| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #16 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| @ragzv, an amp and new wiring will only improve what is already good - no way that it will remove inherent faults. Get your system tuned well first, and only then look at adding more stuff. Get together with Kolkata TBHPians, listen to their set ups and discuss with them what should be done. Perhaps it will be a good idea to take one of them along to the installer.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #17 (permalink) | |
| BHPian Join Date: Oct 2007 Location: Kolkata
| Quote:
1. Compos should go to the front doors rather than rear parcel shelf 2. The fit should be proper But the compos has already been installed in the rear with few modifications, will it not spoil the setup further if i remove and try to put back the stock speakers. I have pmed razor4077 for help.
__________________ Raghav | |
| | #18 (permalink) |
| Exactly. When you are in the driver's seat, most of the 'good' sound from the Boston components on the parcel shelf is already attenuated by the time it reaches you! No, putting the stock speakers into the rear location will not spoil it any further. Simple MDF fix! In fact, you can check if 6x9 coaxials will fit in the parcel shelf location. A pair of ovals, with their deeper bass than the stock speakers, will be far better (for the time being) than buying an amp immediately. Can't visualize without pics, but I guess they can go in on MDF spacers and still look elegant. Once you are used to a good system, adding an amp will take you to the next level. ![]()
| | #19 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Boston Acoustics is a company of good repute and they make good car audio speakers. One cannot compare. There might be people that prefer the Boston to the JBL. It depends on your ears.
__________________ Live the YetiLife® | |
| | #20 (permalink) | |
| BHPian Join Date: Nov 2007 Location: mumbai
| Quote:
new wiring and amp is secondary. First fix what is needed As both of us suggested , put the compos in front and nippons in the back(no problem if the nippons are not "airtight fit" as you say,they are just fillers anyway.Just use some spacers and fit them if the metal is too bent) And no the speakers wont get spoilt by removing and re fitting If you ever do install an amp make it a VFM 4 channel (if on budget) and give two channels to the compos and bridge two for the sub(if you have plans for that)-you should end up with a nice system You dont need to change the rear wiring if your gonna run the nippon (if kept in rear)speakers from the stock HU.the stock wires are good enough. just have the wiring checked
__________________ An expert is someone who takes a subject you understand and makes it sound confusing. | |
| | #21 (permalink) | |
| Team-BHP Support ![]() | Quote:
__________________ Life is short - Break the rules, Forgive quickly, Kiss slowly, Love truly, Laugh uncontrollably and Never regret anything that made you smile. | |
| | #22 (permalink) |
| Ok Guys, I am going to the installer tomorrow and getting the compos relocated to the front. The problem with the Nippons is that being full range there is hardly any sound clarity. No bass no highs. Only mid. And when I add a sub (next month), for rear passengers it may not be very pleasant to the ears. Even if using just as fillers wont it sound better if I get 5.25" 2 way co-axials at the rear (I will be adding Amp & Sub next month)
| | #24 (permalink) | |
| Quote:
| | #25 (permalink) |
| Newbie Join Date: Jan 2008 Location: Bombay
| What i think Ramee is trying to say is that u should be using Line output converters which would take the speaker wires that come out of ur factory HU and convert them into RC outs so that u can connect them into ur amplifier via RC cables looking at ur options u should take a serious look at the Kenwood as it has a High level input option which would allow u to connect the speaker wires to ur amplifier directly have a look at the pics attached to get a better idea of what the Line out put converter looks like. it should be readlily available at your local installer for arount 400rs odd Hope this helps |
| | #26 (permalink) | |
| Quote:
I may not need that after all as my HU has one set of Aux out which i will divide into two thru a Y-cable. A good quality Y cable of Monster/Soundstream costs around Rs. 500 a piece.
| | #27 (permalink) |
| Hi Guys, Today finally decided to go to another installer (Glix). I took reference of Team BHP and was welcomed. Vinay (of Glix) mentioned several members of team bhp who in recent times got systems installed from him. This is what we did: 1. Relocated the Boston compos to the front (door) 2. Fitted JBL GT-5 6.5" co-axials at the rear parcel shelf 3. Fitted JBL GT-5 604 amp 4. Fitted JBL 12" bass tube Powering the sub n compos from the amp. And yes the sound is WAY better. Very happy by the way the Bostons sound. BUT 1. The rear 6.5 co-axials run out of steam very soon. Had to fader it to 30% less. 2. The sound of the tube seems to have limited to the trunk because when the trunk lid is opened the bass almost doubles up. To remedy point no.1, Vinay suggested changing from 6.5" co-axials to 6x9s which will be able to handle high volumes better and also provide a better 'punch' To remedy point no.2 , I wanted a cut of about 6"x10" on the rear parcel shelf so that sound from the bass tube can travel inside the cabin. Hope these things should do the trick.
| Thread Tools | |
Similar Threads | ||||
| Audio installer-at Coimbatore? | TOR | Ask the Gurus | 9 | 15th October 2008 23:57 |
| Installer in calcutta | blueraven316 | Ask the Gurus | 20 | 28th March 2008 21:07 |
| Pro installer in Mumbai? | amit_sound | Ask the Gurus | 1 | 13th October 2007 00:53 |
| Reliable ICE Dealer/Installer in Pune | carboy | Ask the Gurus | 8 | 16th July 2007 16:38 |
| Recommendations for Installer(s) in Delhi | WoodenKnight | Ask the Gurus | 16 | 17th April 2007 13:17 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
