Thread Tools
Old 26th May 2008, 09:00   #1 (permalink)
amitverma's Avatar
Default JBL CS60.4 repair guide
my ICE woes doesnt seem to cease. well this is part II of the deal. my 60.4 JBL amp has a dead MOSFET [i hope this is what it is called, the golden screw thingie..?]. the ones operating the sub are alright. the ones doing duty for the components have said goodbye.
pls let me know where to get it fixed in new delhi? i dont want to goto local electrical-walaa. i have been referred to a lot of these guys but i am fairly confident that they will wreck my amp for sure. also pls dont suggest some ultra hi-fi techno-jargon-buster, who would rip me off by boggling certain cool sounding abbreviations.
if u want a peek at my financial situations regarding ICE, refer here (Pioneer HU upgrade/woes)
__________________
GM need not make a Hummer Hatch - Fiat Already Made PALIO
amitverma is offline   Reply With Quote
Old 26th May 2008, 09:53   #2 (permalink)
Sam Kapasi's Avatar
I'm assuming it isn't under warranty.
Firstly a Metal Oxide Field Effect Transistor is not a golden screw thingy lol. It is a transistor and is proud to be something like this.
Secondly - how do you know that the MOSFET has failed? Yes it is quite possible but not necessary. My question is - how can you be sure?
__________________
Live the YetiLife®
Old 26th May 2008, 13:03   #3 (permalink)
navin's Avatar
correction: it is
Metal Oxide Semiconductor Field Effect Transistor
MOFET is Jewish/Yiddish/Herbew word (something I learnt while at Yeshiva Univ, NY) that has something to do with educatation (I believe it is Maths and Physics) and culture.
__________________
Scixelsyd Etinu
Old 26th May 2008, 13:18   #4 (permalink)
Technocrat's Avatar
Have had this changed in my Sony amp too, it seems this is cheap as the installer did it free of cost to me(as I was anyways paying him for speakers & cables) SO hsould not bea problem, others can advise better on place & price.
__________________
The Holy Trinity: Traction, Torque and Tarmac
Old 26th May 2008, 23:41   #5 (permalink)
amitverma's Avatar
i might know the technical aspects of this but let me just give u a peek into the problem im facing. the 60.4 has a pair of 4 gold screws to which i attach the speaker cable to. on the upper set of screws i have bridged the subwoofer while on the lower set reside the front components. now the LEFT front comp always turned on and off and on...whenever i increased the volume, it comes back to life. i inquired abt this with a couple of local accessory shops and they all told me that the "mosquito" is dead. at first i was a bit sceptical about my amplifier renting out space to a bunch of mosquitos to live but then the working side of my brain intervened and i realised that he must be referring to the MOSFETs.
now when i asked about the repair bills, teh mosquito guy tells me "Sir, yeh JBL-shey-BL ke amp imported maal hai. inko repair karne ka kharcha bhi imported hi hai. pata nahi uske level ka part milta bhi hai yaa kuch jugaaaad chalaana padta hai"
that line was enough for me to walk out of that store.
anybody can throw some light as to what i need to do now?
__________________
Old 27th May 2008, 00:56   #6 (permalink)
navin's Avatar
this sounds like a leaky cap in the amp. any good technician should be able to diagnose and fix this. amp circuits are really not all that complicated. since it is only 1 channel that is malfunctioning one can use the voltages of the working channels to ascertain which part needs replacement.
__________________
Scixelsyd Etinu
Old 27th May 2008, 01:07   #7 (permalink)
Sam Kapasi's Avatar
Change your RCA cables.
__________________
Live the YetiLife®
Old 27th May 2008, 02:01   #8 (permalink)
amitverma's Avatar
2 different suggestions.
Sam, how did u arrive on the faulty RCA cable situation?
__________________
Old 27th May 2008, 12:04   #9 (permalink)
DerAlte's Avatar
2 different valid possibilities!
"Faulty RCA cable situation" means a loose connection can also show this behaviour. "whenever i increased the volume, it comes back to life" could be a coincidence - vibrations from the louder sound could be causing the connection to reconnect!
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 27th May 2008, 12:48   #10 (permalink)
greenhorn's Avatar
question, when you pump up the volume and it comes back to life, does it play clean, or is there any distortion?
__________________
2007 Indica DLG
My next Truck will be a Safari!
Old 27th May 2008, 12:51   #11 (permalink)
low_bass_makker's Avatar
It can be RCA or some dirt in the switches which is used for HPF, FLAT, LPF setting.
Try fiddle with them while playing and check for the sound.
Thread Tools
DIY Guide: How to repair a Tubeless tyre puncture! iraghava Tyre & Alloy wheel Section 62 6th November 2008 11:22
For Sale - JBL 2ch Amp and JBL 12" Basstube karthik247 Shifting gears 5 3rd December 2007 17:44
2 months old JBL CS60.2 and JVC 3300 Amps for sale!!! gopz Shifting gears 3 9th June 2007 17:52
Pioneer 6850 + JBL 606CE + GTO 636e + CS60.4+ GTO100B+ Harmann Kardon Drive +Play ajmat Product Discussions 17 10th July 2006 20:22
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
