Thread Tools
Old 14th June 2008, 22:38   #1 (permalink)
Default Tuning Help, Zen Estilo
Hello eveybody
I recently changed from blaupunkt basstube to sony 12inch subwoofer over tray.
My setup is
Pioneer 4950mp
jbl 937 at rear tray
blaupunkt special mk series 4 ch amp.
and 12inch sub over tray because i hav CNG.
Sony 4inch speakers in front doors.
amp is powering front speakers and sub.
the problem is that am not able to get anykind of effect from sub except thong thong and noise. i tried all tactics with hpf and lpf and setting usual options like eq and amp. But still no change.
Is there anything am missing?
If there is something to change or upgrade then please suggest.. i travel a lot and live in a remote place where good installers = NULL!
bmdesai1987 is offline   Reply With Quote
Old 15th June 2008, 00:38   #2 (permalink)
DerAlte's Avatar
Is there anything you are missing? No, just the fact that you shouldn't have bought the Sony to replace the Blau tube, with all due respect to Sony. You are lucky you got thong thong (with noise thrown in for free), most people get only a pitiful whoomf whoomf.
OK, jokes apart, :
* Did you do the install yourself or an installer?
* Are you powering the sub with CNG? (I asked because you have said "12inch sub over tray because i hav CNG"!)
* Did you test the Sony sub before taking delivery?
* Did you check if the sub is working OK by pushing the cone in and out gently? Are you able to feel and obstruction or scraping noise if you do?
You could drive to Vadodara to get it checked by an installer.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 15th June 2008, 04:04   #3 (permalink)
rohan_fonseca's Avatar
Yup mismatch relacement - sony sub for a blau tube. Could the poor bass be a result of a tray install?
rohan_fonseca is offline   Reply With Quote
Old 15th June 2008, 10:29   #4 (permalink)
No, did it with local installer.
Yes CNG+SUB!
Yes, The Bass is nice at low volume but farts as soon as it goes more the 20 (VOLUME)
I did check the sub because the same one was going in one safari and was working really nice even on a 2ch amp. but i dont know whats hapenning wid my install!
Old 16th June 2008, 00:51   #5 (permalink)
DerAlte's Avatar
Yes, rohan, the problem is due to the IB install on the tray. IB in a sedan parcel tray is still OK, since the rear wave has little chance to interfere with the front one. But in the Zen Estilo, the parcel tray would have a gap at the back.
The same sub will perform better (whatever that is with a Sony) if mounted in a box. The Safari install must have been in a box.
Other reasons could be:
* The sub amp gain is set way too high, and the sub is essentially clipping whenever input signal is increased
* The sub is connected phase-reversed as compared to the ovals, and this is causing bass cancellation
Options:
* Return the Sony sub and get the Blau tube back. Figure out a way of putting it in the boot
* Remove the sub from the tray and put it in a box, which would go into the boot
* Get the system checked and tuned with a better installer at Vadodara
__________________
Old 17th June 2008, 00:21   #6 (permalink)
ok guyz... check this
Old 17th June 2008, 01:32   #7 (permalink)
That enclosure looks way too small for the sub! Check the gains as well.
Old 17th June 2008, 11:00   #8 (permalink)
its not an enclosure.... its just the stand... and gains are below half!
Old 17th June 2008, 11:33   #9 (permalink)
navin's Avatar
Originally Posted by bmdesai1987 View Post
...except thong thong and noise..
..but farts as soon as it goes more the 20
This sounds like a bad install. Atleast I hope it is. Sony subs are poor but not THAT poor.
P.S. I must however applaud the vivid detail with which you decribed the problem and thank you on behalf of Sam and B&T (they are too busy laughing to type).
I think that video is not available anymore.
__________________
Scixelsyd Etinu
Old 17th June 2008, 11:44   #10 (permalink)
harry2223's Avatar
i have a similar problem to yours . sub produces bass at lower volume but at high volume its just producing noise like amp is connected to simple speakers.
__________________
harry
harry2223 is offline   Reply With Quote
Old 17th June 2008, 13:04   #11 (permalink)
navin's Avatar
if ths sub sound like it slapping something it means that the sub is being pushed beyond it's physical limits. If you do this for extended periods you can permanantly damage the sub and maybe your hearing (if ths sub is a good 12" sub and is working normally).
__________________
Scixelsyd Etinu
Old 17th June 2008, 14:00   #12 (permalink)
try installing that sub in an enclosure and see if have the same problem. Alternately you can install another sub in its place and check out.
Old 17th June 2008, 21:12   #13 (permalink)
LOL yea i am fed up with what i have done to my car, and dont take things in double meaning... more then enough laugh will make u do the same as my subs doing.... ROFL.. atleast some of u are happy! with my post!
Thread Tools
ICE for Zen Estilo ultimatechamp Product Discussions 50 22nd September 2008 12:11
Used Zen Estilo for 3.6L pradeepbhambi Hatchbacks 30 24th July 2008 13:14
Bought New Zen Estilo bmdesai1987 Test-Drives & Initial Ownership Reports 18 24th November 2007 13:58
Driven: Zen Estilo drifter Test-Drives & Initial Ownership Reports 27 30th January 2007 15:46
New Zen Estilo Launched GeekSrik The Indian Car Scene!! 230 27th December 2006 09:16
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
