| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #17 (permalink) |
| BHPian Join Date: May 2008 Location: MegaBHPian* at Hyderabad
| The gurus getting emotional!? I assure I am not going to do it and break everyone's heart, but would like to know why gurus are so united against this! Insults to the car, car running away and car's tears apart (so much for your car love and personification ), are there practical reasons why this is outrageous?1. Is the technology out and out different between a car and TV (A/C or DC, different voltage etc.)? 2. Is it impossible to physically fit that kind of a box into a car? 3. Will it necessarily be of poor quality to destroy existing sound (or is this an assumption coloured by feelings? - the box did very well on the TV) 4. I read on this forum some HUs are capable of powering a sub directly to reasonable levels. Why then can't this work off a HU? 5. If HU power is the only constraint, what would make this inferior to a regular sub, if I add in an Amp? Thanks (Fire!). |
| | #18 (permalink) | |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| Quote:
1. Is the technology out and out different between a car and TV (A/C or DC, different voltage etc.)? Yes, different impedance, different gain due to surroundings, different tolerance of surrounding, different sound power output (you don't have road and engine noise in your living room, now do you?) 2. Is it impossible to physically fit that kind of a box into a car? No, you can definitely fit it under the front seats 3. Will it necessarily be of poor quality to destroy existing sound (or is this an assumption coloured by feelings? - the box did very well on the TV) The TV had a large room around it, the car presents a much more limited volume around it (read up on Car Gain). This box is most likely playing efficiently around 60-70Hz. One talks of a car sub (or even a decent HT sub) going down to at least 30Hz. A ported box is "boomy" and one does not expect a plastic BR box to be even more "boomy" than a wooden BR box. The venerable B (@bhagwan; read up on his i10 thread; he feels downright nauseous with such arrangements) 4. I read on this forum some HUs are capable of powering a sub directly to reasonable levels. Why then can't this work off a HU? Maybe you could point us to those instances? No one said it can't, just that at those power levels you will really have to hunt for the low frequencies in your car, it will be so low volume 5. If HU power is the only constraint, what would make this inferior to a regular sub, if I add in an Amp? Quality of low frequencies and the "boominess" (unnatural resonance) associated with a plastic BR box Where? What fire? Fire what? Fire at what?
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! | |
| | #19 (permalink) |
| Senior - BHPian Join Date: Sep 2007 Location: New Delhi
| To satisfy Glass' curiosity, I would recommend he should try out his TV bass unit driven from the HU. For the record, Der Alte, could you please explain the following a bit more: (numbered as per your previous post) 1) In what way is a car amp or speaker designed to overcome such noises? And what does 'different sound power output' mean? 3) Without complicating the subject with low freq cut-offs, how would this box perform in the range it was designed for? Would its performance in a car change so radically that it would make the car feel suicidal? 4) This is pure conjecture. Having personally tried out 'domestic stereo speakers' in a car, I think it a bit extreme to say that one would have to hunt for the lows because their intensity would be so low! 5) Isn't the 'quality' and 'boominess' best decided by the user. Who knows that some users might find this quite acceptable. Last edited by anupmathur : 26th May 2008 at 12:18. |
| | #20 (permalink) |
| Senior - BHPian | Glass, well, the point is , it probably has a driver ~5 inches, and since the enclosure is plastic, will end up sounding a lot worse than your rears, and in fact will have less bass than the rears , considering the fact that 1) the driver is smaller 5" as opposed to 2 6x9 drivers 2) the enclosure will be smaller the volume of the plastic box as opposed to the whole boot/area under parcel shelf 3) will have to be driven off one channel of HU 4) plastic enclosure as opposed to wood. It is not a proper sub , it would be more correct to call it a bass module. It helps supplement the mids and lows from the 3 inch full rangers you usually see on TV's. This is more like the woofer you see in cheap PC 2.1 systems. A Bad analogy would be saying that you cant afford fog lamps , and if you could use the reflectors + bulbs from a torch instead Do-able , but not much of a point to it
__________________ '07 Indica DLG - Almost a DLX Last edited by greenhorn : 26th May 2008 at 12:40. |
| | #21 (permalink) | |
| Quote:
1) In what way is a car amp or speaker designed to overcome such noises? And what does 'different sound power output' mean? A car amp or speaker design is not meant to overcome such noises, but the overall system design is: one needs a system with a bit more punch in that band to be heard over the noise. This box falls squarely in that band - much of its audible power will be in the 60-200Hz range. Conversely, if the system designed for a car were to be installed in a room, it would sound unnaturally bass-heavy. 3) Without complicating the subject with low freq cut-offs, how would this box perform in the range it was designed for? One can safely assume that the original design was meant for a different surrounding and power level. Would its performance in a car change so radically that it would make the car feel suicidal? Looks like the humor was lost on you! The performance wouldn't change inherently, it would just be insufficient for the application. 4) This is pure conjecture. Having personally tried out 'domestic stereo speakers' in a car, I think it a bit extreme to say that one would have to hunt for the lows because their intensity would be so low! Apples v/s oranges comparison, no? Everything from Lajpatrai Market speakers to exotica would produce sound, but there is a general average understanding of what is "good" sound. Even without discussing frequencies, decibels and watts - maybe one can try listening to the lower organ or piano notes with such speakers that you describe, whether in the car or in the living room. Or even test tones in the 20-100Hz range? Music can be heard and appreciated even without those, but conversely one doesn't conventionally classify systems - where that range is absent - has high-fidelity systems 5) Isn't the 'quality' and 'boominess' best decided by the user. Who knows that some users might find this quite acceptable. Very true. In fact, the number of satisfied users of systems where the subwoofer or tweeter output dominates (especially the ones that don't stop 'ringing' till 3 notes beyond) the music and the surroundings for a 100m radius, FAR OUTNUMBER the users of systems which produce a balanced natural sound, the way it was originally intended to (fidelity)!
| | #22 (permalink) |
| BHPian | Car speakers are usually shallower to fit into doors and things in the trunk. Car speakers are typically more efficient because most car stereos produce less than 25 RMS per channel. Most home speakers are 8 ohms while car speakers are 4 ohms or less which draws more power. Common car speakers are typically coaxial (not always) - with all the drivers in one frame covering all frequency ranges. Car speakers require thier own box and have some type of weather proofing from sun and moisture. It is not that one can't try, but it will never match what a good car system can deliver. Have tried creative subs in car and never got what needed.
__________________ jay It’s really quite a simple choice: Life, death or Los Angeles Last edited by redfire : 26th May 2008 at 14:11. |
| | #23 (permalink) | ||
| Thanks for the explanation. I was getting ready to get fired by the gurus again! Quote:
| | #24 (permalink) |
| Der Alte, thank you so much for your patience. And you are too kind, Sir. I really do not deserve such status. The above two remarks quite sum up what I'm trying to say. Glass ought to go ahead and give it a shot. He'll also come to know where in the audiophiles list he figures, lol! ![]() |
| | #25 (permalink) |
| Mathur-saheb, theek hai, theek hai - you are the epitome of humility! ![]() By all means, of course. We were just making him conscious of expected results. But, that said, one really has to go ahead and experiment - knowledge and experience do not come without a few trials and errors. And "audiophile" is not a term to sprout horns for, nor to feel that one should sink into earth if not - it is usually a "mine is bigger than yours" folly!!!
| | #27 (permalink) | |
| Quote:
In fact it is a term that has quite fallen out of favour. However, for want of a suitable 'replacement'. it keeps on finding usage. I am at a stage where I simply advise each one choose to what makes him happy and I strongly advise NOT to feel 'guilty' about it! The way I do not feel at all guilty about being a Bose fan! ![]() | |
| | #28 (permalink) |
| BHPian Join Date: May 2007 Location: Navi Mumbai
| I read somewhere (don't remember where) that people listen to their music but audiophiles listen to their stereos! I believe that audiophile-ness is only one extreme end of the spectrum where only hardware quality matters (along with quality of recording) but the content never gets evaluated in terms of music sense. And hence, many modern day "audiophiles" prefer not to be called one.
__________________ A fine is a tax for doing wrong. A tax is a fine for doing fine. |
« Retro / Classic looking car stereos with modern functionality
Kicker Amp, Subwoofer, Speakers + any good USB support HU »
| Thread Tools | |
Similar Threads | ||||
| Car Audio Advice from the Audio Gurus: Use "Search thread" before posting a new Q! | Sam Kapasi | Ask the Gurus | 9767 | 22nd November 2009 01:32 |
| Subwoofer / Audio enhancements for New Honda Civic... | ST7677 | Ask the Gurus | 530 | 25th August 2009 21:31 |
| Best direction to face box subwoofer in boot of car ? | DRAGONLORD | Ask the Gurus | 4 | 28th December 2007 02:31 |
| lightning audio beast subwoofer | FORDLOVER | Ask the Gurus | 36 | 7th September 2006 17:31 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
