| Ask the Gurus Post your ICE questions here |
| | Thread Tools |
| | #16 (permalink) |
| Senior - BHPian | 13800 as mentioned here (Swift Audio Set Up - Rs. 100/- K Budget -- Options ?)
__________________ 2007 Indica DLG My next Truck will be a Safari! |
| | #17 (permalink) |
| Newbie Join Date: Oct 2005 Location: mumbai
| invinsible your more than welcome to come audition my system. just done a few upgrades recently front - mlk 165 rear - hsk 165 sub - illusion audio nd12i amp - audison lrx 6.9 you can audition the hertz as well as audison and all this in a skoda itself. so then you can decide. |
| | #18 (permalink) |
| BHPian Join Date: Nov 2006 Location: Mumbai
| Thx brett i really appreciate your gesture thats really kind of you and thats a neat system you got there. Where are you put up in mumbai? Where did you get your stuff from and installation ? Can you PM me your details. |
| | #19 (permalink) |
| Come on guys I was expecting that guru's here would come up with great suggestions.. havn't managed to get barely few. I am sure all experts out there can take sometime out to help me out. Wanted to know if anyone here has any idea about JL Audio 300/4 Amplifier has some impressive specs. Any idea how good they are. Below are the spec Specifications:
I am getting the jl audio amp at a good price roughly about Rs.15K and the diamond audio comps for around Rs.10k. Wanted to know if they are really worth going for? Thanks. |
| | #20 (permalink) |
| Team-BHP Support ![]() Join Date: Mar 2007 Location: Bangalore
| @invinsible, the most prudent approach to selection is to actually listen to the equipment on offer. If you have generally gone through the ICE threads, you will have an idea of which brands / models are VFM, and which are not. There are differences in sound signature, and, coupled with individual preferences, it becomes very difficult to believe (though it is very easy to express negatively) relatively 'how good' a model is. At the prices you have mentioned, neither seems to be VFM. They can't be downright bad. Of course, your mention of "getting it at a good price" is compared to the list price, but even after reduction it may not be a justifiable price in the first place.
__________________ Never believe it cannot be done - it's only that you haven't found out how!!! |
| | #21 (permalink) | ||
| Team-BHP Support ![]() Join Date: Mar 2004 Location: mumbai
| Quote:
Which Diamond Audio components are you getting for 10K?
__________________ Scixelsyd Etinu | ||
| | #23 (permalink) | |
| Quote:
Any idea how good they are? I cant audition them coz they aren't available here. I also have choice of going for Rainbow SAX265 which I may get for Rs.12K or so. No Idea how good they are but Rainbow is suppose to be good brand atleast their higher range seems to be good. I don't feel SAX265 would be VFM as compared to DIamond audio S600s. Whats your pick on this ? Also, I can source Alpine SPX pro for about Rs.18.K. All unnecessary bold, italics and font tags removed from the post for this once. | |
| | #24 (permalink) | |
| Senior - BHPian Join Date: Mar 2006 Location: Bombay
| Quote:
__________________ Operator! Give me the number for 911! | |
| | #25 (permalink) | |
| Quote:
I too got a price of 15-18K for them and i figured since your total budget was 50K spending 15-18K on just the front components (you still need to have some money left for an amp, a sub, damping and wiring) might not work.
| | #26 (permalink) |
| I came across with this amp called ALPHASONIK, has some great specs on their amp. Also, read few review on them which says they produce clean sound and is 2nd to Zapco and Audison but at a reasonable price. Here's the amp I came across Alphasonik PMA4150A. Below are the specs: What you think about it ? Any one has any idea how good are the amps? Also, I wanted to check that most of the amps have high frequency range of upto 20khz where as these have upto 50khz, does this make a lot of difference where sound reproduction is concerned from the speakers even though the speakers have frequency limited to 20khz or 25khz. Can anyone explain this ? 4-Channel Class A/B Bipolar Power Amplifier RMS Power Rating: 150 watts x 4 chan. at 4 Ohms Stereo RMS Power Rating: 240 watts x 4 chan. at 2 Ohms Stereo RMS Power Rating: 460 watts x 2 chan. at 4 Ohms Mono Bridgeable Tiffany-style input and ouput RCA jacks Hour meter Remote mount digital voltmeter Remote bass boost control Heavy duty heat sink High speed switching power supply THD: 0.05% S/N Ratio: >100dB Frequency Response: 5Hz-50kHz Variable Low Pass Filter: 50Hz-250Hz, 24 dB/oct Variable High Pass Filter: 50Hz-250Hz, 24 dB/oct Variable Subsonic Filter: Off-20Hz, 24dB/oct Variable Bass Boost at 45Hz: 0-18dB Variable Phase Shift: 0-180 degrees Input Impedance: 10K ohms 4-Way Protection Circuitry: Thermal, Short Circuit, Overload, and DC Offset On board hook-up terminals Dimensions: 22L x 8W x 2 5/8H |
| | #27 (permalink) |
| They usually retail for about 800$ but getting it for 300$ under close out sale. 1. Please use bold / italics only to highlight relevant parts of the post, not the whole post. If done on the whole post it reduces legibility, which would defeat your intention. 2. If you want to add to your post after editing time limit, post only the additional text, instead of duplicating the whole thing and adding. Last edited by DerAlte : 8th June 2008 at 11:49. |
| | #28 (permalink) |
| At (US)$ 300, this would be a good buy, comparable to the 12-13K of the now-defunct JBL 75.4. If the specs were to be believed, this is a good amp. However, there is more to amps than just the specs. The 5Hz-50Khz Frequency Response has to be taken with a pinch of salt - if it were genuinely capable, they would have published a power v/s frequency graph. The remote voltmeter is also a gimmick, unless you want to participate in SPL competitions. The remote bass boost is useful, though, since sometimes you may want to control the sub volume if you are connecting a sub to this amp.
| | #29 (permalink) |
| Guys, here's what I plan to get; 1. JL audio CL441 dsp 2. Rainbow ipaul 4.300 amp for front and subs. 3. Front Speakers : Hertz 165 / Rainbow SAX 265 / Diamond audio S600a / CDT Audio high defination HD-62. What's the best take for good midbass and vocals & not to sharp tweeters. 4. SUB: IDQ 10 or ID two 8 inch / Rainbow Hammer 10". 5. Rear Speakers : Was think of fitting the OE front speaker to the rear or get get coax and power it up either of them with a 2 channel JBL amp or so. What are your take on this? Any Coax suggestion ? Also came across with this review on Pioner Premier TS-C270PRS components speakers. Some great review check it out here Pioneer Premier TS-C720PRS-Review Components - Car Audio and Electronics Beats even rainbow and Lotus Ref speakers with final points. What do guys think about this. Is it worth picking up pioneers? Another comp which is on my mind is Genesis profile 16. Now, i Know Genesis are good with their amps but not sure how good are the speakers. Inputs buy anyone here who has heard the speakers, sub, amp mentioned, will be really helpful. Thanks. |
| Thread Tools | |
Similar Threads | ||||
| Fabia Elegance 1.4 MPI Owners. Need Help! | sunit | Technical Stuff | 5 | 2nd November 2008 20:40 |
| White Elegance - The Fabia 1.4 MPI | SidMeer | Test-Drives & Initial Ownership Reports | 20 | 29th September 2008 01:53 |
| Budget 50K.ICE in my i10. | somebodystopme | Ask the Gurus | 25 | 18th May 2008 17:45 |
| Laura Elegance ICE Setup | brett | Ask the Gurus | 82 | 5th November 2007 14:32 |
| 40-50k budget ICE for scorpio. Clean vocals priority. | vibzez | Ask the Gurus | 32 | 27th October 2007 11:15 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
