| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #2 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| All CDs? Some CDs? Same place in the same CD (even after ejecting and re-inserting)? Random? Car in motion or standstill? Subwoofer on / off? ![]()
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #4 (permalink) |
| Could you please try with sub off? Probably you need to get your unit serviced properly - might just overcome the odd loose connection in the unit. By skipping I hope you mean the abrupt "chhik ... chhik" type of noise that comes, not short periods of silence. If it is periods of silence, then the problem is something else.
| | #6 (permalink) |
| OK, now that is different - nothing wrong with the CD player. Possible causes: * If all channels AND sub go off, Intermittent loose contact in the HU, OR * If only one of [front, rear or sub] goes off, the appropriate connection to the amp is having loose contact You haven't mentioned your ICE configuration. You were having doubts about 2ch/4ch amp, and you wanted to connect an iPod. So do you have 2 speakers or 4?
| | #8 (permalink) |
| OK, easy tests: 1. Do BOTH the sub and the speakers go silent when the CD music stops intermittently? If so, there is a loose contact in the CD player. 2. Does this happen also while playing FM/AM radio? If yes, then the HU amp is overheating (borderline) and cutting out in that situation
| | #11 (permalink) |
| BHPian Join Date: May 2006 Location: Nagpur
| Get your lens cleaned. This sounds like you have dust on your lens. You can run a cleaning CD, or open the HU and get the lens cleaned. And if you do remove your HU to clean the lens, do not forget to check for any loose connections on the rear. |
| | #12 (permalink) |
| OK. Could be a simple loose contact, or dust on the travel mechanism, or could be a bad lens (less likely, since you have already cleaned it). Any chance of getting the HU serviced in Patiala?
| Thread Tools | |
Similar Threads | ||||
| cd player | sankeerthreddy | Ask the Gurus | 9 | 24th January 2007 03:49 |
| Service centre required for LG CD-player/writer cum DVD player | benbsb29 | Gadgets, Computers & Software | 0 | 18th January 2007 11:58 |
| Sony (CDX - R33300S S-Mosfet) sound skips !! | navdeep | Product Discussions | 14 | 31st October 2006 17:16 |
| Mp3 Player Or Cassette Player With 12 Cd Changer. | zulfikar | Ask the Gurus | 6 | 20th March 2006 14:55 |
| Cleaning the car CD player lens | mohit | DIY - Do it yourself | 13 | 11th July 2005 18:05 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
