Thread Tools
Old 23rd June 2008, 01:41   #1 (permalink)
Default Pioneer 3090 UB issues
Have installed a pioneer 3090 UB (With Warranty from radiowarehouse,chennai) .
A couple of questions
1) The output from the front speakers is very low compared to the back speakers . front speakers are pioneer 2-way fitted in the provision provided in the i10 doors . The speakers were a bit small , so they fitted it with a round piece of wood and attached it to the door .
The rear speakers are on a plank , which was attached by radiowarehouse and is a 3 way speaker . The output and effect from the rear is really good , but the front is bad .
After adjusting front/read levels to give higher level to front , it is audible , but rear loses it s effect .
what could the cause of this be ? wiring ? settings in the HU ? quality of speakers
another other thing seems to be the positioning of the speakers in the front door . The i10 has perforated provision , but i feel that might be adding to the reduction in noise . Checked speakers in a friends car and the speakers were fitted with a casing of the speakers itself protruding out .
2) after setting the front/rear volume option to get more output from the front . once i restart the HU , the settings are no longer valid and i have to reset all audio settings again . is this how it works or is there a way of saving the audio settings ?
3) using the USB option , it seems some folders are skipped while browsing through the folders using the up/down joystick . i had the folders named 70s,80s,90s for songs of that era , but these folders were skipped . it would go something like folder number 23 to folder number 49 .
4) Mythbuster : does using the joystick on the HU reduce its life ?
kartron is offline   Reply With Quote
Old 23rd June 2008, 11:56   #2 (permalink)
DerAlte's Avatar
Originally Posted by kartron View Post
... pioneer 3090 UB (With Warranty from radiowarehouse,chennai) . ...
4) Mythbuster : does using the joystick on the HU reduce its life?
@kartron, it would be better if you are able to give more information - like speaker model numbers and sizes etc.
No, using the joystick will not reduce the life of the HU - it has been provided so that it is used.
Looks like your HU may not be wired correctly. There is one wire which is always connected to battery, so that the HU is always powered and hence retains settings such as time, last value of balance, fader, tone controls etc. Another wire, which is the wire coming through the starter switch in the steering column, is used to start / stop the HU functions. If the first wire is not connected, the HU will forget its settings and all parameters will be reset to default values / settings.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 23rd June 2008, 12:11   #3 (permalink)
praveen_v's Avatar
Radiowarehouse is one of the worst installers in chennai. They have been up for a long time but they guy in the store does not know anything. And the installation is very ordinary. You need to be lucky to get a decent install. Some shops in GP road do a much better install than them.
Using Fader should not cause the speaker to loose effect. The effect will be there at higher volumes than it was before. Maybe the speakers are bad. What is the model and size of the front speakers??
Perforation is not an issue at all. In my car all the speakers/tweeters are behind stock grills and I get good sound.
Are they sub-folders?? If a folder has sub-folders, then there will be a small right arrow indicating it on the display near the bottom. For example, if you have the folders 70,80,90 inside a folder called songs, then when you browse songs, you should press right to access these sub folders. If you continue pressing up/down it will go to the next folder in the same level from root.
__________________
Anyone driving slower than you is an idiot, and anyone going faster than you is a maniac. ~Author Unknown
praveen_v is offline   Reply With Quote
Thread Tools
HU with USB-Pioneer 5090 or 3090?? sathya_j2084 Ask the Gurus 12 2nd September 2008 20:41
PIONEER AVH-P4000DVD or Pioneer DEH-P7900BT abhisheksircar Ask the Gurus 23 18th May 2008 17:18
Wagon R issues Venkat The Indian Car Scene!! 19 3rd April 2008 01:41
Specs Req Pioneer 2950 and Pioneer 4950 HU nicejits Ask the Gurus 3 23rd November 2007 12:03
For Sale: Pioneer FH-P 6200 2 Din and Pioneer EQ 6500 Equalizer . sam_78 Shifting gears 4 28th April 2007 13:16
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
