Thread Tools
Old 18th May 2008, 19:15   #1 (permalink)
nura's Avatar
Default Need help choose new car for old ICE
Hi! I am thinking of buying a new car in a few months & trying to decide between an Ikon & a Dzire. I plan to keep the old Santro for a while longer, but want to transfer the ICE (Alpine 9887 HU, Hertz 3-way components, ID 12" sub in a sealed box & Audison SRx5 amp) into the new vehicle.
Would one/ both these cars present any serious problems during the above ICE shift?
I guess the HU would be a straight fit in the Ikon, but a dash-kit would be needed in the Dzire, which shouldn't be a big issue.
I believe the Ikon doors take 5" x 7" drivers & the Dzire doors 6" ones. Will fitting 6.5" speakers involve MDF rings only or door-cutting too?
Would the 3" midrange speakers also go into the doors? Would I need to isolate them from the midbasses? So custom-built door-cards?
The Dzire has stock locations for the tweeters. But where should they be fitted in the Ikon?
If I choose the Dzire Vxi (can't think of a vehicle without power-windows & central-locking after having them in the humble Santro), can I remove the HU & speakers from the new car & fit them into the Santro? Or would it be a better idea to select the Lxi & try to get the original power-windows & central-locking fitted at the dealer's workshop? I know the last question is a bit below the belt in the ICE section & apologise for it.
Or should I simply chicken out & get myself another Santro?
Thanks in advance.
nura.
__________________
Every man has his follies.
And often they are the most interesting things he has!
nura is offline   Reply With Quote
Old 18th May 2008, 19:26   #2 (permalink)
adityamunshi's Avatar
The Dzire will probable need a LOT of damping.
__________________
And Michael Schumacher is actually in a very good position to win the race. He is in last place. - Murray Walker
adityamunshi is offline   Reply With Quote
Old 18th May 2008, 19:37   #3 (permalink)
DerAlte's Avatar
Don't you want to consider the Tata sedans?
Maybe you should look at the experimentation that LBM did when he was trying to optimize his 3-way mounting. He mounted both the mid and the tweeter high on the door.
Maybe you could think of placing the mid and the tweeter in a custom pod in the crook of the A-pillar, or in the conventional mirror pod location.
Compare the economics of stock as well as after-market power windows and central locking, before you settle on the model. The stock ones are usually better integrated.
Shouldn't be a big deal removing the Dzire HU and mounting it in the Santro, unless the Dzire one has an integrated front plate meant for Dzire. If the mid-bass driver size is the same, shouldn't be a problem fixing it in the Santro.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 18th May 2008, 21:40   #4 (permalink)
hydrashok's Avatar
@nura, more or less the same issues I had in my mind when I was thinking of changing my Palio.
The installation challenge will be the 3-way speakers (specifically the midrange) and not the HU or amp or anything else.
IMO the best car (with a boot) to ICE is a Verna. Great metal, great plastics, minimum damping. Rather than a Santro, an i10 would be a better choice. So would be a Getz.
In either case, the Midrange will be a bit difficult to install, but it can be done (without cutting the door), if you get a small FG pod made, or if you get a pod-like spacer made from MDF (paste & screw multiple spacer rings together and cut around them to shape). The pod can be screwed to the door. The midrange is pretty small and shallow, so we will not need to cut the door pad.
Making custom door-pads for the newer cars will be tough, without major FG work, as the door-pads are not straight, and are moulded to shapes in plastic.
Now coming back to the car, I settled for a Swift for a whole lot of reasons not totally ICE related. But I did consult extensively with my installer. The Swift has a pretty deep dashboard with quite a bit of flat area. And the corner between the dash, the windscreen and the A-pillar gives quite a bit of possibilities for housing the midrange and tweeter in a pod, without affecting visibility too much. The downside is that actually getting a pod done there might cause the mids and tweets to fire a bit into the windshield (if mounted flat, firing up/angled up), causing smear. But my installer and I both think that this can be avoided to a large extent.
In my case the midrange is 4" (Energy Series). But you have it a bit easier, because your midrange is 3", and a bit shallower (Hi-Energy series). So lesser issues.
You can also go for a door-pad install, with pods for the midranges fixed there (like LBM's current setup).
I will be getting my ICE reinstalled in the Swift in about 2-3 month's time, so that might be of help (if you decide to go for a DZire -- A DZire and Swift are identical inside). I doubt if you'll get delivery by then anyway The DZire will take 6.5" midbasses in the doors, no issues there.
Be warned that a DZire will need a looooooooot of damping, at least double that of other cars. I'm looking at about 15K as a damping budget for the Swift. I'll also get underbody coating from 3M or Dinitrol done, and that will help with sound-deadening (lessening road-noise) a little bit.
Another option is the Fiesta -- the stock pods are high up on the door panel, and take 5x7 speakers. Perfect position for a midrange & tweeter. A custom spacer can be made (in 5x7 sixe) which will take your 3" midrange and a tweeter, and enclose them both inside the stock grille. But installing the midbass will be an issue -- the door will not take a midbass in the usual position (lower forward corner) without a gigantic spacer (if at all it can be done). Maybe, just maybe, the midbasses can be installed under the seats in small boxes, but well, how the whole setup will sound when it all comes together, is something we can't predict in advance.
I'm not sure if the Ikon has the same door-pad setup as the Fiesta. The old ones (up to 3 years older) did not.
As DerAlte said, the TATA sedans could be the perfect answer, if you're OK with TATA, and if they are like the Indica. If they are (like the Indica), you get a Midbass pod in the door, and a 5.25" pod in the dash. Perfect. The tweeter can be installed close by to the midrange (which will be in the 5.25" pod).
All the best in choosing the car
EDIT: Dash kits for the Swift ZXI and the DZires with the integrated HU are easily available now. My installer had done quite a few HU replacements in both over the last few weeks.
__________________
Alpine 9887 | TRU Tech S44 | Image Dynamics XS65 | Image Dynamics IDQ12 D2V2 | Connection Audison
hydrashok is online now   Reply With Quote
Old 18th May 2008, 22:25   #5 (permalink)
nitrous's Avatar
custom made or branded? if latter, which brand?
__________________
2004 2005 2006 2007 2008 - 5 consecutive titles.
Arguably,the best the sport has ever seen!
Old 19th May 2008, 00:42   #6 (permalink)
hydrashok's Avatar
Not custom-made. Dunno what brand. Certainly not Scosche or such. Basically the entire central panel (of the dash), including the A/C vents, and the integrated stereo get replaced with the central panel of the LXi/VXi Swifts.
A clip-thing/metal-frame to hold the stereo properly in place needs to be custom-made, though. I haven't seen this yet, but my installer told me this.
__________________
Old 19th May 2008, 01:56   #7 (permalink)
low_bass_makker's Avatar
Guys I have a dome midrange which is a complete unit itself we don't need any enclosure for it. But in your cases you need a good enclosure for the midrange to perform to there best potential. So try getting the FG enclosure would yield the best results.
Old 19th May 2008, 11:51   #8 (permalink)
DerAlte's Avatar
LBM, please share the experience of your experimentation on driver positioning.
__________________
Old 19th May 2008, 13:32   #9 (permalink)
It is one of the trickiest part in ICE. A little change here and there will affect a lot.
Earlier I used to run by setup both passive and the driver were placed off-axis to the listener. But now it is both active and on-axis. A very big difference is felt when going from on-to-off axis. I would seriously recommend everyone to at lest place there tweeter on-axis to improve the sound. I helps in good imaging and widen sound stage.
With placing the driver on-axis there comes the problem of level matching of the drivers. Like in a 2-way if the tweeter is on-axis and the mid-bass in off-axis there will be lots of difference in sound out. So setting the gains would help you more on this part. This was one of the reason to go active.
Rest it is a long topic but I need other to comment on the same.
Old 19th May 2008, 14:22   #10 (permalink)
navin's Avatar
Most car component systems are 2 way. The crossover being around 2-6K which menas that about 70-85% of the music energy is being produced by a driver that is firing at your knees! Fortunately for us most midbass drivers have pretty good off-axis reposne till atleast 1K and the off-axis drop is only rally noticed beyond 1.5K (some better drivers can strech this to 3-4K).
For this example lets assume a good midbass that has not breakup or off axis issues till 3K and a good tweeter that can be crossed as low as 2Khz/12db without strain. The XO for arguments sake could be a 12db/octave L-R network.
In most stock locations the midbass driver is about 16-18" from the tweeter. Given the above woofer/tweeter/XO combination, from 1K to 4K you will have 2 distinct soruces of sound. The tweeter will be only 12db down at 1K and the woofer wil be only 12db down at 4K. The wavelength of a 1Khz sine wave is about 14" (at 4K the wavelength is about 3.5"). So there will be marginal lobing related distortions from 1K getting progressively worse till 4K. To maintain vertical polar uniformity, the inter-driver (c-c) spacing must be shorter than the wavelength of the acoustical crossover frequency.
In addition to the above lobing distortions the sound will arrive at the ear at different times (the tweeter usually being closer to the ear than the woofer).
As one moves to a 3 way system some of these problem are reduced but if care is not taken (in the system degins) you can introduce a whole new set of problems. Care must be taken to keep the crossover frequencies far apart so that the elements of one driver's crossover do not create aliansing effects to the elements in other drivers. This usually means a resonably wide bandwidth midrange. The steeper the corssover the greater this issue. Shallow (1st order) crossovers escape this but then driver choice and placement becomes all the more critical.
By going active we resolve many of these issues but have the penalty of having to deal with multiple amplifiers and an electronic crossover.
a basic primer on crossovers
active loudspeakers [english]
Google-meister (aka LBM) can dig up much more.
So why do not hear much of all this?
1. In a car there is too much going to pay attention to these finer nuances
2. Many of us dont know what to listen for
3. Many of us tolerate these limitations for the sake of domestic harmony, aesthetics, and the diffculty is making custom door/kick panles that can accomodate the drivers in acoustically correct locations.
__________________
Scixelsyd Etinu
Old 19th May 2008, 15:39   #11 (permalink)
DerAlte's Avatar
Well, I had hoped LBM will catch the drift about the physical placement (base of A-pillar or mirror pod or door etc.; he has done a lot of placement testing).
If we can come up with a practical solution, maybe @nura will be able to visualize and get something made. I am getting visions of a custom FG enclosure the way Sam conjured up something that held a tweeter (he has a photo-essay somewhere in the DIY section). The next best is the same at the bass of the A-pillar (for the moment ignoring likely smearing)
__________________
Old 19th May 2008, 16:16   #12 (permalink)
navin's Avatar
Practical locations for cars that dont have tweeter pods:
1. A Pillar (flush mount) - I consider this the second best option for mosst cars. There is limited depth so some larger tweeters (dynaudio, ScanSpeak, etc..) wont fit
2. Door Panel (flush mount) - probably the best as it locates the tweeter closer to the midbass but many doors wont accept this as they dont provide any viable space.
3. Dash (surface mount facing listener) - not the best aesthetic solution and is often used when the door or A pillar wont accept the tweeter (usually large tweeters like Dynuadio, ScanSpeak, etc..).
4. Dash (surface mount facing windscreen) - ofnte used with TS20 tweeters - The only tweeter that benefits from this install is the TS20. Mostly becuase the listener is off axis and partly becuase the ragged on-axis respnse actually sounds nicer after being "smeared" (sometimes 2 negatives make one positive).
To make an exhaustive list for each make-model of car is too cumbersome so I guess we'll deal with tweeter placement on a case to case basis.
__________________
Scixelsyd Etinu
Old 19th May 2008, 16:58   #13 (permalink)
DerAlte's Avatar
^^^ ... and then there is the mid too, Navin. @nura has 3-way's!!!
__________________
Old 19th May 2008, 20:19   #14 (permalink)
hydrashok's Avatar
3. Dash (surface mount facing listener) - not the best aesthetic solution and is often used when the door or A pillar wont accept the tweeter (usually large tweeters like Dynuadio, ScanSpeak, etc..)...
I'd go with a combination of 1 & 3 for the mids and the tweets (housed in a single pod), if the door-panel install is not preferred.
There's an Innova project in the oven at a place I know about, that will be having some serious stuff installed this way (3-way comps running active). I'll be using that car as a reference to see how the setup sounds, and if I like it, I'll try the same in my car too, with my current equipment
__________________
Old 19th May 2008, 22:36   #15 (permalink)
Navinji,
i had done couple of active systems in a very low budget,but nothing for the car - could you explain the difference in car and home listening experience.
Many of us don't know what to listen for
could you explain more
mohang_j is offline   Reply With Quote
Thread Tools
Your Only car...choose one Rtech A Collection of the best threads 240 19th November 2008 12:43
help me choose the right car avmaxfan SUVs, MUVs & 4x4s 1 11th November 2007 16:52
Please help me choose a car ranjithc Sedans 17 11th June 2007 23:49
Help me choose a car >> drsvijay Sedans 26 11th April 2007 15:49
Help me choose a car for my brother Sam Kapasi SUVs, MUVs & 4x4s 10 16th January 2007 15:17
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
