| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Oct 2007 Location: Kolkata
| Hi Gurus, Recently my Swift Dzire vxi got delivered. As it came with a built-in music system and 4 speakers I decided to get the speakers upgraded first. I had JBL 6x9s in mind. But after we took out the old (rear) speakers it was clear that body cutting will have to be done to install 6x9s. I decided against that and opted for components instead. I asked for JBL 6.5" GTO and was quoted Rs. 6200/- for the same. But my installer was really praising Boston S60 compos and quoted Rs. 5850/-. He said there were much better that the JBL. So half heartedly I got the same installed. Now the system sounds BAD. Compared to the old Nippon 5.25" full range speakers mids-highs-lows all seem to have gone. ![]() After I blasted the installer he came up saying that an amp will improve the sound. I am not sure and also cannot spend much on the same (max. Rs. 6500 for a 4ch Amp). 4ch Amp because I will be adding a woofer in future. Guide me. ![]()
__________________ Raghav |
| | #2 (permalink) |
| BHPian Join Date: Jul 2007 Location: Bangalore
| It could be a case of bad installation or improper tuning or both. I have the Boston S60 comps installed in my brothers Getz along with a JBL amplifier and they sound great. Do you have an Amplifier to drive them? It makes a lot of difference to sound quality. |
| | #3 (permalink) |
| Senior - BHPian Join Date: Nov 2006 Location: Mumbai
| if you have installed compos then its better you go in for a amplifier too,and alone compos wont do the justice,you could have kept the rear speakers as they are your stock nippon 5.25" and installed the components on the front door and in future could have got a Subwoofer in the boot would have served you well cheersRamie |
| | #5 (permalink) | |
| Quote:
Ramie | |
| | #6 (permalink) | |||
| Quote:
Please suggest a decent 4ch Amp below 6.5k. ![]() Quote:
__________________ Raghav Last edited by Technocrat : 12th May 2008 at 16:54. Reason: Please use edit instead of making back to back posts also use multi quote option | |||
| | #7 (permalink) |
| BHPian Join Date: Mar 2008 Location: Pune
| slightly OT, but i thought i'll share.. I had installed JBL's GT5 963 and 402 and and driving them directly through my PIO5050. The installer had NOT used the original wires supplied in the box and said they are short in length, he used his own set. Even I was not bothered a lot because I dint had any amp setup. Is the SQ bound to be affected with this? Considering I'm not having a amp to power the setup? |
| | #8 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
It should a case of poor installation. First get that sorted before you spend even more money.
__________________ Live the YetiLife® MA-DONNA! MA-DONNA! MA-DONNA! | |
| | #9 (permalink) |
| Distinguished - BHPian ![]() | If the lows have gone it could just be a case of incorrect wiring. If the wire polarity is interchanged the bass will cancel out.
__________________ \ / ][ |) `/ [_] "!" (\./) (o.o) ( X ) This is Bunny. Copy Bunny into your signature to help him achieve world domination. |
| | #12 (permalink) | |||
| Quote:
Yes I will be getting the installation of the S60 done properly before I buy the amp. I have ordered him to make custom mdf rings (because it seems the speaker is not seated properly) The ones he had were very thick and would not let the stock speaker cover to fit.But tell me one thing am I wrong to think that JBL 6.5" GTO 607 are superior to Boston S60 with hardly much price diff. BTW MRP printed on the Boston box was Rs. 6161/- Quote:
![]() Is there any simple way of detecting which polarity a wire is carrying (without physically inspecting the wires from HU/Amp) Quote:
But isn't the mrp of GT5 604 is Rs. 7990. is it available at Rs.6700 (B/W) Is the Kenwood 8401 only for Rs. 5000?
__________________ Raghav Last edited by Technocrat : 13th May 2008 at 09:09. Reason: Please use Multi Quote | |||
| | #13 (permalink) | ||
| BHPian | Quote:
![]() Quote:
__________________ 2007 Indica DLG My next Truck will be a Safari! Last edited by greenhorn : 13th May 2008 at 07:45. | ||
| | #14 (permalink) |
| BHPian Join Date: Nov 2007 Location: mumbai
| as far as i know i think the front speaker size is the same as the back. if so(actaully even if they arent) then you can have the stock speakers at the back and components upfront where they should be!.(with spacer rings)- P.S the above advice valid only if you have insatlled components in the rear do this now, because you might have to do it later nway when you add a sub. go to another installer and get the wiring redone. Ask one of your local bhpians about an installer. Also please tune the system.(add color i.e bass treble settings if need be) what ramie is talking about is line/speaker level output cables.(i recommmend) i dunno if the Y cable is the same or how hes getting them so cheap,i found out they are about 200rs
__________________ An expert is someone who takes a subject you understand and makes it sound confusing. Last edited by Magma : 13th May 2008 at 08:37. |
| | #15 (permalink) | |
| Quote:
I have already played around with the Bass/Treble settings. There are three things I need to do: 1. Add an amp 2. Change the wiring 3. Provide a airtight fit to the speakers.
__________________ Raghav | |
| Thread Tools | |
Similar Threads | ||||
| Installer in calcutta | blueraven316 | Ask the Gurus | 20 | 28th March 2008 20:07 |
| Pro installer in Mumbai? | amit_sound | Ask the Gurus | 1 | 12th October 2007 23:53 |
| Reliable ICE Dealer/Installer in Pune | carboy | Ask the Gurus | 8 | 16th July 2007 15:38 |
| Recommendations for Installer(s) in Delhi | WoodenKnight | Ask the Gurus | 16 | 17th April 2007 12:17 |
| Good dealer and installer for K&N in Bangalore ? | Nikhilb2008 | Motorbikes | 11 | 18th December 2006 16:12 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
