Thread Tools
Old 25th June 2008, 07:56   #1 (permalink)
madbullram's Avatar
Default Jeep Marine Speakers and Amp setup, Pics updated in pg5
Folks,
I am in US right now and once I am back (July end), I will get my Jeep back from Kerala.
I had a Alpine Cassette deck (which was upgraded in my Santro), that I am planning to fit in my Jeep.
Phase 1:
1. Fit the Alpine and completely hide it. The Cassette to Aux converter (dont remember the actual name, you play the cassette in Alpine and the aux wire connected to iPod) would be fitted to my iPod. That takes care of the HeadUnit. All my control will be through my iPod (I have my playlist so wont change songs, may be adjust volume)
2. Speakers - This is a CJ3B so I dont have too much, so I am gonna settle with a pair of Oval 3-Way or 2-Way Marine speakers (why marine, you know it leaks when it rains plus offroading), which would be fitted in a fabricated sheet so they cant remove easily.
Need suggestions with this:
I saw Polk/MOMO MMC690 6X9 3-Way, costs 120$.
Polk/MOMO MMC690 6"x9" 3-way car speakers Certified for marine use at Crutchfield.com
1. Is this worth it?
2. DO I really need Marine version (they state Water Resistant not proof)
3. Any other brands and speaker model
4. Do we get these in India? Is the price same in India? Is worth buying it from here or you think I can buy the same in India for same price?
Phase II:
1. Add 2-Channel amp and a small Sub .I am even thinking go for Amp with Aux in so I am remove the headunit and place it there. Is this setup a good option or retain the HU? The reason I think of this is space constraint.
TIA
madbullram is offline   Reply With Quote
Old 25th June 2008, 10:59   #2 (permalink)
DerAlte's Avatar
JBL has marine speakers, but not sure if they are sold in India. So do a few other companies. If you are in a town with a marina, may be you could scout around there. Your best bet is buying in US. Sure, they are all water resistant (occasional spray, salty conditions, etc.) - they will not play under-water. ;-)
Your plan looks good. There is at least one other thread where there was a discussion on fitting ICE in a jeep. Search the ICE section.
Amplifers like the Blaupunkt 280 or 480 support a direct AUX-IN which can take the iPod EP output.
__________________
Never believe it cannot be done - it's only that you haven't found out how!!!
Old 25th June 2008, 11:08   #3 (permalink)
madbullram's Avatar
Thanks DerALte.
1. I already have a sony cassette adapter, which I was using with my Alpine (was just explaining my setup)
2. Whats the suggestion on Polk? good brand?
3. Is it worth replacing HU with a Amp...i mean its gonna increase my expense by 3-4K for a good 2-channel amp which can be connected to the 2 speakers. I am thinking 6X9 so I dont have to invest on a Sub.
Old 25th June 2008, 11:32   #4 (permalink)
madbullram's Avatar
Found two threads, did answers some queries:
1. Amp directly connected to Speakers will reduce SQ
2. Can make a box and fit speakers below the seats
But still need inputs on the speakers and rates and if I get any marine speakers in India...
Old 25th June 2008, 12:09   #5 (permalink)
iceman91's Avatar
even the momo polk audio have marine speakers but they cost around 10-12k
__________________
WANTED: A Pair of Carbonfibre Cajones!!!!
iceman91 is offline   Reply With Quote
Old 25th June 2008, 16:08   #6 (permalink)
DerAlte's Avatar
Originally Posted by madbullram View Post
... 2. Whats the suggestion on Polk? good brand?
Polk is a respectable reputed brand. According to most who have auditioned them, their models are generally 'bright'. Audition them, may be you will like them
If you just want to listen to some music (your jeep environment will not be like a car with windows closed), an HU should do fine. But if you would rather that it goes loud for fun, then you should get an amp.
6x9 will hardly substitute for a sub in the jeep (in a car, maybe), but it will be much better than nothing.
How else would one connect the amp to the speakers? I think the point was connecting iPod directly to an amp which supports that - no reason why that will reduce SQ.
Of course you could fit the box below the seat (especially in an arrangement where the speakers are looking down to the floor, which will protect the speakers from spillage damage), though I am not sure what kind of an image this will create. You could try it out first.
__________________
Old 25th June 2008, 19:29   #7 (permalink)
madbullram's Avatar
Thanks DerAlte. The other post mentioned if you connect iPod directly to Amp it would reduce SQ compared Amp connected via HU. Thats what I was taking about.
The problem is BestBuy, CIrcuit City doesnt have this I have to buy online using Crutchfield which works out to 130$. Is it worth that price to buy from here...
Old 25th June 2008, 23:20   #8 (permalink)
DerAlte's Avatar
That's about 5K, not too bad - considering they are the marine models.
SQ wouldn't deteriorate at all. Consider this: when playing through an HU connected to the amp, you have 3 components between the iPod and the amp (EP cable, HU, RCA cable). Now imagine the possibilities of noise creeping in any of these 3. Compare that with only 1 component when you connect direct to amp (EP cable), and the possibility of noise creeping in.
__________________
Old 25th June 2008, 23:24   #9 (permalink)
madbullram's Avatar
I was thinking the same and was wondering why they were saying that. Plus iPod has equalizers if I want to tweak and can always add FM receiver to my iPod to take care of FM in Jeep correct?
How much would a Blau ones with Aux-in cost?
Old 26th June 2008, 13:43   #10 (permalink)
Bass&Trouble's Avatar
Dust could kill your speaker sooner than water. Please check whether Polk Audio's marine speakers have a protection for the gap between the cone and tweeter post.
__________________
Operator! Give me the number for 911!
Bass&Trouble is online now   Reply With Quote
Old 26th June 2008, 13:45   #11 (permalink)
DerAlte's Avatar
About 6K or less, with b&w.
__________________
Old 26th June 2008, 15:51   #12 (permalink)
ScarySkulls's Avatar
I've susbcribed to Rainbow newsletter from their website.
Here is what I got some time ago....
3. New Waterproof Loudspeakers
Rainbow is offering two new products for outdoor use. With these products the customers can enjoy the Rainbow Sound on boats or on their porch at home.
Rainbow presents a 165mm coaxial system CO-650-WP in a white plastic basket with an integrated grill for the use around salt water. The coaxial woofers are salt water and UV proof. This promises an untarnished Rainbow Sound for years.
For outdoor use we developed the 3-way system SPA 365 WP. The white weatherproof plastic housing is impermeable to splash-water, UV proof and suits perfect on a porch, next to a pool or in a spa.The cone made of polypropylene material offers a powerful Rainbow Sound even outside the car.
You can get the new Loudspeakers at your local Rainbow dealer!
Not sure if you'll get them here or not. But I think in US of A they should be available.
__________________
Punjabi for Life.
ScarySkulls is offline   Reply With Quote
Old 26th June 2008, 18:29   #13 (permalink)
DerAlte's Avatar
Originally Posted by ScarySkulls View Post
... suits perfect on a porch, next to a pool or in a spa.The cone made of polypropylene material offers a powerful Rainbow Sound even outside the car. ...
LOL either they want the car to be parked beside the pool / porch or in the spa, or the guy who composed this (not you, @scary) didn't check while cutting and pasting!
Do they have ovals (6x9), in the marine range? ram wanted ovals for the bass, as he has written. The round speakers wouldn't cut it in a jeep for that.
__________________
Old 26th June 2008, 18:34   #14 (permalink)
hahaha.... nice one!
__________________
Punjabi for Life.
Old 26th June 2008, 19:33   #15 (permalink)
madbullram's Avatar
B&T: I read the description on the website couldnt find anything on this, MMC690 Car Audio Speaker from Polk Audio can you explain the concept little bit more on what it is, so I can call them and ask.
Scary: Have never heard of this brand so I am skeptical. Polk Momo have been receiving rave reviews and also they are OE speakers in many boats. So was inclinded towards Polk. Do you have any feedback on Rainbow. Also, like DerAlte pointed out, since I have no plan for woofer immediately, I am looking for a oval may be fired from a 2-channel amp.
DerAlte: Thanks for the rate details, can you tell me which model so can check if its cheaper here
Thread Tools
Sam's Bangalore House Party - UPDATED with PICS & REPORT Sam Kapasi The Team-BHP Meet Section 298 28th April 2008 16:01
Mumbai Diwali meet-UPDATED with Reports & Pics from pg 23. manson The Team-BHP Meet Section 461 9th October 2007 17:50
Mumbai & Pune TBHPians drive! 3rd September - UPDATED with Reports & Pics shrivz The Team-BHP Meet Section 220 6th September 2006 11:15
Updated with PICS & VIDEO! : Revvhead, Epyupc & Mpower battle it out on track Revvhead Motor-Sports!! 20 17th June 2006 18:14
Updated Pics : Black & Dark Blue Porsche Carrera in Mumbai v12 Super-Cars & Imports in India 49 11th January 2006 21:52
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471
