Thread Tools
Old 30th May 2008, 14:26   #1 (permalink)
shreyasma's Avatar
Default Help in choosing a new speaker.
Hi Gurus,
I am currently running Pioneer TS-A6952R 6"x9" in ma car.
I have this new deal on Audiobahn speakers.
Please tell me how good are the Audiobahn AS96Q 6"x9" when upgrading from Pioneer TS-A6952R 6"x9".
Is it worth the upgrade and the price??
Its been offered for Rs 2850 for a brand new set.
Or should i go in for JBL GTO937??
Your advice is important for making my decision
shreyasma is offline   Reply With Quote
Old 30th May 2008, 16:02   #2 (permalink)
ramie2400's Avatar
JBL 937s are good for replacement for the existing pioneer,you can even audition Blau and GZ they are also good too.Please specify which car are you running 6x9s weather its on the Plank or Box..cheers
Ramie
__________________
___________
Old 30th May 2008, 16:49   #3 (permalink)
shreyasma's Avatar
Ramie
I am running it in an esteem on a plank. I am powering it with a Pioneer 4 channel amp running in 2 channel mode.
Yet the output is not that good.
I was having this amp to power sony 400 watts speakers and 1000watt pio sub in 4 channel mode in my previous car (santro) using a CarPC.
But had to sell the car with the speakers in it. presently not using the sub in esteem till the car pc is upgraded and fitted back in the car.
Thats a different project all together.
Old 30th May 2008, 17:01   #4 (permalink)
DerAlte's Avatar
Yet the output is not that good. ...
For a moment I read it as "I am running an esteem on a plank" and I thought *why?*!
So you have mounted it on the parcel shelf in the Esteem, which is about 5' away from your ears. Not much to be expected when you are in the driver's seat.
* What speakers do you have in the front?
* What exactly do you mean by "output is not good"? Bass too less? Treble too less?
* By "4 channel amp running in 2 channel mode" I think you mean you are using 2 channels, and 2 channels are free. Right?
* What settings have you set on the tone controls on your HU? You haven't mentioned which HU either
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 30th May 2008, 17:28   #5 (permalink)
shreyasma's Avatar
I have 2 tweeters in the front thats of no use.
The bass doesnt seem to be good enough for normal speaker setup. I understand that i cant expect anything even near to a sub. but still....
My pioneer amp gives me the option to switch from 4ch to 2ch using a switch. By doing this the total output of the amp is split across 4 or 2 ch.
The HU is Pio DEH-P6950IB and These are the settings:
Audio Loudness - MID
Audio Subwoofer - OFF
HP filter - 120
Audio Bass Boost - +3
Audio SLA - +2
Fader - Fronts/Rear - 0
Left/Right - 0
Low - +4
Mids - +2
Highs - +2
Note from mod: Excessive smileys removed
shreyasma is offline   Reply With Quote Received Infraction
Old 30th May 2008, 18:59   #6 (permalink)
Bass&Trouble's Avatar
You have a new deal on very old speakers. That speaker was discontinued atleast 3 years ago.
Even I haven't heard the 96Qs, so cannot comment. But the JBL 937 would definitely be a good bet.
__________________
Losers Commute. We Ride.
Old 31st May 2008, 12:21   #7 (permalink)
DerAlte's Avatar
Now this is quite confusing. Do you mean to say you have ONLY tweeters in the front, and no mid-bass? If so, your setup is quite lop-sided. Unless the speakers are fakes, they should produce music that is tolerable, not hopeless. Steel yourself - you need to invest a bit more than you thought so far!
I am not sure of the mounting in front in an Esteem, whether it is in the doors (usually 5.25" or 6.5") or in the dash (usually 4"). Please check. Here (Esteem ICEd...Work begins..) is one installation where 6.5" speakers are mounted in the doors.
First buy a good set of components (retire the old tweeters) like JBL GTO607, Blaupunkt ODc/THc, Illusion Electra etc. - should cost you 5-6K with b&w - and see how the rear Pio complement them. If the old ovals still don't contribute, replace them with JBL 937. Audition the speakers before buying - JBL at Sound Factor or Sprocket, Blau at Mandovi Motors Wilson Garden or Kanakapura Road, Illusion PM @blueraven or @s0uljah.
HP filter - 120
Audio SLA - +2
Left/Right - 0
Low - +4
Mids - +2
Highs - +2
Good HU, wrongly set - but that is not your fault, you were trying to extract the best.
Just try setting all the above non-0 settings to 0, and HP Filter to 60 or 80 (this is the high pass filter; at 120 your ovals are not giving any decent bass), increase the volume and check at what point the current system gives decent bass and highs. Remember this volume setting, since you should compare after changing at what volume the same is achieved in the new system. This will give you an idea what your current system is inherently capable of.
__________________
Old 31st May 2008, 13:38   #8 (permalink)
navin's Avatar
It is ALWAYS a good idea to audition atleast 3 brands.
__________________
Scixelsyd Etinu
Old 4th June 2008, 12:15   #9 (permalink)
shreyasma's Avatar
What is the size of speakers that goes in the stock location of speakers??
Can we get same sized components or can a component be housed with some mods??
Thread Tools
Help :Choosing a Netbook? tj123 Gadgets, Computers & Software 30 17th September 2009 15:17
Help regarding choosing a dealer nukeblitz Indian Car Dealerships 0 25th January 2009 02:10
Help choosing smartphone... shad0ww Gadgets, Computers & Software 12 22nd May 2007 20:17
Help Choosing Amp redeye Ask the Gurus 65 12th November 2006 02:32
Choosing the right dealership luvjascha Indian Car Dealerships 10 14th September 2006 19:11
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
