88 - 2.0
  • Ported Box Volume (cu ft) 1.75 - 3.25
  • Dual Voice Coil
  • Sensitivity 88.8dB
  • Frequency Response 20-100 Hz
  • RMS Power Range (Watts) 600
  • Peak Power Handling (Watts) 1200
  • Top Mount Depth (inches) 6-3/4
  • Cutout Diameter or Length (inches) 11
  • The Solo-Baric L5 is available in 2-Ohm or 4-Ohm DVC.
Is this good.
Also I cant find out any information on the Ground Zero Subs. Can someone help me with some specs of a good 12" sub from ground zero or any other which can go with the JBL 601.1 marked at
  • 424 watts RMS x 1 channel at 4 ohms and ≤ 1% THD
  • 580 watts RMS x 1 channel at 2 ohms, 14.4V supply
Also Which components will be better than illusion in the 8000 range
__________________
-=]|Do The Dew|[=-
Old 4th May 2008, 16:54   #9 (permalink)
Magma's Avatar
for ground zero subs and illusion compnents informations you can contact Bass&Trouble (fellow member)
Also check hermitaudio.com
__________________
An expert is someone who takes a subject you understand and makes it sound confusing.
Magma is offline   Reply With Quote
Old 4th May 2008, 16:59   #10 (permalink)
Magma's Avatar
JBL GTO 75.4
JBL GTO 601.1
4channel amp and only 1pair of speakers?
good choice only if you are thinking of adding rear fill later,otherwise 2channel amp would suffice.
Alternatively i am sure you have thought of bridging 2 channels of the 75.4 and driving a woofer and using the other two to drive the illusions.
__________________
Old 4th May 2008, 17:01   #11 (permalink)
Magma's Avatar
i can second ramie on this
the KAC8401 is getting harder to find now(mumbai) that the new series is here and thus the premium.
i just got mine 4 days ago and ran pillar to post trying to get 1
__________________
Old 4th May 2008, 20:36   #12 (permalink)
M not looking for kenwood. Somehow dont like its stuff.
I will take the RS and dont know whether should connect the front sets( stock ) to the amp or just bridge the 4 channels into 2 ?
also
guys temme which one is better :
GROUNDZERO Radioactive Subwoofer
GZRW 12 XD-AL
30 cm 500 watts, cast basket, 2 inch 2 x 4ohm, Alucone, woven in leads, Xmax 18mm, SPL 91,4dB Rs. 11,990
GZRW 12 XS-AL
30 cm 500 watts, cast basket, 2 inch 1 x 4ohm, Alucone, woven in leads, Xmax 18mm, SPL 91,4dB Rs. 11,990
( The only difference is the 2 inch 1 x 4 ohm or 2 inch 2 x 4 ohm)
And lastly wanted to ask what size components will fit in the Skoda Octavia RS
__________________
-=]|Do The Dew|[=-
Old 4th May 2008, 21:13   #13 (permalink)
Thats not what i had in mind.
the 75.4 will either run the 2 comp. at the rear after bridging 4 into 2
or
they will be connected to the front stock ones.
The Sub would be run through the 601.1 JBL Monoblock
__________________
-=]|Do The Dew|[=-
Old 4th May 2008, 21:25   #14 (permalink)
GZRW 12 XD-AL
GZRW 12 XS-AL
Ya both are the same only difference as you pointed out is impedance.
Old 4th May 2008, 22:25   #15 (permalink)
Which one would be better? 2 x 4 ohm or 1 x 4 ohm
__________________
-=]|Do The Dew|[=-
Thread Tools
Whats your computers configuration? GTO Gadgets, Computers & Software 1023 12th November 2008 21:34
Help Computer Configuration BUSA Gadgets, Computers & Software 267 8th September 2008 14:16
Configuration For Multitasking PC MADMAX111 Gadgets, Computers & Software 19 27th March 2008 11:28
Hows it Going? vcash Introduce yourself 14 11th January 2007 19:43
Hows this possible? DCEite Shifting gears 8 7th January 2007 09:39
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
