Thread Tools
Old 25th June 2008, 00:39   #31 (permalink)
blueraven316's Avatar
Originally Posted by l3g0l4s View Post
But a new problem has arised .. I get this static/hissing sound whoch is very evident at low volumes which is really annoying ! What could the problem be ? Is it because i messed up with the controls ? And could someone please tell me on what effect do these controls have i.e.
1). Input level
2). X-over- HPF / Flat / LPF
3). Frequency
As in what effect do these controls have over the sound ?
Thanx again folks
If its awhining hiss which increases with throttle, then this is a common thing, check if the power wires and RC wires have been routed from the same side of the car.
Originally Posted by arpandiv View Post
The steering controls dont work.
The steering controls can work, that happens with some changes on the Aftermarket HEad unit, we had got a Corolla steering volume controls to work on a Pioneer DVD player once.
Originally Posted by gopinathann View Post
Even I am not happy with the sound and I am planning to change the speakers without changing the head unit. Your hard work will definitely help the fellow bhpians having SX4/Dzire who wants to have good quality without changing the HU.
Please keep us posted. Also list down the cost of each component spent.
You don't really need a Dash kit for the Swift Dzire / ZXi,
there are 2 solutions, the centre dash unit from a VXI/LXI can be bought and placed instead of the SO called OE unit,
OR
a Fiberglass unit can be fabricated in case of non availability.
blueraven316 is offline   Reply With Quote
Old 25th June 2008, 02:06   #32 (permalink)
l3g0l4s's Avatar
Originally Posted by ragzv View Post
Ok Buddy,
Now this hissing sound is again because of the HU. That’s some of the main characteristics of "The Nippon HU"
Lolzz .. Time for a new Head Unit !
OR
No sir , they have been routed from the either sides of the car seperately . And the way an after market HU has been installed looks impressive actually .. Will probably get a new head unit then ....
__________________
Such a rush to do nothing at all !
l3g0l4s is offline   Reply With Quote
Old 25th June 2008, 02:32   #33 (permalink)
speedzak's Avatar
Location: Delhi. Travelling as usual! Mumbai was great.
Infractions: 0/1 (4)
Where are you getting all these things installed? I would first take my car to a good installer and get things right if I'm not sure what to do/what's wrong.
Check out some different head units and if possible, listen to it before you settle for one.
__________________
A very big THANK YOU, Bombay!
Will miss you guys! :(
speedzak is online now   Reply With Quote
Old 25th June 2008, 10:52   #34 (permalink)
l3g0l4s's Avatar
Got the amp fixed at sprocket hyderabad actually .. Will take the car back to sprocket and try to get it fixed .
__________________
Thread Tools
XBOX360 optical output 5.1 decoding MuzzledMoose Gadgets, Computers & Software 1 24th October 2008 00:06
Amplifier output query panky12345 Ask the Gurus 17 8th December 2007 23:40
Query on Pionner 6950 Output saurabhkum Ask the Gurus 16 29th August 2007 14:23
Help ... Need High Output Alternator TOO MUCH LOAD low_bass_makker Ask the Gurus 44 14th March 2006 10:14
Engine Output and Torque power Surprise Technical Stuff 20 25th May 2005 21:52
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
